管脚该怎么复用啊,代码里面是这样的
/* Performing the Pin Multiplexing for SPI0. */
SPIPinMuxSetup(0);
求指点
#include
#include "soc_C6748.h"
#include "hw_psc_C6748.h"
#include "lcdkC6748.h"
#include "uart.h"
#include "spi.h"
#include "psc.h"
#include "interrupt.h"
#include "uartStdio.h"
** INTERNAL MACRO DEFINITIONS
/* value to configure SMIO,SOMI,CLK and CS pin as functional pin */
#define SIMO_SOMI_CLK_CS 0x00000E01
#define CHAR_LENGTH 0x8
** INTERNAL FUNCTION PROTOTYPES
static void SPIConfigDataFmtReg(unsigned int dataFormat);
static void SpiTransfer(void);
static void SetUpInt(void);
static void SetUpSPI(void);
static void GetStatusCommand(void);
static void ResetCommand(void);
void SPIIsr(void);
** INTERNAL VARIABLE DEFINITIONS
volatile unsigned int flag = 1;
unsigned int tx_len;
unsigned int rx_len;
unsigned char vrf_data[260];
unsigned char tx_data[260];
volatile unsigned char rx_data[260];
unsigned char *p_tx;
volatile unsigned char *p_rx;
volatile unsigned char StatusResponseMessage[16];
** INTERNAL FUNCTION DEFINITIONS
int main(void)
/* Waking up the SPI1 instance. */
PSCModuleControl(SOC_PSC_0_REGS, HW_PSC_SPI0, PSC_POWERDOMAIN_ALWAYS_ON,
PSC_MDCTL_NEXT_ENABLE);
/* Initializing the UART instance for serial communication. */
UARTStdioInit();
UARTPuts("Welcome to StarterWare SPI application.rnrn", -1);
UARTPuts("Here the SPI controller on the SoC communicates with", -1);
UARTPuts(" the Fingerprint Sensor present on the LCDK.rnrn", -1);
SPIPinMuxSetup(0);
** Using the Chip Select(CS) 0 pin of SPI0 to communicate with the Fingerprint Sensor.
SPI0CSPinMuxSetup(0);
/* Enable use of SPI1 interrupts. */
SetUpInt();
/* Configuring and enabling the SPI1 instance. */
SetUpSPI();
/* Issue a Reset to the Fingerprint Sensor */
// ResetCommand();
// UARTPuts("Attempting to Reset the Fingerprint Sensor.rnrn", -1);
// /* Read the Status of the Fingerprint Sensor */
// GetStatusCommand();
// if(StatusResponseMessage[11] == 0x48)
// UARTPuts("Fingerprint Sensor Successfully Reset.rnrn", -1);
// else
// UARTPuts("ERROR: Fingerprint Sensor Reset Attempt Unsuccessful.rnrn", -1);
tx_data[0] = 0x00;
tx_data[1] = 0x01;
tx_data[2] = 0x02;
tx_data[3] = 0x03;
tx_data[4] = 0x04;
tx_data[5] = 0x05;
tx_data[6] = 0x06;
tx_data[7] = 0x07;
tx_data[8] = 0x08;
tx_data[9] = 0x09;
tx_data[10] = 0x0a;
tx_data[11] = 0x0b;
tx_data[12] = 0x0c;
tx_data[13] = 0x0d;
tx_data[14] = 0x0e;
tx_data[15] = 0x0f;
tx_data[16] = 0x10;
tx_data[17] = 0x11;
tx_data[18] = 0x12;
tx_data[19] = 0x13;
tx_data[20] = 0x14;
tx_data[21] = 0x15;
tx_data[22] = 0x16;
tx_len = 23;
rx_len = 23;
for(;;)
SpiTransfer();
// for(; i<100000; i++);
** Configures ARM interrupt controller to generate SPI interrupt
// Setup the ARM or DSP interrupt controller
#ifdef _TMS320C6X
// Initialize the DSP interrupt controller
IntDSPINTCInit();
// Register the ISR in the vector table
IntRegister(C674X_MASK_INT4, SPIIsr);
// Map system interrupt to the DSP maskable interrupt
IntEventMap(C674X_MASK_INT4, SYS_INT_SPI0_INT);
// Enable the DSP maskable interrupt
IntEnable(C674X_MASK_INT4);
IntEventSet(SYS_INT_SPI0_INT);
// Enable DSP interrupts globally
IntGlobalEnable();
#else
/* Initialize the ARM Interrupt Controller.*/
IntAINTCInit();
/* Register the ISR in the Interrupt Vector Table.*/
IntRegister(SYS_INT_SPINT1, SPIIsr);
/* Set the channnel number 2 of AINTC for system interrupt 56.
* Channel 2 is mapped to IRQ interrupt of ARM9.
IntChannelSet(SYS_INT_SPINT1, 2);
/* Enable the System Interrupts for AINTC.*/
IntSystemEnable(SYS_INT_SPINT1);
/* Enable IRQ in CPSR.*/
IntMasterIRQEnable();
/* Enable the interrupts in GER of AINTC.*/
IntGlobalEnable();
/* Enable the interrupts in HIER of AINTC.*/
IntIRQEnable();
#endif
//** Configures SPI Controller
unsigned char cs = 0x01;//0x04;******************
unsigned char dcs = 0x01;//0x04;******************
unsigned int val = SIMO_SOMI_CLK_CS;
SPIReset(SOC_SPI_0_REGS);
SPIOutOfReset(SOC_SPI_0_REGS);
SPIModeConfigure(SOC_SPI_0_REGS, SPI_MASTER_MODE);
SPIClkConfigure(SOC_SPI_0_REGS, 150000000, 1000000, SPI_DATA_FORMAT0);//SCLK原为1M
SPIPinControl(SOC_SPI_0_REGS, 0, 0, &val);
SPIDefaultCSSet(SOC_SPI_0_REGS, dcs);
/* Configures SPI Data Format Register */
SPIConfigDataFmtReg(SPI_DATA_FORMAT0);
/* Selects the SPI Data format register to used and Sets CSHOLD
* to assert CS pin(line)
SPIDat1Config(SOC_SPI_0_REGS, (SPI_CSHOLD | SPI_DATA_FORMAT0), cs);
/* map interrupts to interrupt line INT1 */
SPIIntLevelSet(SOC_SPI_0_REGS, SPI_RECV_INTLVL | SPI_TRANSMIT_INTLVL);
/* Enable SPI communication */
SPIEnable(SOC_SPI_0_REGS);
//** Configures Data Format register of SPI
/* Configures the polarity and phase of SPI clock */
SPIConfigClkFormat(SOC_SPI_0_REGS,(SPI_CLK_POL_HIGH | SPI_CLK_INPHASE),dataFormat);//SPI_CLK_POL_HIGH SPI_CLK_OUTOFPHASE
//SPIConfigClkFormat(SOC_SPI_0_REGS,(SPI_CLK_POL_LOW | SPI_CLK_INPHASE),dataFormat);
/* Configures SPI to transmit MSB bit First during data transfer */
SPIShiftM***First(SOC_SPI_0_REGS, dataFormat);
/* Sets the Charcter length */
SPICharLengthSet(SOC_SPI_0_REGS, CHAR_LENGTH, dataFormat);
//** Enables SPI Transmit and Receive interrupt.** Deasserts Chip Select line.
p_tx = &tx_data[0];
p_rx = &rx_data[0];
SPIIntEnable(SOC_SPI_0_REGS, (SPI_RECV_INT | SPI_TRANSMIT_INT));
// while(flag);
// flag = 1;
/* Deasserts the CS pin(line) */
SPIDat1Config(SOC_SPI_0_REGS, SPI_DATA_FORMAT0, 0x01);
//** Data transmission and receiption SPIIsr
void SPIIsr(void)
unsigned int intCode = 0;
IntEventClear(SYS_INT_SPI0_INT);
intCode = SPIInterruptVectorGet(SOC_SPI_0_REGS);
while (intCode)
if(intCode == SPI_TX_BUF_EMPTY)
tx_len--;
SPITransmitData1(SOC_SPI_0_REGS, *p_tx);
p_tx++;
if (!tx_len)
tx_len = 23;
SPIIntDisable(SOC_SPI_0_REGS, SPI_TRANSMIT_INT);
break;
if(intCode == SPI_RECV_FULL)
rx_len--;
*p_rx = (char)SPIDataReceive(SOC_SPI_0_REGS);
p_rx++;
if (!rx_len)
flag = 0;
SPIIntDisable(SOC_SPI_0_REGS, SPI_RECV_INT);
管脚该怎么复用啊,代码里面是这样的
SPIPinMuxSetup(0);
求指点
#include
#include "uart.h"
#include "spi.h"
#include "psc.h"
void SPIIsr(void);
int main(void)
UARTStdioInit();
SPIPinMuxSetup(0);
SetUpInt();
SetUpSPI();
// ResetCommand();
// else
tx_data[0] = 0x00;
tx_data[1] = 0x01;
tx_data[2] = 0x02;
tx_data[3] = 0x03;
tx_data[4] = 0x04;
tx_data[5] = 0x05;
tx_data[6] = 0x06;
tx_data[7] = 0x07;
tx_data[8] = 0x08;
tx_data[9] = 0x09;
tx_data[10] = 0x0a;
tx_data[11] = 0x0b;
tx_data[12] = 0x0c;
tx_data[13] = 0x0d;
tx_data[14] = 0x0e;
tx_data[15] = 0x0f;
tx_data[16] = 0x10;
tx_data[17] = 0x11;
tx_data[18] = 0x12;
tx_data[19] = 0x13;
tx_data[20] = 0x14;
tx_data[21] = 0x15;
tx_data[22] = 0x16;
tx_len = 23;
rx_len = 23;
for(;;)
SpiTransfer();
#ifdef _TMS320C6X
IntDSPINTCInit();
IntGlobalEnable();
#else
IntAINTCInit();
IntGlobalEnable();
IntIRQEnable();
#endif
p_tx = &tx_data[0];
p_rx = &rx_data[0];
// while(flag);
// flag = 1;
void SPIIsr(void)
while (intCode)
tx_len--;
p_tx++;
if (!tx_len)
tx_len = 23;
break;
rx_len--;
p_rx++;
if (!rx_len)
flag = 0;
举报
