% function [dsp pixel_dsp segs labels] = total_stereo...
% (i1,i2, hs,hr,M,mins, maxs, segs, labels)
% A first take at 3D from stereo. This function takes a stereo pAIr
% (that should already be registered so the only difference is in the
% 'x' dimension), and produces a 'disparity map.' The output here is
% pixel disparity, which can be converted to actual distance from the
% cameras if information about the camera geometry is known.
% The output here does show which objects are closer and 'segments'
% by distance to camera.
% EXAMPLE:
% i1 = imread('tsuL.jpg');
% i2 = imread('tsuR.jpg');
% [d p s l] = total_stereo(i1,i2,10,7,30,1,20);
% dsp = final disparity map
% pixel_dsp = pixel disparities before final filtering
% segs = segmented image from msseg
% labels = labemap from msseg
% i1 = right image
% i2 = left image
% hs = spacial bandwidth (for msseg) (usually 10)
% hr = range(color) bandwidth (for msseg) (usually 7)
% M = minimum segment size (for msseg) (usually 30)
% mins = minimum shift (usually 1)
% maxs = maximum shift (depends on images)
% segs = segments (if you have them pre-computed)
% labels = labelmap (if you have it pre-computed)
% Algorithm adapted from: "Segment-Based Stereo Matching Using
% Belief Propogation and Self-Adapting Dissimilarity Measure" by
% Klaus, Sormann, and Karner.
% (The algorithm in the paper is better, and more complete. The
% codes here are inspired by these guys, and parts are original)
% Coded by Shawn Lankton (http://www.shawnlankton.com) Dec. 2007
web www.hslogic.com
%QQ:1224848052
win_size = 5; %-- larger for less textured surfaces
tolerance = 0; %-- larger for less textured surfaces
%--I think this looks cleaner, but it doesn't really serve a purpose
pixel_dsp(pixel_dsp==inf)=NaN;
%%----- HELPER FUNCTIONS
%-- slides images across each other to get disparity estimate
function [disparity mindiff] = slide_images(i1,i2,mins,maxs,win_size)
[dimy,dimx,c] = size(i1);
disparity = zeros(dimy,dimx); %-- init outputs
mindiff = inf(dimy,dimx);
w = 5; %-- weight of CSAD vs CGRAD
hx = [-1 0 1]; hy = [-1 0 1]'; %-- gradient filter
h = 1/win_size.^2*ones(win_size); %-- averaging filter
g1x = sum(imfilter(i1,hx).^2,3); %-- get gradient for each image
g1y = sum(imfilter(i1,hy).^2,3); %-- used to compute CGRAD
g2x = sum(imfilter(i2,hx).^2,3);
g2y = sum(imfilter(i2,hy).^2,3);
step = sign(maxs-mins); %-- adjusts to reverse slide
for(i=mins:step:maxs)
s = shift_image(i2,i); %-- shift image and derivs
sx = shift_image(g2x,i);
sy = shift_image(g2y,i);
%--CSAD is Cost from Sum of Absolute Differences
%--CGRAD is Cost from Gradient of Absolute Differences
diffs = sum(abs(i1-s),3); %-- get CSAD and CGRAD
CSAD = imfilter(diffs,h);
gdiff = w * (sum(abs(g1x-sx),3)+sum(abs(g1y-sy),3));
CGRAD = imfilter(gdiff,h);
d = CSAD+CGRAD; %-- total 'difference' score
idx = find(d
disparity(idx) = i; % into correct place in image
mindiff(idx) = d(idx);
end
%-- reconsiles two noisy disparity estimates
function [pd] = winner_take_all(d1,m1,d2,m2,tolerance)
if(~exist('tolerance','var')) tolerance = 0; end
[dimy dimx] = size(d1);
d3 = zeros(size(d1));
m3 = zeros(size(d1));
%-- scoot L-R disparity (this should make disprities line up
% between the refernce image(left) and the other image(right)
for(i=1:max(d2(:)))
[yy xx] = find(d2==i); %-- get all disprities 'i'
idx2 = sub2ind([dimy, dimx],yy,xx);
xx = xx+i-1; %-- figure out new position
xx(xx>dimx)=dimx; %-- check boundary
idx3 = sub2ind([dimy dimx],yy,xx);
d3(idx3)=d2(idx2); %-- move disparities and
m3(idx3)=m2(idx2); %-- diffs to the right spot
end
%-- keep the best ones and mark the bad ones
pd = d3; %-- start with shifted L-R
idx = find(m1
pd(idx) = d1(idx); %-- use disp from R-L there
diff(idx) = m1(idx); %-- use L-R mindiff's too
idx = find(m1==m3); %-- find where its a tie
pd(idx) = round(d1(idx)+d3(idx))/2; %-- split the difference
pd(abs(d1-d3)>tolerance) = inf; %-- mark points that are
% likley wrong
%-- Shift an image
function I = shift_image(I,shift)
dimx = size(I,2);
if(shift > 0)
I(:,shift:dimx,:) = I(:,1:dimx-shift+1,:);
I(:,1:shift-1,:) = 0;
else
if(shift<0)
I(:,1:dimx+shift+1,:) = I(:,-shift:dimx,:);
I(:,dimx+shift+1:dimx,:) = 0;
end
end
% EXAMPLE:
% i1 = right image
% i2 = left image
web www.hslogic.com
%QQ:1224848052
idx = find(d
end
for(i=1:max(d2(:)))
end
idx = find(m1
% likley wrong
%-- Shift an image
dimx = size(I,2);
if(shift > 0)
else
if(shift<0)
end
end
