嗨,可參考以下電路
其中6和7為天線
而P13和P14為喚醒功用,讓Wifi不工作時候能夠降低功耗,視需求
其他BT相關的9~12為PCM,是通訊界面,USB/PCM擇一,所以PCM可不接
Product model
Interface type
Work channel
- WIFI: 1-13(default Channel Plan WW13,other Channel Plan optional) 11: (Ch. 1-11) – United States(North America)
13: (Ch. 1-13) – Europe
14: (Ch. 1-14) – Japan
- BT: CH.0~78
Frequency range
Modulation mode
Transmission speed
- WIFI
- 802.11b: 11,5.5,2,1 Mbps
- 802.11g:54,48,36,24,18,12,9,6Mbps
- 802.11n:up to 150Mbps
- BT:
- 1 Mbps for Basic Rate
- 2,3 Mbps for Enhanced Data Rate
- 6,9,12,18,24,36,48,54 Mbps for High Speed
Receiving sensitivity
- 802.11b@8% PER
802.11g@10% PER
802.11n@10% PER
Working voltage
Working modeWIFI
- Ad-hoc mode (Peer-to-Peer )
Infrastructure mode
Software AP
WiFi Direct
BT
Support operating system
- Support Windows/Linux/Android operatin system
Mode size
Use environment
- Working environment:0℃~70℃
- Working humidity:10%~90%RH Non condensing
- Storage temperature:-40℃~80℃
- Storage humidity:5%~90%RH Non condensing
以上供參考
嗨,可參考以下電路
其中6和7為天線
Product model
Interface type
Work channel
- BT: CH.0~78
Frequency range
Modulation mode
Transmission speed
- WIFI
- BT:
- 802.11b@8% PER
802.11g@10% PER
802.11n@10% PER
Working voltage
Working modeWIFI
Infrastructure mode
Software AP
WiFi Direct
BT
Mode size
Use environment
以上供參考
举报
