TI论坛
直播中
余正成
7年用户 200经验值
私信 关注
[问答]
使用SampleDoorLock开启一个定时器来检测按键抢包没有抢出来的原因?
描述:
1、CC2530 非开发套件,使用 SampleDoorLock 作为协调器、SampleDoorLockController作用终端
2、终端(SampleDoorLockController)开启一个定时器来检测按键(100ms),例如:P1_5 ==1时,来发起Becon reques 请求并且可以入网(入网抓包如下图)
3、例如:P1_6 ==1时,来发送解锁命令,但是数据发来出来,抢包没有抢出来。debug能正常进入定时器检测,例程其他地方没有改动,请问问题出在那里呢?谢谢,代码如下:
if ( events &   SAMPLEDOORLOCK_wds )  [        osal_start_timerEx( zclSampleDoorLockController_TaskID, SAMPLEDOORLOCK_wds, 100 );   // zcl_EZModeAction ( EZMODE_ACTION_TIMED_OUT, NULL ); // EZ-Mode timed out    if(P1_6==1)    [    // increase PIN number    if ( giDoorLockScreenMode == DOORLOCK_PINMODE )    [      if ( giDoorLockPINColumnCount < 4 )      [        if ( giDoorLockPINCount > 8 )        [          giDoorLockPINCount = 0;        ]        else        [          giDoorLockPINCount++;        ]      ]    ]    // for all other modes, lock/unlock door    else    [      zclDoorLock_t cmd;      cmd.pPinRfidCode = aiDoorLockPIN;      static bool locked = TRUE;      giDoorLockScreenMode = DOORLOCK_MAINMODE;      if ( locked )      [        zclClosures_SendDoorLockUnlockDoor( SAMPLEDOORLOCKCONTROLLER_ENDPOINT, &zclSampleDoorLockController_DstAddr, &cmd, false, zclSampleDoorLockControllerSeqNum++ );        locked = FALSE;      ]      else      [        zclClosures_SendDoorLockLockDoor( SAMPLEDOORLOCKCONTROLLER_ENDPOINT, &zclSampleDoorLockController_DstAddr, &cmd, false, zclSampleDoorLockControllerSeqNum++ );        locked = TRUE;      ]    ]    ]    if(P1_5==1)    [     if ( ( giDoorLockScreenMode == DOORLOCK_MAINMODE ) ||         ( giDoorLockScreenMode == DOORLOCK_HELPMODE ) )    [      giDoorLockScreenMode = DOORLOCK_MAINMODE;#ifdef ZCL_EZMODE      [        zclEZMode_InvokeData_t ezModeData;        static uint16 clusterIDs[] = [ ZCL_CLUSTER_ID_CLOSURES_DOOR_LOCK ];   // only bind on the on/off cluster        // Invoke EZ-Mode        ezModeData.endpoint = SAMPLEDOORLOCKCONTROLLER_ENDPOINT; // endpoint on which to invoke EZ-Mode        if ( ( zclSampleDoorLockController_NwkState == DEV_ZB_COORD ) ||             ( zclSampleDoorLockController_NwkState == DEV_ROUTER )   ||             ( zclSampleDoorLockController_NwkState == DEV_END_DEVICE ) )        [          ezModeData.onNetwork = TRUE;      // node is already on the network        ]        else        [          ezModeData.onNetwork = FALSE;     // node is not yet on the network        ]        ezModeData.initiator = TRUE;            // DoorLock Controller is an initiator        ezModeData.numActiveInClusters = 0;        ezModeData.pActiveInClusterIDs = NULL;        ezModeData.numActiveOutClusters = 1;    // active output cluster        ezModeData.pActiveOutClusterIDs = clusterIDs;        zcl_InvokeEZMode( &ezModeData );#ifdef LCD_SUPPORTED        HalLcdWriteString( "EZMode", HAL_LCD_LINE_2 );#endif      ]// NOT ZCL_EZMODE, Use EndDeviceBind#else      [        zAddrType_t dstAddr;        HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );        // Initiate an End Device Bind Request, this bind request will        // only use a cluster list that is important to binding.        dstAddr.addrMode = afAddr16Bit;        dstAddr.addr.shortAddr = 0;   // Coordinator makes the match        ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),                              SAMPLEDOORLOCKCONTROLLER_ENDPOINT,                              ZCL_HA_PROFILE_ID,                              0, NULL,   // No incoming clusters to bind                              ZCLSAMPLEDOORLOCKCONTROLLER_BINDINGLIST, bindingOutClusters,                              TRUE );      ]#endif // ZCL_EZMODE    ]    ]    return ( events ^   SAMPLEDOORLOCK_wds );  ]
回帖(1)
李果
2020-4-28 10:50:50
如果定义了ZCL_EZMODE的话,首先需要进行两个设备在EZ_MODE下绑定的过程。
确保SampleDoorLock和SampleDoorLockController都处于EZ_MODE的状态下。
另外在一般应用中SampleDoorLock是实际的锁,是低功耗设备,所以是zigbee网络里的end device
SampleDoorLockController是控制端,一般可能是协调器等设备。
举报
更多回帖
