HMC476MP86TR产品介绍HMC476MP86TR
英文资料 RF Amp Single Gain Amp 6GHz 12V 4-Pin Micro-P T/R,RF Amplifiers
HMC479ST89TR
RF Amp Single MMIC Amp 5GHz 12V 4-Pin(3+Tab) SOT-89 T/R,RF Amplifiers
HMC481MP86TR
RF Amp Single MMIC Amp 5GHz 12V 4-Pin SMD T/R,RF Amplifiers
HMC346C8TR
Voltage Variable Absorp
tive Attenuator 30dB 8000MHz 8-Pin Case C-8 T/R,电压可变衰减器
HMC986
RF Switch SPDT 100MHz to 50GHz 22dB 13-Pin Die,射频开关
HMC788LP2ETR
RF Amp Single MMIC Amp 10GHz 7V 6-Pin DFN EP T/R,RF Amplifiers
HMC881LP5ETR
Active Filter Single Low Pass 4GHz 32-Pin QFN EP T/R,有源滤波器
HMC1019LP4ETR
5Bit 0.5dBStep 31dB 30GHz 24-Pin QFN EP T/R,数字衰减器
HMC894LP5ETR
Active Filter Single Band Pass 11.2GHz 32-Pin QFN EP T/R,有源滤波器
HMC187AMS8TR
Passive RF Multipliers x2 1.7GHz to 4GHz-OUT 8-Pin MSOP T/R,射频倍频器
HMC896
Active Filter Single SW-CAP Band Pass 18GHz,有源滤波器
HMC669LP3TR
RF Amp Single LNA 2.2GHz 6V 16-Pin QFN EP T/R,RF Amplifiers
HMC468LP3TR
3Bit 1dBStep 7dB 6GHz 16-Pin QFN EP,数字衰减器
HMC274QS16ETR
5Bit 1dBStep 31dB 2.7GHz 16-Pin QSOP,数字衰减器
HMC194MS8ETR
RF Switch SPDT 0MHz to 3GHz 24dB 8-Pin MSOP T/R,射频开关
HMC995LP5GETR
RF Amp Single Power Amp 16GHz 7V 24-Pin QFN EP T/R,RF Amplifiers
HMC540LP3ETR
4Bit 1dBStep 15dB 5.5GHz 16-Pin LFCSP EP T/R,数字衰减器
HMC604LP3ETR
RF Amp Single LNA 6GHz 8V 16-Pin LFCSP EP Cut Tape,RF Amplifiers
HMC540LP3TR
4Bit 1dBStep 15dB 5.5GHz 16-Pin QFN EP T/R,数字衰减器
HMC1132LP5DETR
RF Amp Single Power Amp 32GHz 6V 32-Pin LFCSP EP T/R,RF Amplifiers
HMC306AMS10TR
5Bit 0.5dBStep 15.5dB 3.8GHz 10-Pin MSOP T/R,数字衰减器
HMC141C8TR
Up/Down Conv Mixer 15GHz 8-Pin CSMD T/R,上下转换器和混频器
HMC637
RF Amp Single Power Amp 6GHz 14V 8-Pin Die Tray,RF Amplifiers
HMC975
RF Switch SPDT 2GHz to 50GHz 35dB 3-Pin Die,射频开关
HMC240A
RF Switch SPDT 0MHz to 4GHz 24dB 6-Pin SOT-26,射频开关
HMC1099LP5DETR
RF Amp Single Power Amp 1.1GHz 32V 32-Pin QFN EP T/R,RF Amplifiers
HMC1068-SX
Laser Driver 32Gbps 18-Pin Die Tray,激光驱动器
HMC1069-SX
32Gbps Optical Modulator Driver,激光驱动器
HMC5445LS6TR
RF Amp Single Power Amp 27GHz 6.3V 16-Pin CSMD T/R,RF Amplifiers
HMC5846LS6TR
RF Amp Single Power Amp 16GHz 8V 16-Pin CSMD T/R,RF Amplifiers
HMC7590-SX
SP Amp Transimpedance Amp 3.465V Die Tray,立体声功率放大器
HMC5805LS6TR
RF Amp Single MMIC Amp 40GHz 12V 16-Pin CSMD T/R,RF Amplifiers
HMC784MS8GTR
RF Switch SPDT 0MHz to 4GHz 26dB Automotive 8-Pin MSOP EP,射频开关
HMC351S8TR
Up/Down Conv Mixer 1.2GHz 8-Pin MSOP,上下转换器和混频器
HMC400MS8TR
Up/Down Conv Mixer 2.2GHz 8-Pin MSOP,上下转换器和混频器
HMC617LP3TR
RF Amp Single MMIC Amp 1.2GHz 5V 16-Pin QFN EP,RF Amplifiers
HMC1022-SX
RF Amp Single Power Amp 48GHz 12V 8-Pin Chip Tray,RF Amplifiers
HMC649
Phase Shifter Digital 3000MHz to 6000MHz 12-Pin Die Tray,相移器
HMC387MS8TR
Up/Down Conv Mixer 500MHz 8-Pin MSOP,上下转换器和混频器
HMC471MS8GTR
RF Amp Dual MMIC Amp 5GHz 12V 8-Pin MSOP EP,RF Amplifiers
HMC322
RF Switch SP8T 0MHz to 10GHz 18dB 14-Pin Die,射频开关
HMC399MS8TR
Up/Down Conv Mixer 1GHz 8-Pin MSOP,上下转换器和混频器
HMC322LP4TR
RF Switch SP8T 0MHz to 8GHz 20dB 24-Pin QFN EP T/R,射频开关
HMC6494LP6CETR
GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER,相移器
HMC1016
RF Amp Single Power Amp 46.5GHz 7V 5-Pin Die,RF Amplifiers
HMC891LP5ETR
Active Filter Single Band Pass 3.9GHz 32-Pin QFN EP T/R,有源滤波器
HMC554LC3BTR
Up/Down Conv Mixer 20GHz 12-Pin CQFN EP T/R,上下转换器和混频器
