| 1 2 3 4 5 6 7 8 9 10 11 12 | #ifndef NET_PARAMS_H #define NET_PARAMS_H #define PARAM_HOTSPOT_SSID "TELLO-TELLO-60BA0A" // your AP SSID #define PARAM_HOTSPOT_PSK "12345678" // your AP PSK #define PARAM_HOTSPOT_TYPE WIFI_SEC_TYPE_PSK // defined in wifi_device_config.h #define PARAM_SERVER_ADDR "192.168.10.1" // your PC IP address #define PARAM_SERVER_PORT 8889 #endif // NET_PARAMS_H |
| 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 | #include #include #include #include #include "udp_client_test.h" #include "net_common.h" static char response[128] = ""; void UdpClientTest(const char* host, unsigned short port) { ssize_t retval = 0; int sockfd = socket(AF_INET, SOCK_DGRAM, 0); // UDP socket struct sockaddr_in toAddr = {0}; toAddr.sin_family = AF_INET; toAddr.sin_port = htons(port); // 端口号,从主机字节序转为网络字节序 if (inet_pton(AF_INET, host, &toAddr.sin_addr) <= 0) { // 将主机IP地址从“点分十进制”字符串 转化为 标准格式(32位整数) printf("inet_pton failed!rn"); goto do_cleanup; } // UDP socket 是 “无连接的” ,因此每次发送都必须先指定目标主机和端口,主机可以是多播地址 //从这里开始给无人机发送SDK中的指令,控制无人机 retval = sendto(sockfd, "command", sizeof("command"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","command", retval); osDelay(500); retval = sendto(sockfd, "takeoff", sizeof("takeoff"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","takeoff", retval); osDelay(800); retval = sendto(sockfd, "up 50", sizeof("up 50"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","up 50", retval); osDelay(500); retval = sendto(sockfd, "flip r", sizeof("flip r"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","flip r", retval); osDelay(800); retval = sendto(sockfd, "cw 360", sizeof("cw 360"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","cw 360", retval); osDelay(800); retval = sendto(sockfd, "ccw 360", sizeof("ccw 360"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","ccw 360", retval); osDelay(500); retval = sendto(sockfd, "flip r", sizeof("flip l"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","flip r", retval); osDelay(800); retval = sendto(sockfd, "left 80", sizeof("left 80"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","left 80", retval); osDelay(500); retval = sendto(sockfd, "right 80", sizeof("right 80"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","right 80", retval); osDelay(500); retval = sendto(sockfd, "land", sizeof("land"), 0, (struct sockaddr *)&toAddr, sizeof(toAddr)); printf("send UDP message {%s} %ld done!rn","land", retval); struct sockaddr_in fromAddr = {0}; socklen_t fromLen = sizeof(fromAddr); // UDP socket 是 “无连接的” ,因此每次接收时前并不知道消息来自何处,通过 fromAddr 参数可以得到发送方的信息(主机、端口号) retval = recvfrom(sockfd, &response, sizeof(response), 0, (struct sockaddr *)&fromAddr, &fromLen); if (retval <= 0) { printf("recvfrom failed or abort, %ld, %d!rn", retval, errno); goto do_cleanup; } response[retval] = '\0'; printf("recv UDP message {%s} %ld done!rn", response, retval); printf("peer info: ipaddr = %s, port = %drn", inet_ntoa(fromAddr.sin_addr), ntohs(fromAddr.sin_port)); do_cleanup: printf("do_cleanup...rn"); close(sockfd); } |
更多回帖
