TI论坛
直播中
王刚
8年用户 1352经验值
私信 关注
[问答]
Kc积分校正增益是什么作用
/* ==================================================================================File name:       PID_REG3.H  (IQ version)                    =====================================================================================*/#ifndef __PIDREG3_H__#define __PIDREG3_H__typedef struct [  _iq  Ref;                           // Input: Reference input                                   _iq  Fdb;                           // Input: Feedback input                                   _iq  Err;                                // Variable: Error                                  _iq  Kp;                                // Parameter: Proportional gain                                  _iq  Up;                                // Variable: Proportional output                                   _iq  Ui;                                // Variable: Integral output                                   _iq  Ud;                                // Variable: Derivative output                                           _iq  OutPreSat;                 // Variable: Pre-saturated output                                  _iq  OutMax;                    // Parameter: Maximum output                                   _iq  OutMin;                    // Parameter: Minimum output                                  _iq  Out;                           // Output: PID output                                   _iq  SatErr;                        // Variable: Saturated difference                                  _iq  Ki;                            // Parameter: Integral gain                                  _iq  Kc;                             // Parameter: Integral correction gain                                  _iq  Kd;                         // Parameter: Derivative gain                                  _iq  Up1;                               // History: Previous proportional output                                  ] PIDREG3;                    typedef PIDREG3 *PIDREG3_handle;/*-----------------------------------------------------------------------------Default initalizer for the PIDREG3 object.-----------------------------------------------------------------------------*/                     #define PIDREG3_DEFAULTS [ 0,                                                    0,                                                    0,                                                    _IQ(1.3),                                    0,                                                    0,                                                    0,                                                    0,                                                    _IQ(1),                                            _IQ(-1),                                    0,                                                    0,                                                    _IQ(0.02),                                    _IQ(0.5),                                    _IQ(1.05),                                    0,        ]/*------------------------------------------------------------------------------         PID Macro Definition------------------------------------------------------------------------------*/#define PID_REG3_MACRO(v)        v.Err = v.Ref - v.Fdb;        /* Compute the error */                                                        v.Up= _IQmpy(v.Kp,v.Err);        /* Compute the proportional output */                        v.Ui= v.Ui + _IQmpy(v.Ki,v.Up) + _IQmpy(v.Kc,v.SatErr);        /* Compute the integral output */                                v.OutPreSat= v.Up + v.Ui;        /* Compute the pre-saturated output */                        v.Out = _IQsat(v.OutPreSat, v.OutMax, v.OutMin);                /* Saturate the output */                                                v.SatErr = v.Out - v.OutPreSat;                                                        /* Compute the saturate difference */                        v.Up1 = v.Up;        /* Update the previous proportional output */#define PID_REG3_POS_MACRO(v)        v.Err = v.Ref - v.Fdb;        /* Compute the error */                                                        if (v.Err >= _IQ(0.5))        v.Err -= _IQ(1.0);        /* roll in the error */                                                    else if (v.Err <= _IQ(-0.5))        v.Err += _IQ(1.0);        /* roll in the error */                                                    v.Up= _IQmpy(v.Kp,v.Err);        /* Compute the proportional output */                        v.Ui= v.Ui + _IQmpy(v.Ki,v.Up) + _IQmpy(v.Kc,v.SatErr);        /* Compute the integral output */                                v.Ud = _IQmpy(v.Kd,(v.Up - v.Up1));        v.OutPreSat= v.Up + v.Ui + v.Ud;                                                /* Compute the pre-saturated output */                        v.Out = _IQsat(v.OutPreSat, v.OutMax, v.OutMin);                /* Saturate the output */                                                v.SatErr = v.Out - v.OutPreSat;                                                        /* Compute the saturate difference */                        v.Up1 = v.Up;#endif // __PIDREG3_H__// Add the lines below if derivative output is needed following the integral update位置在ticontrolSUITElibsapp_libsmotor_controlmath_blocksv4.3/
在给出的文档中似乎没有对这个的说明(看大家用的这个,也打算用这个。把Kd设为0就是PI了吧)
1、Kc,积分校正增益,没明白是什么作用
2、这个是增量式PID吗?
3、SatErr,饱和差,好像是v->SatErr = v->Out - v->OutPreSat;,但不知道什么用
4、v.Ui= v.Ui + _IQmpy(v.Ki,v.Up) + _IQmpy(v.Kc,v.SatErr);也即是// Compute the integral output
v->Ui = v->Ui +v->Ki*v->Up + v->Kc*v->SatErr;其中的v->Kc*v->SatErr;怎么理解啊,为什么加上v->Ki*v->Up + v->Kc*v->SatErr,加上当前误差乘以Ki不就可以了吗?
5、// Compute the derivative output
v->Ud = v->Kd*(v->Up - v->Up1);计算微分的时候为什么用的是比例输出。
6、_iq换成了float32, _IQ(1.3)换成1.3也可以吧。想换成浮点型的。
谢谢
回帖(19)
王刚
2020-5-29 13:34:35
这个大家谁知道吗,不需要回答全部,回答下您知道的就可以,非常感谢。
举报
吴键洪
2020-5-29 13:45:10
你好!
      我是一个DSP的菜鸟不知理解的对不对,2你的这个算法好像不是增量式的PID,好像是位置式的PID,
Up= _IQmpy(v.Kp,v.Err),比例环节,Ui= v.Ui + _IQmpy(v.Ki,v.Up)积分环节,Ud = _IQmpy(v.Kd,(v.Up - v.Up1))微分环节,饱和差我也不是很清楚,但是位置式的PID由于积分一直在累加求和因此需要退饱和,具体怎么退饱和我没有接触过所以我说不清楚。Ud = v->Kd*(v->Up - v->Up1)这是微分环节离散化之后的公式,以上的三个PID都是经过离散化的,Kd(du/dt),离散化就是前后两个时间的差值,也就是Kd*(v->Up - v->Up1)。而增量式PID比位置式的多一步,增量式是前后两个时间位置PID的差值。不知我理解的对不对,仅供你参考!谢谢!
举报
王刚
2020-5-29 14:00:23
引用: Jayden888 发表于 2020-5-29 15:22
你好!
Up= _IQmpy(v.Kp,v.Err),比例环节,Ui= v.Ui + _IQmpy(v.Ki,v.Up)积分环节,Ud = _IQmpy(v.Kd,(v.Up - v.Up1))微分环节,饱和差我也不是很清楚,但是位置式的PID由于积分一直在累加求和因此需要退饱和,具体怎 ...
谢谢您的回答,不过_iq换成了float32, _IQ(1.3)换成1.3也可以吧。想换成浮点型的。
Ui= v.Ui + _IQmpy(v.Ki,v.Up)积分环节,这个是得出积分的输出,但是不应该是v.Ui +KI*Err吗,为什么是_IQmpy(v.Ki,v.Up),谢谢
举报
吴键洪
2020-5-29 14:13:49
您好!
关于这个问题,我也有疑问,我比较同意你的看法v.Ui +KI*Err,不知是不是这个PID中间还有其他的传递环节,因为我上面写的那个参考是最简单的数学模型,你的这个应该比较复杂点,所以我也没什么把握!我再查查资料,如果你弄明白了也请给我留言谢谢!
举报
更多回帖
