基于HiSpark_WiFi_IoT Hi3861板子项目实战3-触摸彩屏LCD - HarmonyOS技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
pschen083 关注 私信
[文章]
这个例子是基于HiSpark Wi-Fi物联网套件Hi3861板子项目实战3-触摸彩屏LCD,从本例程中,在HarmonyOS中Hi3861学习到
      1。和谐liteOS Hi3861 WIFI设置和操作
      2。和谐LiteOS Hi3861 UDP长链接控制方式
      3。通过UDP控制彩屏LCD输出和触摸输入操作
      4。附上实战的原始码和个人开发的虚拟彩屏LCD带触摸,方便Hi3861,Hi3518EV300等没有彩屏驱动的MCU,也能通过彩屏LCD调试1。原始代码如下: #include“ ohos_init.h” #include“ cmsis_os2.h” #include“ hi_wifi_api.h” #include“ lwip / ip_addr.h” #include“ lwip / netifapi.h” #include“ lwip / sockets.h” #include” MQTTPacket.h“ #include” transport.h“ #include #include #include #include”
#include“ wifiiot_gpio_ex.h”
#include“ lwip / api_shell.h”
#include“ net_common.h”
#include“ cJSON.h”
#define PARAM_HOTSPOT_SSID“ Honor” //您的AP SSID
#定义PARAM_HOTSPOT_PSK “12345678” //你的AP PSK
的#define PARAM_SERVER_ADDR “192.168.43.36”
的#define PARAM_SERVER_PORT 6201
#定义PARAM_HOTSPOT_TYPE WIFI_SEC_TYPE_PSK //定义在wifi_device_config.h
的#define R_LED WIFI_IOT_GPIO_IDX_10
的#define B_LED WIFI_IOT_GPIO_IDX_12
的#define G_LED WIFI_IOT_GPIO_IDX_11
的#define DOWN 0×01
#define UP 0x02
#define MOVE 0x03
静态字符响应[128] =“”;
static int sockfd = 0;
static int sockfd_isConect = 0;
static struct sockaddr_in toAddr = {0};
static int lcdTouch[3] ={0};
void UdpClient(const char* host, unsigned short port);
static void APPTask(void *arg);
static void PrintLinkedInfo(WifiLinkedInfo* info)
    if (!info) return;
    static char macAddress[32] = {0};
    unsigned char* mac = info->bssid;
    snprintf(macAddress, sizeof(macAddress), "%02X:%02X:%02X:%02X:%02X:%02X",
        mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
    printf("bssid: %s, rssi: %d, connState: %d, reason: %d, ssid: %srn",
        macAddress, info->rssi, info->connState, info->disconnectedReason, info->ssid);
static volatile int g_connected = 0;
static void OnWifiConnectionChanged(int state, WifiLinkedInfo* info)
    if (!info) return;
    printf("%s %d, state = %d, info = rn", __FUNCTION__, __LINE__, state);
    PrintLinkedInfo(info);
    if (state == WIFI_STATE_AVALIABLE) {
        g_connected = 1;
    } else {
        g_connected = 0;
static void OnWifiScanStateChanged(int state, int size)
    printf("%s %d, state = %X, size = %drn", __FUNCTION__, __LINE__, state, size);
static WifiEvent g_defaultWifiEventListener = {
    .OnWifiConnectionChanged = OnWifiConnectionChanged,
    .OnWifiScanStateChanged = OnWifiScanStateChanged
static struct netif* g_iface = NULL;
int ConnectToHotspot(WifiDeviceConfig* apConfig)
    WifiErrorCode errCode;
    int netId = -1;
    errCode = RegisterWifiEvent(&g_defaultWifiEventListener);
    printf("RegisterWifiEvent: %drn", errCode);
    errCode = EnableWifi();
    printf("EnableWifi: %drn", errCode);
    errCode = AddDeviceConfig(apConfig, &netId);
    printf("AddDeviceConfig: %drn", errCode);
    g_connected = 0;
    errCode = ConnectTo(netId);
    printf("ConnectTo(%d): %drn", netId, errCode);
    while (!g_connected) { // wait until connect to AP
        osDelay(10);
    printf("g_connected: %drn", g_connected);
    g_iface = netifapi_netif_find("wlan0");
    if (g_iface) {
        err_t ret = netifapi_dhcp_start(g_iface);
        printf("netifapi_dhcp_start: %drn", ret);
        osDelay(100); // wait DHCP server give me IP
        ret = netifapi_netif_common(g_iface, dhcp_clients_info_show, NULL);
        printf("netifapi_netif_common: %drn", ret);
    return netId;
void DisconnectWithHotspot(int netId)
    if (g_iface) {
        err_t ret = netifapi_dhcp_stop(g_iface);
        printf("netifapi_dhcp_stop: %drn", ret);
    WifiErrorCode errCode = Disconnect(); // disconnect with your AP
    printf("Disconnect: %drn", errCode);
    errCode = UnRegisterWifiEvent(&g_defaultWifiEventListener);
    printf("UnRegisterWifiEvent: %drn", errCode);
    RemoveDevice(netId); // remove AP config
    printf("RemoveDevice: %drn", errCode);
    errCode = DisableWifi();
    printf("DisableWifi: %drn", errCode);
static void NetTask(void *arg)
    (void)arg;
    WifiDeviceConfig config = {0};
    // 准备AP的配置参数
    strcpy(config.ssid, PARAM_HOTSPOT_SSID);
    strcpy(config.preSharedKey, PARAM_HOTSPOT_PSK);
    config.securityType = PARAM_HOTSPOT_TYPE;
for(;;){
    osDelay(10);
    int netId = ConnectToHotspot(&config);
    int timeout = 2;
    while (timeout--) {
        printf("After %d seconds, I will startrn", timeout);
        osDelay(100);
    UdpClient(PARAM_SERVER_ADDR, PARAM_SERVER_PORT);
    // mqtt_connect();
    printf("disconnect to AP ...rn");
    DisconnectWithHotspot(netId);
    printf("disconnect to AP done!rn");
int udpsend(char *msg,int len){
    if(sockfd_isConect==0)return -1;
    ssize_t retval = sendto(sockfd, msg, len, 0, (struct sockaddr *)&toAddr, sizeof(toAddr));
        if (retval < 0) {
            printf("sendto failed!rn");
            return -1;
        return 1;
    int counts=0;
    ssize_t retval = 0;
    char* con = "connect;pc";
    while (g_connected){
    sockfd = socket(AF_INET, SOCK_DGRAM, 0); // UDP socket
    printf("ip%s:%drn",host,port);
    toAddr.sin_family = AF_INET;
    toAddr.sin_port = htons(port);
    if (inet_pton(AF_INET, host, &toAddr.sin_addr) <= 0) {
        printf("inet_pton failed!rn");
        goto do_cleanup;
    retval = sendto(sockfd, con, sizeof(con), 0, (struct sockaddr *)&toAddr, sizeof(toAddr));
    if (retval < 0) {
        goto do_cleanup;
    GpioSetOutputVal(B_LED, 1);
    printf("request connectrn");
    sockfd_isConect =1;
    struct sockaddr_in fromAddr = {0};
    socklen_t fromLen = sizeof(fromAddr);
    struct timeval timeOut;
    timeOut.tv_sec = 5;                 //设置2s超时
    timeOut.tv_usec = 0;
    if (setsockopt(sockfd, SOL_SOCKET, SO_RCVTIMEO, &timeOut, sizeof(timeOut)) < 0)
             printf("time out setting failedn");
    for(;;){
    retval = recvfrom(sockfd, &response, sizeof(response), 0, (struct sockaddr *)&fromAddr, &fromLen);
    if (retval == -1 && errno == EAGAIN)      //阻塞接收超时
               printf("timeout..n");
               if(++counts>=5){
              // goto do_cleanup;
                  break;
    else{
         int x=0 ,y=0;
         counts=0;
         response[retval] = '';
         cJSON *json = cJSON_Parse((char *)response);
         char *mouse = cJSON_GetObjectItem((cJSON *)json,"mouse")->valuestring;
         if(strncmp(mouse, (char *)"mouseMove", 9) == 0){
             x = cJSON_GetObjectItem((cJSON *)json,"x")->valueint;
            y = cJSON_GetObjectItem((cJSON *)json,"y")->valueint;
             lcdTouch[0]=MOVE;
             lcdTouch[1]=x;
             lcdTouch[2]=y;
         else if(strncmp(mouse, (char *)"mouseDown", 9) == 0){
             lcdTouch[0]=DOWN;
             lcdTouch[1]=x;
             lcdTouch[2]=y;
         else if(strncmp(mouse, (char *)"mouseUp", 7) == 0){
             lcdTouch[0]=UP;
             lcdTouch[1]=x;
             lcdTouch[2]=y;
         cJSON_Delete(json);
sockfd_isConect=0;
GpioSetOutputVal(B_LED, 0);
do_cleanup:
    printf("do_cleanup...rn");
    close(sockfd);
static void MainEntry(void) //主程入口
    GpioInit();
    //设置红色,蓝 色,绿色 LED IO为输出状态
    IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
    GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
    IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
    GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
    IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
    GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
    osThreadAttr_t attr;
    attr.name = "NetTask";
    attr.attr_bits = 0U;
    attr.cb_mem = NULL;
    attr.cb_size = 0U;
    attr.stack_mem = NULL;
    attr.stack_size = 30960;
    attr.priority = osPriorityNormal;
    if (osThreadNew(NetTask, NULL, &attr) == NULL) {  //Wifi udp task
        printf("[NetEntry] Falied to create NetTask!n");
    attr.name = "APPTask";
    //attr.priority = osPriorityBelowNormal7;
    if (osThreadNew(APPTask, NULL, &attr) == NULL) {  //app
         printf("[NetEntry] Falied to create APPTask!n");
SYS_RUN(MainEntry);
//RBG LCD绘图API接口 , LCD Color = RRBBGG(0XFFFFFF)
static char str[250] ={0};
void drawPixel(int x,int y, unsigned int color ){
    int len = sprintf((char *)str,"drawPixel;%d;%d;#%06x",x,y,color);
    udpsend((char *)str,len);
void drawLine(int x0,int y0,int x1,int y1, unsigned int color ){
    int len = sprintf((char *)str,"drawLine;%d;%d;%d;%d;#%06x",x0,y0,x1,y1,color);
void drawArc(int x, int y, int radius, int startAngle, int endAngle,unsigned int color){
    int len = sprintf((char *)str,"drawArc;%d;%d;%d;%d;%d;#%06x",x,y,radius,startAngle,endAngle,color);
void drawCircle(int x,int y, int radius,unsigned int color,int fill ){
    int len = sprintf((char *)str,"drawCircle;%d;%d;%d;#%06x;%d",x,y,radius,color,fill);
void drawRect(int x,int y, int width,int hight,unsigned int color,int fill ){
    int len = sprintf((char *)str,"drawRect;%d;%d;%d;%d;#%06x;%d",x,y,width,hight,color,fill);
void drawText(int x,int y, unsigned int color,const char* text,int size ){
    int len = sprintf((char *)str,"drawText;%d;%d;#%06x;%s;%d",x,y,color,text,size);
void drawImage(int x,int y, const char* fileName ){
    int len = sprintf((char *)str,"drawImage;%d;%d;%s",x,y,fileName);
void drawClean(unsigned int color ){
    int len = sprintf((char *)str,"drawClean;#%06x",color);
//===========================这个任务是写自已应用===============================
    (void)arg;
    int x=0,y=0;
    while(!sockfd_isConect){
        osDelay(100);
    drawClean(0xff0000); //red
    osDelay(100);
    drawClean(0x00ff00); //green
    osDelay(100);
    drawClean(0x0000ff);//blue
   osDelay(100);
    //drawImage(50,50, "test" );
    drawImage(0,0,"back");
    osDelay(100);
    drawText(60,100, 0x00ff00,"hello word!",20);
    osDelay(100);
    drawText(60,60, 0x00ff00,"中文测试",30);
    drawText(200,60, 0x0000ff,"中文测试",14);
    osDelay(100);
    drawCircle(300,70, 80,0xffffff,1);
    drawRect(200,100,100,150,0x0000ff,1);
for(;;){
        osDelay(10);
        if(lcdTouch[0]){
             if(lcdTouch[0]==DOWN) {
                 x=lcdTouch[1];
                 y=lcdTouch[2];
             else  if(lcdTouch[0]==UP) {
             else  if(lcdTouch[0]==MOVE) {
                 if((x==0)&&(y==0)){
                     x=lcdTouch[1];
                     y=lcdTouch[2];
                 drawLine(x,y,lcdTouch[1],lcdTouch[2],0xff0000);
                 x=lcdTouch[1];
                 y=lcdTouch[2];
             lcdTouch [0] = 0;
2.
二进制附件[attach] 980057 [/ attach]
3.虚拟UDP彩屏LCD
[附件] 980055 [/ attach]
[附件] 980056 [/ attach]
回帖(2)
soon顺soon
2020-11-30 09:11:24
厉害了,还能这么玩,赞
emitter
2020-11-30 11:34:23
有视频,有代码!赞
更多回帖
