SysCtlClockSet(SYSCTL_SYSDIV_64|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN |SYSCTL_XTAL_16MHZ);
SYSCTL_SYSDIV_64改变这个配置来修改其频率
SYSCTL_XTAL_16MHZ 这个参数只是你外部接的晶振频率
详细你可以参考TI数据手册上具体描述
//! Sets the clocking of the device.
//! param ui32Config is the required configuration of the device clocking.
//! This function configures the clocking of the device. The input crystal
//! frequency, oscillator to be used, use of the PLL, and the system clock
//! divider are all configured with this function.
//! The e ui32Config parameter is the logical OR of several different values,
//! many of which are grouped into sets where only one can be chosen.
//! The system clock divider is chosen with one of the following values:
//! b SYSCTL_SYSDIV_1, b SYSCTL_SYSDIV_2, b SYSCTL_SYSDIV_3, ...
//! b SYSCTL_SYSDIV_64.
//! The use of the PLL is chosen with either b SYSCTL_USE_PLL or
//! b SYSCTL_USE_OSC.
//! The external crystal frequency is chosen with one of the following values:
//! b SYSCTL_XTAL_4MHZ, b SYSCTL_XTAL_4_09MHZ, b SYSCTL_XTAL_4_91MHZ,
//! b SYSCTL_XTAL_5MHZ, b SYSCTL_XTAL_5_12MHZ, b SYSCTL_XTAL_6MHZ,
//! b SYSCTL_XTAL_6_14MHZ, b SYSCTL_XTAL_7_37MHZ, b SYSCTL_XTAL_8MHZ,
//! b SYSCTL_XTAL_8_19MHZ, b SYSCTL_XTAL_10MHZ, b SYSCTL_XTAL_12MHZ,
//! b SYSCTL_XTAL_12_2MHZ, b SYSCTL_XTAL_13_5MHZ, b SYSCTL_XTAL_14_3MHZ,
//! b SYSCTL_XTAL_16MHZ, b SYSCTL_XTAL_16_3MHZ, b SYSCTL_XTAL_18MHZ,
//! b SYSCTL_XTAL_20MHZ, b SYSCTL_XTAL_24MHZ, or b SYSCTL_XTAL_25MHz.
//! Values below b SYSCTL_XTAL_5MHZ are not valid when the PLL is in
//! operation.
//! The oscillator source is chosen with one of the following values:
//! b SYSCTL_OSC_MAIN, b SYSCTL_OSC_INT, b SYSCTL_OSC_INT4,
//! b SYSCTL_OSC_INT30, or b SYSCTL_OSC_EXT32. b SYSCTL_OSC_EXT32 is only
//! available on devices with the hibernate module, and then only when the
//! hibernate module has been enabled.
//! The internal and main oscillators are disabled with the
//! b SYSCTL_INT_OSC_DIS and b SYSCTL_MAIN_OSC_DIS flags, respectively.
//! The external oscillator must be enabled in order to use an external clock
//! source. Note that attempts to disable the oscillator used to clock the
//! device is prevented by the hardware.
//! To clock the system from an external source (such as an external crystal
//! oscillator), use b SYSCTL_USE_OSC b | b SYSCTL_OSC_MAIN. To clock the
//! system from the main oscillator, use b SYSCTL_USE_OSC b |
//! b SYSCTL_OSC_MAIN. To clock the system from the PLL, use
//! b SYSCTL_USE_PLL b | b SYSCTL_OSC_MAIN, and select the appropriate
//! crystal with one of the b SYSCTL_XTAL_xxx values.
//! note This function should only be called on TM4C123 devices. For
//! all other devices use the SysCtlClockFreqSet() function.
//! note If selecting the PLL as the system clock source (that is, via
//! b SYSCTL_USE_PLL), this function polls the PLL lock interrupt to
//! determine when the PLL has locked. If an interrupt handler for the
//! system control interrupt is in place, and it responds to and clears the
//! PLL lock interrupt, this function delays until its timeout has occurred
//! instead of completing as soon as PLL lock is achieved.
//! return None.
void
SysCtlClockSet(uint32_t ui32Config)
uint32_t ui32Delay, ui32RCC, ui32RCC2;
// Get the current value of the RCC and RCC2 registers.
ui32RCC = HWREG(SYSCTL_RCC);
ui32RCC2 = HWREG(SYSCTL_RCC2);
// Bypass the PLL and system clock dividers for now.
ui32RCC |= SYSCTL_RCC_BYPASS;
ui32RCC &= ~(SYSCTL_RCC_USESYSDIV);
ui32RCC2 |= SYSCTL_RCC2_BYPASS2;
// Write the new RCC value.
HWREG(SYSCTL_RCC) = ui32RCC;
HWREG(SYSCTL_RCC2) = ui32RCC2;
// See if the oscillator needs to be enabled.
if((ui32RCC & SYSCTL_RCC_MOSCDIS) && !(ui32Config & SYSCTL_MAIN_OSC_DIS))
// Make sure that the required oscillators are enabled. For now, the
// previously enabled oscillators must be enabled along with the newly
// requested oscillators.
ui32RCC &= (~SYSCTL_RCC_MOSCDIS | (ui32Config & SYSCTL_MAIN_OSC_DIS));
// Clear the MOSC power up raw interrupt status to be sure it is not
// set when waiting below.
HWREG(SYSCTL_MISC) = SYSCTL_MISC_MOSCPUPMIS;
// Timeout using the legacy delay value.
ui32Delay = 524288;
while((HWREG(SYSCTL_RIS) & SYSCTL_RIS_MOSCPUPRIS) == 0)
ui32Delay--;
if(ui32Delay == 0)
break;
// If the main oscillator failed to start up then do not switch to
// it and return.
if(ui32Delay == 0)
return;
// Set the new crystal value and oscillator source. Because the OSCSRC2
// field in RCC2 overlaps the XTAL field in RCC, the OSCSRC field has a
// special encoding within ui32Config to avoid the overlap.
ui32RCC &= ~(SYSCTL_RCC_XTAL_M | SYSCTL_RCC_OSCSRC_M);
ui32RCC |= ui32Config & (SYSCTL_RCC_XTAL_M | SYSCTL_RCC_OSCSRC_M);
ui32RCC2 &= ~(SYSCTL_RCC2_USERCC2 | SYSCTL_RCC2_OSCSRC2_M);
ui32RCC2 |= ui32Config & (SYSCTL_RCC2_USERCC2 | SYSCTL_RCC_OSCSRC_M);
ui32RCC2 |= (ui32Config & 0x00000008) << 3;
// Set the PLL configuration.
ui32RCC &= ~SYSCTL_RCC_PWRDN;
ui32RCC |= ui32Config & SYSCTL_RCC_PWRDN;
ui32RCC2 &= ~SYSCTL_RCC2_PWRDN2;
ui32RCC2 |= ui32Config & SYSCTL_RCC2_PWRDN2;
// Clear the PLL lock interrupt.
HWREG(SYSCTL_MISC) = SYSCTL_MISC_PLLLMIS;
if(ui32RCC2 & SYSCTL_RCC2_USERCC2)
else
// Set the requested system divider and disable the appropriate
// oscillators. This value is not written immediately.
ui32RCC &= ~(SYSCTL_RCC_SYSDIV_M | SYSCTL_RCC_USESYSDIV |
SYSCTL_RCC_MOSCDIS);
ui32RCC |= ui32Config & (SYSCTL_RCC_SYSDIV_M | SYSCTL_RCC_USESYSDIV |
ui32RCC2 &= ~(SYSCTL_RCC2_SYSDIV2_M);
ui32RCC2 |= ui32Config & SYSCTL_RCC2_SYSDIV2_M;
if(ui32Config & SYSCTL_RCC2_DIV400)
ui32RCC |= SYSCTL_RCC_USESYSDIV;
ui32RCC2 &= ~(SYSCTL_RCC_USESYSDIV);
ui32RCC2 |= ui32Config & (SYSCTL_RCC2_DIV400 | SYSCTL_RCC2_SYSDIV2LSB);
else
ui32RCC2 &= ~(SYSCTL_RCC2_DIV400);
// See if the PLL output is being used to clock the system.
if(!(ui32Config & SYSCTL_RCC_BYPASS))
// Wait until the PLL has locked.
for(ui32Delay = 32768; ui32Delay > 0; ui32Delay--)
if((HWREG(SYSCTL_PLLSTAT) & SYSCTL_PLLSTAT_LOCK))
break;
// Enable use of the PLL.
ui32RCC &= ~(SYSCTL_RCC_BYPASS);
ui32RCC2 &= ~(SYSCTL_RCC2_BYPASS2);
// Write the final RCC value.
// Delay for a little bit so that the system divider takes effect.
SysCtlDelay(16);
详细你可以参考TI数据手册上具体描述
//! operation.
//! return None.
void
ui32Delay = 524288;
ui32Delay--;
if(ui32Delay == 0)
break;
// it and return.
if(ui32Delay == 0)
return;
else
else
break;
SysCtlDelay(16);
举报
