嵌入式学习小组
直播中
魏渝韦
8年用户 198经验值
私信 关注
关于FreeRTOS使用IAP跳转是怎么回事
之前做了一个IAP程序,bootloader使用裸机,APP使用ucos2系统,IAP可以互相跳转
程序如下:
[C] 纯文本查看 复制代码
void iap_load_app(u32 appxaddr){if(((*(vu32*)appxaddr)&0x2FFE0000)==0x20000000)                        //检查栈顶地址是否合法.{                  jump2app=(iapfun)*(vu32*)(appxaddr+4);                        //用户代码区第二个字为程序开始地址(复位地址)                 __set_PSP(*(volatile unsigned int*) appxaddr);                  //重新设置进程PSP堆栈地址                __set_CONTROL(0);                                                           //设置为MSP                __set_MSP(*(volatile unsigned int*) appxaddr);                  //重新设置进程MSP堆栈地址                jump2app(); //跳转到APP.}}现在学习FreeRTOS,就把bootloader程序改为了FreeRTOS,但是在jump2app()跳转的时候进入到了HardFault_Handler
尝试在设置堆栈和跳转前,关闭调度器vPortEndScheduler()和挂起调度vTaskSuspendAll()都没有效果。
然后又尝试把所有任务都注释掉,就添加一个任务,就是跳转,然后启用调度,也是不行。
不打开任务和调度,就可以跳转。
感觉是堆栈没设置好,不知道各位有没有试过在FreeRTOS程序跳转或有什么思路?
谢谢!
回帖(13)
姜薇
2020-6-18 12:26:34
参考我们使用的跳转。
[C] 纯文本查看 复制代码
/* * File      : rbl_jump_stm32f2_f4.c.c * This file is part of RT-Thread RTOS * COPYRIGHT (C) 2006 - 2015, RT-Thread Development Team * *  This program is free software; you can redistribute it and/or modify *  it under the terms of the GNU General Public License as published by *  the Free Software Foundation; either version 2 of the License, or *  (at your option) any later version. * *  This program is distributed in the hope that it will be useful, *  but WITHOUT ANY WARRANTY; without even the implied warranty of *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the *  GNU General Public License for more details. * *  You should have received a copy of the GNU General Public License along *  with this program; if not, write to the Free Software Foundation, Inc., *  51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA. * * Change Logs: * Date           Author       Notes * 2014-03-12     aozima       first version. * 2015-09-22     aozima       disable and clean up all interrupts. */#include #include void jump_to_app(uint32_t app_address){    typedef void (*_func)(void);    __disable_irq();    /* MCU peripherals re-initial. */    {        GPIO_InitTypeDef GPIO_InitStruct;        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_IN;        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;        GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;        GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_NOPULL;        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_All;        GPIO_InitStruct.GPIO_Pin &= ~(GPIO_Pin_13 | GPIO_Pin_14); /* SWDIO/SWCLK */        GPIO_Init(GPIOA, &GPIO_InitStruct);        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_All;        GPIO_Init(GPIOB, &GPIO_InitStruct);        GPIO_Init(GPIOC, &GPIO_InitStruct);        GPIO_Init(GPIOD, &GPIO_InitStruct);        GPIO_Init(GPIOE, &GPIO_InitStruct);        GPIO_Init(GPIOF, &GPIO_InitStruct);        GPIO_Init(GPIOG, &GPIO_InitStruct);        GPIO_Init(GPIOH, &GPIO_InitStruct);        GPIO_Init(GPIOI, &GPIO_InitStruct);        /* reset systick */        SysTick->CTRL &= ~SysTick_CTRL_ENABLE_Msk;        /* disable all peripherals clock. */        RCC->AHB1ENR = (1<<20); /* 20: F4 CCMDAT ARAMEN. */        RCC->AHB2ENR = 0;        RCC->AHB3ENR = 0;        RCC->APB1ENR = 0;        RCC->APB2ENR = 0;        /* Switch to default cpu clock. */        RCC->CFGR = 0;    } /* MCU peripherals re-initial. */    /* Disable MPU */    MPU->CTRL &= ~MPU_CTRL_ENABLE_Msk;    /* disable and clean up all interrupts. */    {        int i;        for(i = 0; i < 8; i++)        {            /* disable interrupts. */            NVIC->ICER = 0xFFFFFFFF;            /* clean up interrupts flags. */            NVIC->ICPR = 0xFFFFFFFF;        }    }    /* Set new vector table pointer */    SCB->VTOR = app_address;    /* reset register values */    __set_BASEPRI(0);    __set_FAULTMASK(0);    /* set up MSP and switch to it */    __set_MSP(*(uint32_t*)app_address);    __set_PSP(*(uint32_t*)app_address);    __set_CONTROL(0);    /* ensure what we have done could take effect */    __ISB();    __disable_irq();    /* never return */    ((_func)(*(uint32_t*)(app_address + 4)))();}
rbl_jump_stm32f2_f4.c (3.29 KB )
举报
胡雄相
2020-6-18 12:40:03
谢谢!
刚才自己调试解决了,在跳转前加一句关闭所有中断就可以了
看到你的程序也是有关闭中断的语句
之前裸机和ucos2都不用也没问题,看来是原来的程序还不够完善
举报
贵奂
2020-6-18 12:58:51
用jtag仿真看看?然后,你那个栈顶地址检查不合法的,至少应该给个死循环吧?
举报
陈键
2020-6-18 13:11:36
我公司的项目也是用FreeRTOS,前段时间也弄完了IAP在线升级,没发现你所说的问题,我用的单片机是STM32F051,IAP过程比103的复杂一些,需要手动拷贝向量表到SRAM的起始地址并作映射,但这些问题都解决了,祝你好运!
举报
更多回帖
