下面是我的ADC的配置,EPWM触发转换,触发频率25KHZ,现在有个问题是,在某个转换点的时候,ADC会有较大幅度的转换误差,就是跳动,在200左右,特别是在输入共模电压在1V一下和9V以上的时候。
测量了ADC的输入,除了电源产生得到噪声之外并没有发现毛刺和电压突变。
void ConfigureADC(void)
Uint16 acqps;
EALLOW;
//write configurations
AdcaRegs.ADCCTL2.bit.PRESCALE = 2; //set ADCCLK divider to /2
AdcSetMode(ADC_ADCA, ADC_RESOLUTION_16BIT, ADC_SIGNALMODE_DIFFERENTIAL);
//Set pulse positions to late
AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1;
//power up the ADC
AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1;
//delay for 1ms to allow ADC time to power up
DELAY_US(1000);
EDIS;
//determine minimum acquisition window (in SYSCLKS) based on resolution
if(ADC_RESOLUTION_12BIT == AdcaRegs.ADCCTL2.bit.RESOLUTION)
acqps = 14; //75ns
else //resolution is 16-bit
acqps = 63; //320ns
//Select the channels to convert and end of conversion flag
EALLOW;
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 0; //SOC0 will convert pin A0
AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is 100 SYSCLK cycles
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 5; //trigger on ePWM1 SOCA/C
AdcaRegs.ADCSOC1CTL.bit.CHSEL = 2; //SOC1 will convert pin A2
AdcaRegs.ADCSOC1CTL.bit.ACQPS = acqps; //sample window is 100 SYSCLK cycles
AdcaRegs.ADCSOC1CTL.bit.TRIGSEL = 5; //trigger on ePWM1 SOCA/C
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 1; //end of SOC1 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
EDIS;
Uint16 acqps;
EALLOW;
//power up the ADC
DELAY_US(1000);
EDIS;
acqps = 14; //75ns
acqps = 63; //320ns
EALLOW;
EDIS;
举报
