源程序:
#include “reg52.h”
#define uchar unsigned char
#define uint unsigned int
uchar code table[10]={0x3f,0x06,0x5b,
0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //共阴数码管显示码(0-9)
***it xiaoshudian=P0^7;
***it wei1=P2^4; //数码管位选定义
***it wei2=P2^5;
***it wei3=P2^6;
***it wei4=P2^7;
***it beep=P2^3; //蜂鸣器控制端
***it motor = P1^0; //电机控制
***it s1_jiasu = P1^4; //加速按键
***it s2_jiansu= P1^5; //减速按键
***it s3_jiting=P1^6; //停止/开始按键
uint pulse_count; //INT0接收到的脉冲数
uint num=0; //num相当于占空比调节的精度
uchar speed[3]; //四位速度值存储
float bianhuasudu; //当前速度(理论计算值)
float reallyspeed; //实际测得的速度
float vv_min=0.0;vv_max=250.0;
float vi_Ref=60.0; //给定值
float vi_PreError,vi_PreDerror;
uint pwm=100; //相当于占空比标志变量
int sample_time=0; //采样标志
float v_kp=1.2,v_ki=0.6,v_kd=0.2; //比例,积分,微分常数
void delay (uint z)
uint x,y;
for(x=z;x》0;x--)
for (y=20;y》0;y--);
void time_init()
ET1=1; //允许定时器T1中断
ET0=1; //允许定时器T0中断
TMOD = 0x15; //定时器0计数,模式1;定时器1定时,模式1
TH1 = (65536-100)/256; //定时器1值,负责PID中断 ,0.1ms定时
TL1 = (65536-100)%6;
TR0 = 1; //开定时器
TR1 = 1;
IP=0X08; //定时器1为高优级
EA=1; //开总中断
void keyscan()
float j;
if(s1_jiasu==0) //加速
delay(20);
if(s1_jiasu==0)
vi_Ref =10;
j=vi_Ref;
while(s1_jiasu==0);
if(s2_jiansu==0) //减速
delay(20);
if(s2_jiansu==0)
vi_Ref-=10;
j=vi_Ref;
while(s2_jiansu==0);
if(s3_jiting==0)
delay(20);
motor=0;
P1=0X00;
P3=0X00;
P0=0x00;
while(s3_jiting==0);
float v_PIDCalc(float vi_Ref,float vi_SpeedBack)
register float error1,d_error,dd_error;
error1=vi_Ref-vi_SpeedBack; //偏差的计算
d_error=error1-vi_PreError; //误差的偏差
dd_error=d_error-vi_PreDerror; //误差变化率
vi_PreError=error1; //存储当前偏差
vi_PreDerror=d_error;
bianhuasudu=(v_kp*d_error v_ki*vi_PreError v_kd*dd_error);
return (bianhuasudu);
void v_Display()
uint sudu;
sudu=(int)(reallyspeed*10); //乘以10之后强制转化成整型
speed[3]=sudu/1000; //百位
speed[2]=(sudu00)/100; //十位
speed[1]=(sudu0)/10; //个位
speed[0]=sudu; //小数点后一位
wei1=0; //第一位打开
P0=table[speed[3]];
delay(5);
wei1=1; //第一位关闭
wei2=0;
P0=table[speed[2]];
delay(5);
wei2=1;
wei3=0;
P0=table[speed[1]];
xiaoshudian=1;
delay(5);
wei3=1;
wei4=0;
P0=table[speed[0]];
delay(5);
wei4=1;
void BEEP()
if((reallyspeed)》=vi_Ref 5||(reallyspeed
beep=~beep;
delay(4);
void main()
time_init();
motor=0;
while(1)
v_Display();
BEEP();
if(s3_jiting==0) //对按键3进行扫描,增强急停效果
delay(20);
motor=0;
P1=0X00;
P3=0X00;
P0=0x00;
void timer0() interrupt 1
void timer1() interrupt 3
TH1 = (65536-100)/256; //1ms定时
sample_time ;
if(sample_time==5000) //采样时间0.1ms*5000=0.5s
TR0=0; //关闭定时器0
sample_time=0;
pulse_count=TH0*255 TL0; //保存当前脉冲数
keyscan(); //扫描按键
reallyspeed=pulse_count/(4*0.6); //计算速度
pwm=pwm v_PIDCalc(vi_Ref,reallyspeed);
if(pwm
if(pwm》100)pwm=100;
TH0=TL0=0;
TR0=1; //开启定时器0
num ;
if(num==pwm) //此处的num值,就是占空比
motor=0;
if(num==100) //100相当于占空比调节的精度
num=0;
motor=1;
源程序:
#include “reg52.h”
***it wei2=P2^5;
***it wei3=P2^6;
***it wei4=P2^7;
void delay (uint z)
uint x,y;
for(x=z;x》0;x--)
for (y=20;y》0;y--);
void time_init()
ET1=1; //允许定时器T1中断
ET0=1; //允许定时器T0中断
TR0 = 1; //开定时器
TR1 = 1;
IP=0X08; //定时器1为高优级
EA=1; //开总中断
void keyscan()
float j;
delay(20);
if(s1_jiasu==0)
vi_Ref =10;
j=vi_Ref;
while(s1_jiasu==0);
delay(20);
if(s2_jiansu==0)
vi_Ref-=10;
j=vi_Ref;
if(s3_jiting==0)
delay(20);
motor=0;
P1=0X00;
P3=0X00;
P0=0x00;
void v_Display()
uint sudu;
wei1=0; //第一位打开
P0=table[speed[3]];
delay(5);
wei1=1; //第一位关闭
wei2=0;
P0=table[speed[2]];
delay(5);
wei2=1;
wei3=0;
P0=table[speed[1]];
xiaoshudian=1;
delay(5);
wei3=1;
wei4=0;
P0=table[speed[0]];
delay(5);
wei4=1;
void BEEP()
beep=~beep;
delay(4);
void main()
time_init();
motor=0;
while(1)
v_Display();
BEEP();
delay(20);
motor=0;
P1=0X00;
P3=0X00;
P0=0x00;
sample_time ;
TR0=0; //关闭定时器0
sample_time=0;
keyscan(); //扫描按键
if(pwm
if(pwm》100)pwm=100;
TH0=TL0=0;
TR0=1; //开启定时器0
num ;
motor=0;
num=0;
motor=1;
举报
