TI论坛
直播中
元办叙
8年用户 199经验值
私信 关注
[问答]
DSP C64x+异常处理的原因是什么?
你好,我使用的芯片是OMAP3530,对应的DSP型号为dm3730,开发环境为CCS3.3,BIOS5.4。在DSP/BIOS系统下开发。现在想使用C64x+芯片提供的异常处理机制来监测处理系统异常,但是在测试时,触发异常后,系统并未进入设置好的异常处理程序,麻烦你们帮我查找下原因?
         我开发过程如下:
        1、进入DSP/BIOS配置界面,使能EXC功能:HWI_Hardware Interrupt Service Routine Manager->Properties->勾选“Enable EXC module excdption processing”,保存。
        2、在DSP/BIOS配置界面,设置异常处理函数(excInt):HWI_NMI->Properties->function,在function后填入:_excInt,然后保存。
        3、相关代码说明:
(1)内存保护初始化
#define EXC_EVTPMCCMPA 120 /* L1P CPU Memory Protection fault */
#define EXC_EVTDMCCMPA 122 /* L1D CPU Memory Protection fault */
#define EXC_EVTUMCCMPA 124 /* L2 CPU Memory Protection fault */
void MPC_init (void)
     /*写1 到MPFCR,清除BOOT ROM 可能触发的内存保护异常*/
    L1PMPFCR = 1;
    L1DMPFCR = 1;
    L2MPFCR = 1;
   /*清除内存保护故障事件对应的EVTFLAG 和MEXPFLAG 标志位*/
   EVTCLR3 | = 0x01000000;
   EVTCLR3 | = 0x04000000;
   EVTCLR3 | = 0x10000000;
   /*使能内存保护故障事件*/
   EXPMASK3 & = ~0x01000000;
   EXPMASK3 & = ~0x04000000;
   EXPMASK3 & = ~0x10000000;
(2)异常中断初始化
#define EXC_TSRGEE 0x00000004
#define EXC_TSRXEN 0x00000008
void EXC_init(void)
    extern volatile cregister unsigned int TSR;
    extern volatile cregister unsigned int ISTP;
    extern volatile cregister unsigned int IER;
    extern volatile cregister unsigned ECR;
    extern volatile cregister unsigned NRP;
    extern volatile cregister unsigned NTSR;
    extern volatile cregister unsigned IERR;
/*清除异常中断相关寄存器的状态*/
   ECR = 0xFFFFFFFF;
   NRP = 0;
   NTSR = 0;
   IERR = 0;
/* 使能异常中断*/
  TSR |= EXC_TSRXEN | EXC_TSRGEE;
  IER = IER |2;
(3)设置内存保护页属性
#define MPC_MPPA_UX 0x00000001 /* User execute */
#define MPC_MPPA_UW 0x00000002 /* User Write */
#define MPC_MPPA_UR 0x00000004 /* User Read */
#define MPC_MPPA_SX 0x00000008 /* Supervisor execute */
#define MPC_MPPA_SW 0x00000010 /* Supervisor Write */
#define MPC_MPPA_SR 0x00000020 /* Supervisor Read */
#define MPC_MPPA_LOCAL 0x00000100 /* LOCAL CPU access */
void MPC_setBufferPA(void)
  unsigned int * p1;
  unsigned int i;
  p1 = (unsigned int *) 0x0184AE40;              //L1DMPPA16 地址
  for(i=0; i<8; i++)
     *p1++ = MPC_MPPA_UR | MPC_MPPA_SR | MPC_MPPA_LOCAL;
  for(i=0; i<8; i++)
     *p1++ = 0;                                            //16KB cache
(4)中断服务处理程序
void excInt()
//异常处理代码
(5)main函数中调用
#define L1DSRAM_CACHE_BASE 0x00F14000
void main(void)
[ volatile unsigned int * p;
/* L1DCFG L1D Configuration. 16k cache, 16k addressable */
   L1DCFG = 3;
   MPC_init();   //内存保存初始化
   EXC_init();   //中断初始化
   MPC_setBufferPA();   //设置内存属性
   //向不可写的内存进行写操作,触发异常
   p= (unsigned int *) L1DSRAM_CACHE_BASE;
   *p=123;
      将上述程序集成到系统中,编译后下载到调试板上,发现系统并未进入异常处理函数excInt()。我想问下,是我配置存在问题吗?还是什么其他原因?
回帖(15)
余少虹
2020-8-13 08:29:06
先看一下IFR中断标志位有没有置起来?
举报
元办叙
2020-8-13 08:39:05
引用: vuywsdfwf 发表于 2020-8-13 10:20
先看一下IFR中断标志位有没有置起来?
你好,非常感谢你的解答。
我已经将IFR寄存器的状态值打印出来了,发现其低16位的值是0x8000,NMIF并未置1,所以无法进入异常中断。我还有几个疑问,麻烦你解答下:
1、利用DSP/BIOS开发,我在程序中那样使能C64x+ 的异常处理机制对吗?
2、现在未进入中断,我应该从那方面去寻找问题?即为什么NMIF未置为1,是我异常使能不对?还是我那样操作内存并未触发异常呢?
举报
余少虹
2020-8-13 08:46:24
引用: Abby0127 发表于 2020-8-13 10:30
你好,非常感谢你的解答。
DSP/BIOS里有MPC_setBufferPA API函数,可以试试用BIOS API函数配置。 请参考一下DM6437的exception handling例程。
http://processors.wiki.ti.com/index.php/Cache_Protection_With_the_DSP/BIOS_MPC_Module#Example
举报
元办叙
2020-8-13 09:02:13
你好,经过调试我的程序已经可以进入NMI中断了,非常感谢。
我还有几个疑问,希望你能解答下:
1、如果在BIOS中不使能”MPC module“,是否可使用中的MPC API函数?
2、在BIOS中不使能”MPC module“,但使能了”内存异常事件“,如果出现了内存的违规访问,是否会产生相应的异常事件,并进入”HWI_NMI“中断的处理函数?
               期待你的回答!祝:工作愉快!
举报
更多回帖
