TI论坛
直播中
张兰英
8年用户 169经验值
私信 关注
[问答]
当“pCaptureInstPrm->standard = SYSTEM_STD_MUX_4CH_D1”时,capture可以采到视频,但deinterlace会出错怎么办?
我们现在的DM385开发板上外挂了一个tvp5151芯片,用来接CVBS摄像头,原理图如下:
tvp5151输出8bit 内嵌同步的CVBS(NTSC或PAL)信号到DM385的VIP1 PORTA的D0~D7位上,数据流如下:
tvp5151(cvbs) -> capture-> deinterlace -> encode -> send
软件版本使用的是dvr rdk 4.0,代码如下:
void MultiCh_createVcapVencVdis()[        CaptureLink_CreateParams                        capturePrm;        DeiLink_CreateParams                                deiPrm;        IpcFramesOutLinkRTOS_CreateParams        ipcFramesOutVpssToHostPrm;        IpcFramesInLinkRTOS_CreateParams        ipcFramesInVideoFromHostPrm;        EncLink_CreateParams                                encPrm;        IPCBitsOutLinkRTOS_CreateParams                ipcBitsOutVideoPrm;        IpcBitsInLinkHLOS_CreateParams                ipcBitsInHostPrm;        CaptureLink_VipInstParams                        *pCaptureInstPrm;        CaptureLink_OutParams                                *pCaptureOutPrm;        VCAP_VIDEO_SOURCE_STATUS_S vidSourceStatus;        int i;        MULTICH_INIT_STRUCT(DeiLink_CreateParams, deiPrm);        MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams, ipcFramesOutVpssToHostPrm);        MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams, ipcFramesInVideoFromHostPrm);        MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);        MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams, ipcBitsOutVideoPrm);        MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams, ipcBitsInHostPrm);        gVcapModuleContext.captureId                                = SYSTEM_LINK_ID_CAPTURE;        gVcapModuleContext.deiId[0]                                        = SYSTEM_LINK_ID_DEI_0;        gVcapModuleContext.ipcFramesOutVpssToHostId        = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;        gVencModuleContext.ipcM3InId                                = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;        gVencModuleContext.encId                                        = SYSTEM_LINK_ID_VENC_0;        gVencModuleContext.ipcBitsOutRTOSId                        = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;        gVencModuleContext.ipcBitsInHLOSId                        = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;        MultiCh_detectBoard();        System_linkControl(SYSTEM_LINK_ID_M3VPSS,                SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,                NULL,                0,                TRUE                );        System_linkControl(SYSTEM_LINK_ID_M3VIDEO,                SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,                &systemVid_encDecIvaChMapTbl,                sizeof(SystemVideo_Ivahd2ChMap_Tbl),                TRUE                );        gVcapModuleContext.isWrbkCaptEnable = FALSE;        CaptureLink_CreateParams_Init(&capturePrm);        capturePrm.outQueParams[0].nextLink         = gVcapModuleContext.deiId[0];        capturePrm.isPalMode                                = TRUE;        capturePrm.numVipInst                                        = 1;        capturePrm.enableSdCrop                                        = FALSE;        capturePrm.doCropInCapture                                = FALSE;        capturePrm.tilerEnable                                        = FALSE;        capturePrm.numBufsPerCh                                        = NUM_CAPTURE_BUFFERS;        capturePrm.overrideNumBufsInInstPrms        = 1u;        pCaptureInstPrm                                         = &capturePrm.vipInst[0];        pCaptureInstPrm->inDataFormat                = SYSTEM_DF_YUV422P;        //pCaptureInstPrm->standard                        = SYSTEM_STD_D1;        pCaptureInstPrm->standard                        = SYSTEM_STD_MUX_4CH_D1;        pCaptureInstPrm->videoDecoderId                = 0;        pCaptureInstPrm->numOutput                        = 1;        pCaptureInstPrm->numBufsPerCh                = NUM_CAPTURE_BUFFERS;        pCaptureInstPrm->vipInstId                        = SYSTEM_CAPTURE_INST_VIP1_PORTA;        pCaptureInstPrm->videoIfMode                = SYSTEM_CAPT_VIDEO_IF_MODE_8BIT;        pCaptureInstPrm->inScanFormat                = SYSTEM_SF_INTERLACED;        pCaptureOutPrm                                                = &pCaptureInstPrm->outParams[0];        pCaptureOutPrm->dataFormat                        = SYSTEM_DF_YUV422I_YUYV;        pCaptureOutPrm->scEnable                        = FALSE;        pCaptureOutPrm->scOutWidth                        = 0;        pCaptureOutPrm->scOutHeight                 = 0;        pCaptureOutPrm->outQueId                        = 0;        deiPrm.inQueParams.prevLinkId                = gVcapModuleContext.captureId;        deiPrm.inQueParams.prevLinkQueId        = 0;        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.numerator = 1;        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.denominator = 1;        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.numerator = 1;        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.denominator = 1;        for (i = 1; i < DEI_LINK_MAX_CH; i++)                deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];        deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC]                                        = FALSE;        deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC]                                        = TRUE;        deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT]                = FALSE;        deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC_SECONDARY_OUT]                = FALSE;        deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC_TERTIARY_OUT]                = FALSE;        deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink                = gVcapModuleContext.ipcFramesOutVpssToHostId;        deiPrm.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC]                                        = FALSE;        deiPrm.comprEnable        = FALSE;        deiPrm.setVipScYuv422Format        = FALSE;        deiPrm.enableDeiForceBypass        = FALSE;        ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode                                        = FALSE;        ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink                                = TRUE;        ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink                                = TRUE;        ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId         = 0;        ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId                = gVcapModuleContext.deiId[0];        ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink                = gVencModuleContext.ipcM3InId;        ipcFramesInVideoFromHostPrm.baseCreateParams.noNotifyMode                                 = FALSE;        ipcFramesInVideoFromHostPrm.baseCreateParams.notifyNextLink                         = TRUE;        ipcFramesInVideoFromHostPrm.baseCreateParams.notifyPrevLink                         = TRUE;        ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId        = 0;                ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkId                = gVcapModuleContext.ipcFramesOutVpssToHostId;        ipcFramesInVideoFromHostPrm.baseCreateParams.outQueParams[0].nextLink        = gVencModuleContext.encId;        [                EncLink_ChCreateParams *pLinkChPrm;                EncLink_ChDynamicParams *pLinkDynPrm;                VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;                VENC_CHN_PARAMS_S *pChPrm;                for (i = 0; i < gVencModuleContext.vencConfig.numPrimaryChn; i++) [                        pLinkChPrm = &encPrm.chCreateParams;                        pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;                        pChPrm = &gVencModuleContext.vencConfig.encChannelParams;                        pDynPrm = &pChPrm->dynamicParam;                        pLinkChPrm->format                                                = IVIDEO_H264HP;                        pLinkChPrm->profile                                                = gVencModuleContext.vencConfig.h264Profile;                        pLinkChPrm->dataLayout                                        = IVIDEO_PROGRESSIVE;                        pLinkChPrm->fieldMergeEncodeEnable                = FALSE;                        pLinkChPrm->enableAnalyticinfo                        = pChPrm->enableAnalyticinfo;                        pLinkChPrm->enableWaterMarking                        = pChPrm->enableWaterMarking;                        pLinkChPrm->maxBitRate                                        = pChPrm->maxBitRate;                        pLinkChPrm->encodingPreset                                = pChPrm->encodingPreset;                        pLinkChPrm->rateControlPreset                        = IVIDEO_USER_DEFINED;                        pLinkChPrm->enableSVCExtensionFlag                = pChPrm->enableSVCExtensionFlag;                        pLinkChPrm->numTemporalLayer                        = pChPrm->numTemporalLayer;                        pLinkChPrm->enableHighSpeed                                = FALSE;                        pLinkDynPrm->intraFrameInterval                        = pDynPrm->intraFrameInterval;                        pLinkDynPrm->targetBitRate                                = pDynPrm->targetBitRate;                        pLinkDynPrm->interFrameInterval                        = 1;                        pLinkDynPrm->mvAccuracy                                        = IVIDENC2_MOTIONVECTOR_QUARTERPEL;                        pLinkDynPrm->inputFrameRate                                = pDynPrm->inputFrameRate;                        pLinkDynPrm->rcAlg                                                = pDynPrm->rcAlg;                        pLinkDynPrm->qpMin                                                = pDynPrm->qpMin;                        pLinkDynPrm->qpMax                                                = pDynPrm->qpMax;                        pLinkDynPrm->qpInit                                                = pDynPrm->qpInit;                        pLinkDynPrm->vbrDuration                                = pDynPrm->vbrDuration;                        pLinkDynPrm->vbrSensitivity                                = pDynPrm->vbrSensitivity;                        encPrm.numBufPerCh                                        = 4;                ]        ]        encPrm.chCreateParams[0].defaultDynamicParams.inputFrameRate = 30;        encPrm.chCreateParams[1].defaultDynamicParams.inputFrameRate = 30;        encPrm.inQueParams.prevLinkQueId        = 0;        encPrm.inQueParams.prevLinkId                = gVencModuleContext.ipcM3InId;        encPrm.outQueParams.nextLink                = gVencModuleContext.ipcBitsOutRTOSId;        ipcBitsOutVideoPrm.baseCreateParams.noNotifyMode                                = FALSE;        ipcBitsOutVideoPrm.baseCreateParams.notifyNextLink                                = TRUE;        ipcBitsOutVideoPrm.baseCreateParams.notifyPrevLink                                = TRUE;        ipcBitsOutVideoPrm.baseCreateParams.numOutQue                                        = 1;        ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId        = 0;        ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId                = gVencModuleContext.encId;        ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink                = gVencModuleContext.ipcBitsInHLOSId;        ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkQueId                = 0;        ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkId                = gVencModuleContext.ipcBitsOutRTOSId;        MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm);        vidSourceStatus.numChannels = 1;        vidSourceStatus.chStatus[0].chId = 0;        vidSourceStatus.chStatus[0].frameWidth = 720;        vidSourceStatus.chStatus[0].frameHeight = 288;        vidSourceStatus.chStatus[0].vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA;        vidSourceStatus.chStatus[0].isInterlaced = TRUE;        vidSourceStatus.chStatus[0].frameInterval = 20000;        vidSourceStatus.chStatus[0].isVideoDetect = FALSE;        Vcap_setVideoSourceStatus(&vidSourceStatus);        System_linkCreate(gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm));        System_linkCreate(gVcapModuleContext.deiId[0], &deiPrm, sizeof(deiPrm));        System_linkCreate(gVcapModuleContext.ipcFramesOutVpssToHostId, &ipcFramesOutVpssToHostPrm, sizeof(ipcFramesOutVpssToHostPrm));        System_linkCreate(gVencModuleContext.ipcM3InId, &ipcFramesInVideoFromHostPrm, sizeof(ipcFramesInVideoFromHostPrm));        System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));        System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));        System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm, sizeof(ipcBitsInHostPrm));]
测试结果如下:
1. 当“pCaptureInstPrm->standard  = SYSTEM_STD_D1”时,capture采不到视频;
2. 当“pCaptureInstPrm->standard  = SYSTEM_STD_MUX_4CH_D1”时,capture可以采到视频,但deinterlace会出错;
麻烦各位帮忙看一下上面的哪些配置是错误的,到底该怎么配置才能让视频出来? 谢谢!
回帖(4)
吴立节
2020-8-19 06:49:52
SYSTEM_STD_MUX_4CH_D1 这个应该不对的,是用于TVP5158这样4个通道复合的视频ADC的。SYSTEM_STD_D1应该是对的。
你提到capture能采集到视频,是通过什么来看的?
BR,
Eason
举报
张兰英
2020-8-19 07:01:57
你好,我也知道SYSTEM_STD_MUX_4CH_D1不对,但总是采不到数据,我就把所有分辨为720*576的格式都试了一遍,结果只有SYSTEM_STD_MUX_4CH_D1可以采集到视频;
我是根据"DVRRDK_04.01.00.02/ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/vps/drivers/capture/src/vpsdrv_captureList.c"文件中的Vps_captTskSubmitFieldList函数的如下代码作判断的:
Int32 Vps_captTskSubmitFieldList()[                    pid |= Vps_captLmPostDescList(listAddr, listSize);]当采集到1场数据时,Vps_captLmPostDescList函数返回0x1;
当采集到2场(1帧)数据时,Vps_captLmPostDescList函数返回0x11;
没有采集到数据时,Vps_captLmPostDescList函数返回0x0;
我们在DM385的VIP0 PORTA上接了一块HDMI解码芯片,那条通道是可以正常出视频的,此时Vps_captLmPostDescList函数返回0x11;
将VIP1 PORTA设置成SYSTEM_STD_MUX_4CH_D1, 此时Vps_captLmPostDescList函数返回0x1;
将VIP1 PORTA设置成SYSTEM_STD_D1, 此时Vps_captLmPostDescList函数返回0x0;
举报
张兰英
2020-8-19 07:14:34
问题解决了,是由于tvp5151的yout7没有信号输出导致采不到数据的,修改硬件后就好了。
举报
赵雪培
2020-8-19 07:26:21
你好,我也做了一个和你这个类似的开发,使用的是tvp5150,我的程序如果去掉DEI模块就是正常的,但当我加入DEI模块后就会出现VPSS挂掉的现象,出现错误sh是unhandle exception,希望你看到后给我点建议,qq:1083789279
举报
更多回帖
