Exotic Spin Excitations of Quantum Magnets
量子磁体的外来的自旋激振
量子自旋液体(QSLs)代表一种新颖的物质状态,其中没有自然的对称或缺,而且甚至在绝对零度自旋保持在类似液体的状态。它们在量子计算与通讯中具有很大的势力。更进一步,相信了解QSLs会帮助解决高温超导电性的长期难题。由于这些原因,在以往的四十五年里进行了研究,但是到目前为止还是没有出现理想的QSLs材料。讨论呈现出两种QSL提议的结果,极度几何化的化合物YbMgGa04和YbZnGa04带三角晶格,和彻洛利材料阿尔法-RuC13带蜂窝晶格。对于YbMgGaO4和YbZnGaO4两者,我们发现它们的真正的基态是旋转玻璃,而且无序的主要责任为自旋-液体-类观察。对于阿尔法RuC13,有一个主导的吉洛切作用于之字形有序状态中,并且一个电磁场可以驱动系统从一个有序的状态到一个可能的QSL态。最后将简单地讨论近期发现的拓扑磁量子于三维的逆磁铁Cu3Te06。
A New Era of Galactic Archaeology
银河考古时代的新纪元
Understanding physical processes responsible for the formation and evolution of galaxies like the Milky Way is a fundamental problem in astrophysics. However, a key challenge is that the properties and orbits of the stars can only be observed at present: to understand what happened in the Milky Way at earlier epochs, one must explore “archaeological” techniques. The Galacticarchaeology landscape is rapidly changing thanks to on-going large-scale surveys (astrometry, photometry, spectroscopy, asteroseismology) which provide a few orders of magnitude more stars than before. In this talk, I will discuss new "phenomenological" opportunities with these surveys. I will introduce a new set of machine-learning tools for maximally harness information from spectra (LAMOST), photometric fluxes (Gaia) and light curves (TESS). I will also present the new opportunities in Galactic archaeology in the era of deep photometry,such as LSST and DES.
对星系类似于银河的形成和进化负责的物理过程的理解是天文物理学的基础问题。可是目前关键的挑战是只能够观察天上星星的特性和轨道:了解较早纪元时期银河系发生的事情,您必须探索“考古学”技巧。银河考古地形的迅速改变感谢进行中的大尺度的观察(天文,光学,频谱,星震学)等比以往提供了数次放幅度的星星。这里探讨一下新的“现象学”机遇于这些观察中。介绍一组新的机器学习工具及大地有益于信息来自频谱(LAMOST),光度流量(盖亚)和光的曲线(TESS)。还将呈现新的机遇在深的光度学纪元的银河考古学中,例如LSSE和DES。
量子力学常用单位和常数,以及阅读发音,附图二如下,符合国际标准:
