编程论坛
400万+工程师在用
华为|鸿蒙开发者日
直播报名
400万+工程师在用
华为|鸿蒙开发者日
直播报名
电子发烧友网工程师
17年用户 16436经验值
擅长:可编程逻辑 MEMS/传感技术 测量仪表 模拟技术 控制/MCU RF/无线
私信 关注
GetRows 方法范例 (VB)
2009-1-8 10:20
<p><font face="Verdana">GetRows 方法范例 (VB)</font></p><font face="Verdana">
<p><br/>本范例使用 GetRows 方法从 Recordset 中检索指定数目的行,并用结果数据填充一个数组。在两种情况下,GetRows 方法返回的行将少于所需的数目:一种情况是到达了 EOF,另一种情况是 GetRows 试图检索被其他用户删除的记录。仅在发生第二种情况时,该函数才返回 False。运行此过程需要 GetRowsOK 函数。</p>
<p>Public Sub GetRowsX()</p>
<p>&nbsp;&nbsp;&nbsp; Dim rstEmployees As ADODB.Recordset<br/>&nbsp;&nbsp;&nbsp; Dim strCnn As String<br/>&nbsp;&nbsp;&nbsp; Dim strMessage As String<br/>&nbsp;&nbsp;&nbsp; Dim intRows As Integer<br/>&nbsp;&nbsp;&nbsp; Dim avarRecords As Variant<br/>&nbsp;&nbsp;&nbsp; Dim intRecord As Integer</p>
<p>&nbsp;&nbsp;&nbsp; ' Open recordset with names and hire dates from employee table.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; strCnn = "Provider=sqloLEDb;" &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "Data Source=srv;Initial Catalog=Pubs;User Id=sa;Password=; "<br/>&nbsp;&nbsp;&nbsp; Set rstEmployees = New ADODB.Recordset<br/>&nbsp;&nbsp;&nbsp; rstEmployees.Open "SELECT fName, lName, hire_date " &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "FROM Employee ORDER BY lName", strCnn, , , adCmdText</p>
<p>&nbsp;&nbsp;&nbsp; Do While True<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Get user input for number of rows.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; strMessage = "Enter number of rows to retrieve."<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; intRows = Val(InputBox(strMessage))</p>
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; IF intRows &lt;= 0 Then Exit Do</p>
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' If GetRowsOK is successful, print the results,<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' noting if the end of the file was reached.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; If GetRowsOK(rstEmployees, intRows, _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; avarRecords) Then<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; If intRows &gt; UBound(avarRecords, 2) + 1 Then<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; debug.Print "(Not enough records in " &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "Recordset to retrieve " &amp; intRows &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; " rows.)"<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; End If<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Debug.Print UBound(avarRecords, 2) + 1 &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; " records found."</p>
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Print the retrieved data.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; For intRecord = 0 To UBound(avarRecords, 2)<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Debug.Print "&nbsp; " &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; avarRecords(0, intRecord) &amp; " " &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; avarRecords(1, intRecord) &amp; ", " &amp; _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; avarRecords(2, intRecord)<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Next intRecord<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Else<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Assuming the GetRows error was due to data <br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' changes by another user, use Requery to<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' refresh the Recordset and start over.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; If MsgBox("GetRows failed--retry?", _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; vbYesNo) = vbYes Then<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; rstEmployees.Requery<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Else<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Debug.Print "GetRows failed!"<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Exit Do<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; End If<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; End If</p>
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Because using GetRows leaves the current <br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' record pointer at the last record accessed, <br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' move the pointer back to the beginning of the <br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Recordset before looping back for another search.<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; rstEmployees.MoveFirst<br/>&nbsp;&nbsp;&nbsp; Loop</p>
<p>&nbsp;&nbsp;&nbsp; rstEmployees.Close</p>
<p>End Sub</p>
<p>Public Function GetRowsOK(rstTemp As ADODB.Recordset, _<br/>&nbsp;&nbsp;&nbsp; intNumber As Integer, avarData As Variant) As Boolean</p>
<p>&nbsp;&nbsp;&nbsp; ' Store results of GetRows method in array.<br/>&nbsp;&nbsp;&nbsp; avarData = rstTemp.GetRows(intNumber)<br/>&nbsp;&nbsp;&nbsp; ' Return False only if fewer than the desired <br/>&nbsp;&nbsp;&nbsp; ' number of rows were returned, but not because the <br/>&nbsp;&nbsp;&nbsp; ' end of the Recordset was reached.<br/>&nbsp;&nbsp;&nbsp; If intNumber &gt; UBound(avarData, 2) + 1 And _<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Not rstTemp.EOF Then<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; GetRowsOK = False<br/>&nbsp;&nbsp;&nbsp; Else<br/>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; GetRowsOK = True<br/>&nbsp;&nbsp;&nbsp; End If</p>
<p>End Function</p>
<p></font>&nbsp;</p>
更多回帖
打开APP
