void McBSP_Init(void) [ McbspaRegs.SPCR2.all=0x0000; McbspaRegs.SPCR1.all=0x0000; McbspaRegs.SPCR2.bit.FREE = 1; McbspaRegs.SPCR2.bit.SOFT = 1; //1x - Free run McbspaRegs.SPCR2.bit.XINTM = 0; //0 - XINT when XRDY set, indicate the transmitter is ready to accept new data McbspaRegs.SPCR2.bit.XSYNCERR = 0; //0 - Clear Transmit frame-synch error McbspaRegs.SPCR1.bit.DLB = 0; //0 - Disable DLB mode. Comment out for non-DLB mode. McbspaRegs.SPCR1.bit.RJUST = 0; //0 - Right justify the Receive data and Zero fill the MSB McbspaRegs.SPCR1.bit.CLKSTP = 0x2; //2 - Clock stop mode, without clock delay McbspaRegs.SPCR1.bit.DXENA = 0; //0 - DX delay enabler off McbspaRegs.SPCR1.bit.RINTM = 0; //0 - RINT when RRDY set, indicate the receive data is ready to be read McbspaRegs.SPCR1.bit.RSYNCERR = 0; //0 - Clear Receive frame-synch error McbspaRegs.MFFINT.all = 0x0; //0 - Disable all interrupts McbspaRegs.RCR2.bit.RPHASE = 0; //0 - Single-phase frame McbspaRegs.RCR2.bit.RCOMPAND = 0; //0 - No companding, MSB received first McbspaRegs.RCR2.bit.RFIG = 1; //0 - Unexpected frame-synch cause aborts data,set RSYNCEERR and begin new data McbspaRegs.RCR2.bit.RDATDLY = 0; //0 - RX data delay is 0 bit McbspaRegs.RCR1.bit.RFRLEN1 = 0; //0 - 1 word in phase 1 of the receive frame McbspaRegs.RCR1.bit.RWDLEN1 = 2; //2 - 16bits, Receive word length McbspaRegs.XCR2.bit.XPHASE = 0; //0 - Single-phase frame McbspaRegs.XCR2.bit.XCOMPAND = 0; //0 - No companding, MSB transmit first McbspaRegs.XCR2.bit.XFIG = 1; //1 - Ignore Transmit Frame-synch McbspaRegs.XCR2.bit.XDATDLY = 0; //0 - TX data delay is 0 bit McbspaRegs.XCR1.bit.XFRLEN1 = 0; //0 - 1 word in phase 1 of the transmit frame McbspaRegs.XCR1.bit.XWDLEN1 = 0; //0 - 8 bits, Transmit word length McbspaRegs.SRGR2.bit.GSYNC = 0; //0 - No clock sync for CLKG McbspaRegs.SRGR2.bit.FPER = 11; //11 - Frame-synch period, (11+1)*(1000/1200) = 10ms McbspaRegs.SRGR2.bit.FSGM = 1; //1 - Frame-synch pulses from the sample rate generator McbspaRegs.PCR.bit.SCLKME = 1; McbspaRegs.SRGR2.bit.CLKSM = 0; //1-0 - SCLKME=1, CLKSM=0, Clock Signal on MCLKR pin McbspaRegs.SRGR1.bit.CLKGDV = 0; //0 - Divide-down value for CLKG 1 delay_loop(); McbspaRegs.SRGR1.bit.FWID = 1; //1 - Frame-synchronization pulse width delay_loop(); McbspaRegs.PCR.bit.FSXM = 1; //1 - FSX generated internally, McbspaRegs.PCR.bit.FSRM = 0; //0 - FSR derived from an external source McbspaRegs.PCR.bit.CLKXM = 1; //1 - CLKX generated internally McbspaRegs.PCR.bit.CLKRM = 0; //0 - CLKR derived from an external source McbspaRegs.PCR.bit.FSXP = 0; //0 - Transmit frame-synch pulses are active high McbspaRegs.PCR.bit.FSRP = 0; //0 - Receive frame-synch pulses are active high McbspaRegs.PCR.bit.CLKXP = 1; //1 - Transmit data is sampled on the Falling edge of CLKX McbspaRegs.PCR.bit.CLKRP = 1; //1 - Receive data is sampled on the rising edge of MCLKR McbspaRegs.SPCR2.bit.GRST = 1; //1 - Enable Sample rate generator delay_loop(); // wait at least 2 CLKG clock cycles McbspaRegs.SPCR2.bit.XRST = 1; //1 - Release TX from Reset McbspaRegs.SPCR1.bit.RRST = 1; //1 - Release RX from Reset McbspaRegs.SPCR2.bit.FRST = 1; //1 - Frame Sync Generator reset ] |
更多回帖
