下图是采用运放组成的文氏电桥振荡器
电路图,输出15-150KHz的正弦波。运放采用LF351,由于LF351比较难找到,也可采用TL071,TL081等运放。
通过选择不同的电容,分四档可调。
第一档输出范围:15Hz-150Hz
第二档输出范围:150Hz-1.5KHz
第三档输出范围:1.5KHz-15KHz
第四档输出范围:15KHz-150KHz
Here is Circuit classic Wien Bridge oscillator using an Op-Amp covering a frequency range of 15 to 150kHz in four switched steps.
Two condi
tions exist for a sinusoidal oscillator. Regenerative or positive feedback, and a closed loop gain of unity. The losses in the wien feedback circuit, are such that the open loop gain of the amplifier must also exceed 29.
In this circuit the gain is provided by a FET type op-amp. I have used an LF351, which may be hard to obtain, but the TL071CN or TL081CN may be used and have a faster slewing rate than the LF351. The Maplin order codes are RA67X and RA70M respectively. The wien network is a parallel combination of resistor and capacitor, in series with a serial R-C network. Regenerative feedback is applied from the op-amp output, to the serail R-C input and continues. Stabilization is required to prevent the otherwise uncontrolled oscillation from building up and becoming unstable.
引用: 这里是电路经典的文氏桥振荡器使用一个运算放大器频率范围涵盖了15至150kHz的切换在四个步骤。
两个条件都存在一个正弦振荡器。蓄热式或正反馈,一个团结的闭环增益。的损失,在维也纳的反馈电路,放大器的开环增益也必须超过29。
在这个电路的增益是由FET输入运算放大器。我用LF351,这可能是很难获得,但TL071CN或TL081CN也可以使用,有一个比LF351更快回转率。 Maplin订购代码分别RA67X和RA70M。维恩网络是一个电阻器和电容器的并联组合,在与一个串行RC网络串联。再生反馈运算放大器的输出应用,serail RC输入,并继续。稳定是必需的,以防止从建立和变得不稳定的,否则无节制的振荡。
[url=http:///uploadfile/2010/0525/20100525010540573.gif][/url]
