#include
#include
#define SYSCLK 16000000L
#pragma interrupt_handler timer1_ovf_isr:9
#pragma interrupt_handler timer0_ovf_isr:10
unsigned char const table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //共阳极数码管编码
unsigned long int count=0;
unsigned long int temp=0;
void delay(unsigned char ms)
unsigned char i,j,k;
for(i=160;i》0;i--)
for(j=20;j》0;j--)
for(k=ms;k》0;k--);
//关闭看门狗
void Init_WatchDog(void)
WDR();
WDTCR |= (1《《WDCE) | (1《《WDE);
WDTCR = 0x00;
void timer1_init(void) //定时器1来提供1s的定时
TCCR1B=0x00; //停止定时器1
TCNT1H=0xC2;
TCNT1L=0XF7;
TCCR1B=0x05; //来自预分频器的1024 外部时钟为16M
void timer0_init(void)
TCCR0=0X00; //停止计数器工作
TCNT0=0X00; //设置初值为0
TCCR0=0X07; //时钟由外部时钟输入,上升沿触发
void port_init(void)
PORTB=0XFF;
DDRB=0XFF;
PORTC = 0x7F; //输出状态,初始后为高电平
DDRC = 0x7F;
PORTD |= 0xEF;
DDRD = 0xEF;
void timer1_ovf_isr(void)
CLI(); //关闭所有中断
TCCR0=0X00; //停止计数器0工作
TCNT1H=0xC2;
TCNT1L=0xF7;
count=(temp《《8)+TCNT0;
temp=0;
TCNT0=0X00;
TCCR1B=0x05;//定时器1的时钟为1024分频。
SEI(); //开中断
void timer0_ovf_isr(void)
unsigned char flag=0;
CLI(); //关闭所有中断
temp++;
TCNT0=0X00;
SEI(); //开中断
void init_devices(void)
CLI(); //关闭所有中断
Init_WatchDog();
port_init();//IO口初始化
timer0_init();
timer1_init(); //定时器初始化
TIMSK = 0x05; //使能定时器0和定时器1
SEI(); //开中断
void Scan_DPY(void)
PORTC = 0x20;
PORTD = (table[count/100000]&0x01)|(table[count/100000]&0x02)|(table[count/100000]&0x04)|(table[count/100000]&0x08)|((table[count/100000]&0x10)《《1)|((table[count/100000]&0x20)《《1)|((table[count/100000]&0x40)《《1);
delay(1);
PORTC = 0x10;
PORTD = (table[(count0000)/10000]&0x01)|(table[(count0000)/10000]&0x02)|(table[(count% 100000)/10000]&0x04)|(table[(count0000)/10000]&0x08)|((table[(count0000)/10000]&0x10)《《1)|((table[(count0000)/10000]&0x20)《《1)|((table[(count0000)/10000]&0x40)《《1);
delay(1);
PORTC = 0x08;
PORTD = (table[(count000)/1000]&0x01)|(table[(count000)/1000]&0x02)|(table[(count000)/1000]&0x04)|(table[(count000)/1000]&0x08)|((table[(count000)/1000]&0x10)《《1)|((table[(count000)/1000]&0x20)《《1)|((table[(count000)/1000]&0x40)《《1);
delay(1);
PORTC = 0x04;
PORTD = (table[(count00)/100]&0x01)|(table[(count00)/100]&0x02)|(table[(count00)/100]&0x04)|(table[(count00)/100]&0x08)|((table[(count00)/100]&0x10)《《1)|((table[(count00)/100]&0x20)《《1)|((table[(count00)/100]&0x40)《《1);
delay(1);
PORTC = 0x02;
PORTD = (table[(count0)/10]&0x01)|(table[(count0)/10]&0x02)|(table[(count0)/10]&0x04)|(table[(count0)/10]&0x08)|((table[(count0)/10]&0x10)《《1)|((table[(count0)/10]&0x20)《《1)|((table[(count0)/10]&0x40)《《1);
delay(1);
PORTC = 0x01;
PORTD = (table[count]&0x01)|(table[count]&0x02)|(table[count]&0x04)|(table[count]&0x08)|((table[count]&0x10)《《1)|((table[count]&0x20)《《1)|((table[count]&0x40)《《1);
delay(1);
void main(void)
init_devices();
while(1)
Scan_DPY();
#include
#include
for(i=160;i》0;i--)
for(j=20;j》0;j--)
for(k=ms;k》0;k--);
//关闭看门狗
WDR();
WDTCR = 0x00;
TCNT1H=0xC2;
TCNT1L=0XF7;
PORTB=0XFF;
DDRB=0XFF;
DDRC = 0x7F;
PORTD |= 0xEF;
DDRD = 0xEF;
CLI(); //关闭所有中断
TCNT1H=0xC2;
TCNT1L=0xF7;
temp=0;
TCNT0=0X00;
SEI(); //开中断
CLI(); //关闭所有中断
temp++;
TCNT0=0X00;
SEI(); //开中断
CLI(); //关闭所有中断
Init_WatchDog();
timer0_init();
SEI(); //开中断
void Scan_DPY(void)
PORTC = 0x20;
delay(1);
PORTC = 0x10;
delay(1);
PORTC = 0x08;
delay(1);
PORTC = 0x04;
delay(1);
PORTC = 0x02;
delay(1);
PORTC = 0x01;
delay(1);
void main(void)
init_devices();
while(1)
Scan_DPY();
举报
