准备工作:
1.下载ethercat-1.5.2.tar.bz2;
2.准备目标
arm板运行的内核源码,编译通过;
3.安装或者解压目标arm板相应的交叉编译工具。
这里使用的平台和内核版本是TQIMX6Q(
点此了解板载资源),Linux-4.1.4+Ubuntu16.04系统,
以下具体说明ethercat的移植:
1.解压IGH源码进入目录
#tar xjf ethercat-1.5.2.tar.bz2
#cd ethercat-1.5.2/
#./configure --prefix=/opt/ethercat-1.5.2/ --with-linux-dir=/opt/linux/xxx/kernel_imx --enable-8139too=no --enable-generic=yes CC=arm-none-linux-gnueabi-gcc --host=arm-none-linux-gnueabi
2.编译源码
#make
出现错误:
/home/mm/work/project/ethercat/ethercat-1.5.2/devices/generic.c: In func
tion 'ec_gen_device_init':
/home/mm/work/project/ethercat/ethercat-1.5.2/devices/generic.c:152:77: error: macro "alloc_netdev" requires 4 arguments, but only 3 given
dev->netdev = alloc_netdev(sizeof(ec_gen_device_t *), &null, ether_setup);
/home/mm/work/project/ethercat/ethercat-1.5.2/devices/generic.c:152:19: error: 'alloc_netdev' undeclared (first use in this function)
/home/mm/work/project/ethercat/ethercat-1.5.2/devices/generic.c:152:19: note: each undeclared identifier is reported only once for each function it appears in
/home/mm/work/project/ethercat/ethercat-1.5.2/devices/generic.c:146:10: warning: unused variable 'null' [-Wunused-variable]
char null = 0x00;
t/ethercat/ethercat-1.5.2/master/ethernet.c:151:72: error: macro "alloc_netdev" requires 4 arguments, but only 3 given
if (!(eoe->dev = alloc_netdev(sizeof(ec_eoe_t *), name, ether_setup))) {
/home/mm/work/project/ethercat/ethercat-1.5.2/master/ethernet.c:151:22: error: 'alloc_netdev' undeclared (first use in this function)
修改:
sudo vi devices/generic.c
152行 dev->netdev = alloc_netdev(sizeof(ec_gen_device_t *), &null, ether_setup);
改为
dev->netdev = alloc_netdev(sizeof(ec_gen_device_t *), &null, NET_NAME_UNKNOWN, ether_setup);
sudo vi master/ethernet.c
151行if (!(eoe->dev = alloc_netdev(sizeof(ec_eoe_t *), name, ether_setup))) {
改为
if (!(eoe->dev = alloc_netdev(sizeof(ec_eoe_t *), name,NET_NAME_UNKNOWN, ether_setup))) {
3.指定交叉编译工具,编译器modules
#make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- modules
//编译通过会对应生成ethercat-1.5.2/devices/ec_generic.ko和ethercat-1.5.2/master/ec_master.ko
4.安装
#make install
//make install 会在前面指定/opt/ethercat目录下有编译生成的各种用户空间的文件
5.在/opt/ethercat目录下创建modules文件夹,并复制ec_generic.ko和ec_master.ko到modules下
#mkdir -p /opt/ethercat/modules
#cp devices/ec_generic.ko /opt/ethercat/modules/
#cp master/ec_master.ko /opt/ethercat/modules/
6.将ethercat文件夹打包
# ls
bin etc include lib modules ***in
#tar -cjf ethercat.tar.bz2 ethercat
/至此IGH交叉编译完成,下面是在对应arm目标板上的操作*/
注意:
arm目标板上要使用的东西都在ethercat文件夹下或者是ethercat.tar.bz2
ethercat文件夹下包含链接文件,可以通过nfs/ftp等方式cp到板子上,不是通过挂载的方式只能下载ethercat.tar.bz2到板子再解压
1.将ethercat.tar.bz2拷贝到板子根目录下解压(这里不做说明)
root@EmbedSky-Board:/# tar xvf ethercat.tar.bz2
ethercat/
ethercat/ec_generic.ko
ethercat/lib/
ethercat/lib/libethercat.a
ethercat/lib/libethercat.so.1
ethercat/lib/libethercat.la
ethercat/lib/libethercat.so.1.0.0
ethercat/lib/systemd/
ethercat/lib/systemd/system/
ethercat/lib/systemd/system/ethercat.service
ethercat/include/
ethercat/include/ectty.h
ethercat/include/ecrt.h
ethercat/bin/
ethercat/bin/ethercat
ethercat/***in/
ethercat/***in/ethercatctl
ethercat/ec_master.ko
ethercat/etc/
ethercat/etc/init.d/
ethercat/etc/init.d/ethercat
ethercat/etc/sysconfig/
ethercat/etc/sysconfig/ethercat
ethercat/etc/ethercat.conf
2.进入ethercat目录下
root@EmbedSky-Board:/# cd /ethercat
root@EmbedSky-Board:/ethercat# ls
将ethercat目录下各文件目录的内容复制到板子根文件系统根目录下相应目录下,例如:cp bin/ethercat /bin/
3.复制ec_master.ko到/lib/modules/内核版本号/
root@EmbedSky-Board:/ethercat# cp /ethercat/modules/ec_master.ko /lib/modules/4.1.15
//这里的内核版本是4.1.15,可以通过uname -r 查看
root@EmbedSky-Board:/ethercat# depmod
4.配置rules,创建设备号
root@EmbedSky-Board:/ethercat#vi /etc/sysconfig/ethercat
将引号中的内容 "echo KERNEL=="EtherCAT[0-9]*", MODE="0664" > /etc/udev/rules.d/99-EtherCAT.rules" 加进去。
5.获取板子MAC地址
root@EmbedSky-Board:/ethercat#ifconfig
//eth2 Link encap:以太网 硬件地址 00:0c:29:01:69:aa
/**************至此板子上的配置结束,下面是启动EtherCAT ***************/
通过网线直连ethercat主从站,从站启动完成后,打开主站电源
1.配置主站的MAC地址
root@EmbedSky-Board:/ethercat#modprobe ec_master main_devices=1E:ED:19:27:1A:B3
2.启动ethercat
root@EmbedSky-Board:/ethercat# /etc/init.d/ethercat start
Starting EtherCAT master 1.5.2 done
3.安装通用网卡驱动
root@EmbedSky-Board:/ethercat#insmod /modules/ec_generic.ko
//上面两步加载了 EtherCAT 的内核模块,下面就可以使用 ethercat 工具来进行一些操作
4.通过ethercat查看信息
root@EmbedSky-Board:/ethercat#ethercat //输入ethercat得到帮助菜单
/到此移植过程结束***/
原文转载至【广州天嵌】公众号,更多内容欢迎关注。
