天线|RF射频
直播中
向可嘉
8年用户 208经验值
私信 关注
[问答]
nrf24l01接收调不通原因是什么?
手上有一对NRF24L01模块,但是调试时这一对模块都出现相同问题
我在调发射时修改了        nRF_WriteRegister(WRITE_REG+SETUP_RETR,0x00);
        nRF_WriteRegister(WRITE_REG+EN_AA,0x00);
          nRF_WriteRegister(WRITE_REG+EN_RXADDR,0x00)
返回正常(0X01);应该说发射没问题
问题是接收,我设置了SPI_RW_Reg(WRITE_REG + EN_AA, 0x00)关掉自动应答,接收端收不任何信号,如果把参数设置0X01打开自动应答,但是发送端没通电的情况下,接收端会有收到状态,缓存有0XFF的数据, 我现在都不知道是不是模块坏了,麻烦各位帮忙看下,另外关于SPI是模拟的但是用硬件的话都是这样情况
代码是这样的:
//ICC-AVR application builder : 2007-8-11 20:37:32
// Target : M16
// Crystal: 8.0000Mhz
#include
#include
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO          B4                //输入0
#define   Hign_24L01_MISO    ORTB |= (1 << PB4)
#define   Low_24L01_MISO     PORTB &= ~(1 << PB4)
#define   Read_24L01_MISO    INB & (1 << PB4)
//#define NRF24L01_MOSI         PB2              //输出1
#define   Hign_24L01_MOSI    ORTB |= (1 << PB2)
#define   Low_24L01_MOSI     PORTB &= ~(1 << PB2)
#define   Read_24L01_MOSI    INB & (1 << PB2)
//#define NRF24L01_CSN                     B7              //输出1
#define   Low_24L01_CSN     PORTB &= ~(1 << PB7)
#define   Hign_24L01_CSN           ORTB |= (1 << PB7)
//#define NRF24L01_SCK                  B6             //输出1
#define   Hign_24L01_SCK    ORTB |= (1 << PB6)
#define   Low_24L01_SCK     PORTB &= ~(1 << PB6)
#define   Read_24L01_SCK    INB & (1 << PB6);
//#define NRF24L01_CE                PB5              //输出1
#define   Hign_24L01_CE    PORTB |= (1 << PB5)
#define   Low_24L01_CE     PORTB &= ~(1 << PB5)
#define   Read_24L01_CE    PINB & (1 << PB5)
//#define  NRF24L01_IRQ     PB3               //输入
#define   Hign_NRF24L01_IRQ    PORTB |= (1 << PB3)
#define   Low_NRF24L01_IRQ     PORTB &= ~(1 << PB3)
#define   Read_NRF24L01_IRQ    PINB & (1 << PB3)
char TxBuf[32]=
0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,
0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,
char sta,count;
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH    5           // 5 uints TX address width
#define RX_ADR_WIDTH    5           // 5 uints RX address width
#define TX_PLOAD_WIDTH  32          // 20 uints TX payload
#define RX_PLOAD_WIDTH  32          // 20 uints TX payload
char  TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //本地地址
char  RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG        0x00          // 读寄存器指令
#define WRITE_REG       0x20         // 写寄存器指令
#define RD_RX_PLOAD     0x61          // 读取接收数据指令
#define WR_TX_PLOAD     0xA0          // 写待发数据指令
#define FLUSH_TX        0xE1         // 冲洗发送 FIFO指令
#define FLUSH_RX        0xE2          // 冲洗接收 FIFO指令
#define REUSE_TX_PL     0xE3          // 定义重复装载数据指令
#define NOP1             0xFF          // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG          0x00  // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA           0x01  // 自动应答功能设置
#define EN_RXADDR       0x02  // 可用信道设置
#define SETUP_AW        0x03  // 收发地址宽度设置
#define SETUP_RETR      0x04  // 自动重发功能设置
#define RF_CH           0x05  // 工作频率设置
#define RF_SETUP        0x06  // 发射速率、功耗功能设置
#define STATUS          0x07  // 状态寄存器
#define OBSERVE_TX      0x08  // 发送监测功能
#define CD              0x09  // 地址检测
#define RX_ADDR_P0      0x0A  // 频道0接收数据地址
#define RX_ADDR_P1      0x0B  // 频道1接收数据地址
#define RX_ADDR_P2      0x0C  // 频道2接收数据地址
#define RX_ADDR_P3      0x0D  // 频道3接收数据地址
#define RX_ADDR_P4      0x0E  // 频道4接收数据地址
#define RX_ADDR_P5      0x0F  // 频道5接收数据地址
#define TX_ADDR         0x10  // 发送地址寄存器
#define RX_PW_P0        0x11  // 接收频道0接收数据长度
#define RX_PW_P1        0x12  // 接收频道0接收数据长度
#define RX_PW_P2        0x13  // 接收频道0接收数据长度
#define RX_PW_P3        0x14  // 接收频道0接收数据长度
#define RX_PW_P4        0x15  // 接收频道0接收数据长度
#define RX_PW_P5        0x16  // 接收频道0接收数据长度
#define FIFO_STATUS     0x17  // FIFO栈入栈出状态寄存器设置
void Delay(int s);
void inerDelay_us(char n);
void init_NRF24L01(void);
char SPI_RW(char data);
char SPI_Read(char reg);
char SPI_RW_Reg(char reg, char value);
char SPI_Read_Buf(char reg, char *pBuf, char uchars);
char SPI_Write_Buf(char reg, char *pBuf, char uchars);
void SetRX_Mode(void);
char nRF24L01_RxPacket(char* rx_buf);
void nRF24L01_TxPacket(char * tx_buf);
void StartUART(void);
void R_S_Byte(char R_Byte);
void display();
//*****************************************长延时*****************************************
void Delay(int s)
        unsigned int i;
        for(i=0; i
        for(i=0; i
/*函数:uint SPI_RW(uint uchar)
/*功能:NRF24L01的SPI写时序
        char i,temp=0;
           for(i=0;i<8;i++) // output 8-bit
        if(data & 0x80)
                Hign_24L01_MOSI ;         // output 'uchar', MSB to MOSI
        else
                 Low_24L01_MOSI;
                data = (data << 1);           // shift next bit into MSB..
                temp<<=1;
                Hign_24L01_SCK ;                      // Set SCK high..
                if(PINB&0x10)temp++;                         // capture current MISO bit
                Low_24L01_SCK;                              // ..then set SCK low again
    return(temp);                             // return read uchar
/*函数:uchar SPI_Read(uchar reg)
/*功能:NRF24L01的SPI时序
        char reg_val;
        Low_24L01_CSN;                // CSN low, initialize SPI communication...
        SPI_RW(reg);            // Select register to read from..
        reg_val = SPI_RW(0);    // ..then read registervalue
        Hign_24L01_CSN;                // CSN high, terminate SPI communication
        return(reg_val);        // return register value
/*功能:NRF24L01读写寄存器函数
        char status;
        Low_24L01_CSN;                   // CSN low, init SPI transaction
        status = SPI_RW(reg);      // select register
        SPI_RW(value);             // ..and write value to it..
        Hign_24L01_CSN;                   // CSN high again
        return(status);            // return nRF24L01 status uchar
/*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
        int status1,uchar_ctr;
        Low_24L01_CSN;                                    // Set CSN low, init SPI tranaction
        status1 = SPI_RW(reg);                       // Select register to write to and read status uchar
        for(uchar_ctr=0;uchar_ctr
                pBuf[uchar_ctr] = SPI_RW(0);    //
        Hign_24L01_CSN;
        return(status1);                    // return nRF24L01 status uchar
/*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
        char status1,uchar_ctr;
        Low_24L01_CSN;             //SPI使能
        for(uchar_ctr=0; uchar_ctr
        SPI_RW(*pBuf++);
        Hign_24L01_CSN;           //关闭SPI
        return(status1);                      //
/*函数:void SetRX_Mode(void)
/*功能:数据接收配置
        Low_24L01_CE;
        //SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);                   // IRQ收发完成中断响应,16位CRC        ,主接收
        Hign_24L01_CE;
        Delay(1000);//注意不能太小
/*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
/*功能:数据读取后放如rx_buf接收缓冲区中
    char revale=0;
        sta=SPI_Read(STATUS);             // 读取状态寄存其来判断数据接收状况
        if(sta&0x40)                 // 判断是否接收到数据
            Low_24L01_CE;                         //SPI使能
                SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
                revale =1;                        //读取数据完成标志
        SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
        return revale;
/*函数:void nRF24L01_TxPacket(char * tx_buf)
/*功能:发送 tx_buf中数据
        Low_24L01_CE;                        //StandBy I模式
        SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
        SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);                          // 装载数据
//        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);                   // IRQ收发完成中断响应,16位CRC,主发送
        Hign_24L01_CE;                //置高CE,激发数据发送
        Delay(600);
/*NRF24L01初始化
        Low_24L01_CE;    // chip enable
        Hign_24L01_CSN;   // Spi disable
        Low_24L01_SCK;   // Spi clock line init high
        SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 写本地地址
        SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址
        SPI_RW_Reg(WRITE_REG + EN_AA, 0x00);      //  频道0自动        ACK应答允许,测试时为0关掉
        SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  允许接收地址只有频道0,如果需要多频道可以参考Page21
        SPI_RW_Reg(WRITE_REG + RF_CH,40);        //   设置信道工作为2.4GHZ,收发必须一致
        SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
        //SPI_RW_Reg(WRITE_REG + RX_PW_P0, 1);
        SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f);                   //设置发射速率为1MHZ,发射功率为最大值0dB
        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);                   // IRQ收发完成中断响应,16位CRC        ,主接收}
    Delay(6000);
void main()
        char i,RxBuf[1];
        DDRB=0xe4;
        DDRC=0xff;
        DDRA=0xFF;
        PORTA=0x01;
        PORTC=0x00;
        //StartUART();
    init_NRF24L01() ;SetRX_Mode();
        while(1)
                   if(nRF24L01_RxPacket(RxBuf))   //判断是否收到数据
                {PORTA|=0x02;//PA2口点亮LED状态灯
                PORTC|=RxBuf[0];//LED显示接收到的数据
回帖(1)
刘英
2020-5-6 10:45:51
参考下我们的例程试试吧.
举报
更多回帖
