bootloader未修改 放入mcuimg.bin中
oob例程未修改 放入mcuimg1.bin中
能正常启动oob文件网页什么都正常就是sta模式就卡死
但是 通过网页设置为sta模式 程序就会卡死
while(uiConnect
timeoutCnt
((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus))))
//Turn RED LED On
GPIO_IF_LedOn(MCU_RED_LED_GPIO);
osi_Sleep(50);
//Turn RED LED Off
GPIO_IF_LedOff(MCU_RED_LED_GPIO);
osi_Sleep(50);
uiConnectTimeoutCnt++;
程序在这里死掉了
sta例程也是同样死掉了
能说明下为什么么?
[18:01:25] Begin Format operation.
[18:01:25] INFO: > Executing Operation: Connect
[18:01:27] INFO: setting break signal
[18:01:27] INFO: connection succeeded
[18:01:27] INFO: getting storage list
[18:01:28] INFO: > Executing Operation: Init
[18:01:28] INFO: reading version info
[18:01:28] INFO: DEVICE CC3200 ES1.32
[18:01:29] INFO: reading version info
[18:01:31] INFO: > Executing Operation: Format
[18:01:31] INFO: Erase storage SFLASH
[18:01:32] INFO: erase storage succeeded
[18:01:32] INFO: erase storage completed
[18:01:32] INFO: > Executing Operation: Disconnect
[18:01:32] Operation Format returned.
[18:01:35] Begin Program operation.
[18:01:35] INFO: > Executing Operation: Connect
[18:01:37] INFO: setting break signal
[18:01:38] INFO: detecting FTDI for device reset
[18:01:39] INFO: connection succeeded
[18:01:39] INFO: getting storage list
[18:01:39] INFO: > Executing Operation: Init
[18:01:39] INFO: reading version info
[18:01:39] INFO: DEVICE CC3200 ES1.32
[18:01:41] INFO: reading version info
[18:01:43] INFO: > Executing Operation: Program
[18:01:43] INFO: > File name: /sys/mcuimg.bin, Update: true, Erase: true
[18:01:43] INFO: > Erase File: /sys/mcuimg.bin
[18:01:43] INFO: erasing file "/sys/mcuimg.bin"
[18:01:43] INFO: deleting file "/sys/mcuimg.bin"
[18:01:43] INFO: erase file completed
[18:01:43] INFO: > Size of file = 13952
[18:01:43] INFO: > Update File: /sys/mcuimg.bin
[18:01:43] INFO: Downloading file "/sys/mcuimg.bin" with size 13952
[18:01:44] INFO:
New Token is 0x0
[18:01:44] INFO: Download complete
[18:01:44] INFO: Verifying Data...
[18:01:44] INFO: get file
[18:01:45] INFO: Done. Reading 13952 bytes
[18:01:45] INFO:
Verification OK
[18:01:46] INFO: > Updated Token value: 0x0
[18:01:46] INFO: > File name: /cert/ca.pem, Update: false, Erase: false
[18:01:46] INFO: > File name: /cert/client.pem, Update: false, Erase: false
[18:01:46] INFO: > File name: /cert/private.key, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/macadd.bin, Update: false, Erase: true
[18:01:46] INFO: > Erase File: /sys/macadd.bin
[18:01:46] INFO: erasing file "/sys/macadd.bin"
[18:01:46] INFO: deleting file "/sys/macadd.bin"
[18:01:46] INFO: erase file completed
[18:01:46] INFO: > File name: /sys/mode.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/ipcfg.ini, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/ap.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/devname.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/mdns.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/dhcpsrv.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/httpsrv.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/pref.net, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/smartconfigkeys.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/stacfg.ini, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/p2p.cfg, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/pmcfg.ini, Update: false, Erase: false
[18:01:46] INFO: > File name: /sys/mcuimg1.bin, Update: true, Erase: true
[18:01:46] INFO: > Erase File: /sys/mcuimg1.bin
[18:01:46] INFO: erasing file "/sys/mcuimg1.bin"
[18:01:46] INFO: deleting file "/sys/mcuimg1.bin"
[18:01:46] INFO: > Size of file = 48420
[18:01:46] INFO: > Update File: /sys/mcuimg1.bin
[18:01:46] INFO: Downloading file "/sys/mcuimg1.bin" with size 48420
[18:01:49] INFO:
New Token is 0x0
[18:01:49] INFO: Download complete
[18:01:49] INFO: Verifying Data...
[18:01:49] INFO: get file
[18:01:50] INFO: Done. Reading 48420 bytes
[18:01:50] INFO:
Verification OK
[18:01:51] INFO: > Updated Token value: 0x0
[18:01:51] INFO: > Executing Operation: Disconnect
[18:01:51] Operation Program returned.
[18:01:54] Begin ListFileSystem operation.
[18:01:55] INFO: > Executing Operation: Connect
[18:01:57] INFO: setting break signal
[18:01:58] INFO: detecting FTDI for device reset
[18:01:59] INFO: connection succeeded
[18:01:59] INFO: getting storage list
[18:01:59] INFO: > Executing Operation: Init
[18:01:59] INFO: reading version info
[18:01:59] INFO: DEVICE CC3200 ES1.32
[18:02:01] INFO: reading version info
[18:02:03] INFO: > Executing Operation: ListFileSystem
[18:02:03] INFO: extracting file system information...
[18:02:03] INFO: Serial Flash block size: 4096 bytes
[18:02:03] INFO: Serial Flash capacity: 2048 blocks
[18:02:03] INFO: file start size fail total size filename
[18:02:03] INFO: index block [BLKs] safe [BLKs]
[18:02:03] INFO: ----------------------------------------------------------------------------
[18:02:03] INFO: N/A 0 5 N/A 5 FATFS
[18:02:03] INFO: 0 15 4 yes 8 /sys/mcuimg.bin
[18:02:03] INFO: 4 5 5 yes 10 /tmp/phy.cal
[18:02:03] INFO: 6 23 12 yes 24 /sys/mcuimg1.bin
[18:02:03] INFO:
[18:02:03] INFO: Flash usage
[18:02:03] INFO: used space: 47 blocks
[18:02:03] INFO: free space: 2001 blocks
[18:02:03] INFO: memory hole: [47-2047]
[18:02:03] INFO: > Executing Operation: Disconnect
[18:02:03] Operation ListFileSystem returned.
