嵌入式学习小组
直播中
杨斌
8年用户 142经验值
私信 关注
UCOSII不支持FPU功能
已经按例程全改了,运行程序还是进入HardFault.
1、------------------------------------------------------------
PendSV_Handler
    CPSID   I                                                   ; Prevent interruption during context switch
    MRS     R0, PSP                                             ; PSP is process stack pointer 如果在用PSP堆栈,则可以忽略保存寄存器,参考CM3权威中的双堆栈-白菜注
    CBZ     R0, PendSV_Handler_Nosave                      ; Skip register save the first time
;Is the task using the FPU context? If so, push high vfp registers.
TST  R14, #0x10
IT   EQ
VSTMDBEQ R0!, {S16-S31}
    SUBS    R0, R0, #0x20                                       ; Save remaining regs r4-11 on process stack
    STM     R0, {R4-R11}
    LDR     R1, =OSTCBCur                                       ; OSTCBCur->OSTCBStkPtr = SP;
    LDR     R1, [R1]
    STR     R0, [R1]                                            ; R0 is SP of process being switched out
        ; At this point, entire context of process has been saved
    PUSH    {R14}                                               ; Save LR exc_return value
    LDR     R0, =OSTaskSwHook                                   ; OSTaskSwHook();
    BLX     R0
    POP     {R14}
    LDR     R0, =OSPrioCur                                      ; OSPrioCur = OSPrioHighRdy;
    LDR     R1, =OSPrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R0, =OSTCBCur                                       ; OSTCBCur  = OSTCBHighRdy;
    LDR     R1, =OSTCBHighRdy
    LDR     R2, [R1]
    STR     R2, [R0]
    LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdy->OSTCBStkPtr;
    LDM     R0, {R4-R11}                                        ; Restore r4-11 from new process stack
    ADDS    R0, R0, #0x20
TST  R14, #0x10
IT   EQ
VLDMIAEQ R0!, {S16-S31}
MSR     PSP, R0                                             ; Load PSP with new process SP
    ORR     LR, LR, #0x04                                       ; Ensure exception return uses process stack
    CPSIE   I
    BX      LR                                                  ; Exception return will restore remaining context
NOP
    end
2、------------------------------------------------------------
OS_STK *OSTaskStkInit (void (*task)(void *p_arg), void *p_arg, OS_STK *ptos, INT16U opt)
    OS_STK *stk;
    (void)opt;                                   /* 'opt' is not used, prevent warning                 */
    stk       = ptos;                            /* Load stack pointer                                 */
#if (__FPU_PRESENT==1)&&(__FPU_USED==1)
*(--stk) = (INT32U)0x00000000L; //No Name Register
*(--stk) = (INT32U)0x00001000L; //FPSCR
*(--stk) = (INT32U)0x00000015L; //s15
*(--stk) = (INT32U)0x00000014L; //s14
*(--stk) = (INT32U)0x00000013L; //s13
*(--stk) = (INT32U)0x00000012L; //s12
*(--stk) = (INT32U)0x00000011L; //s11
*(--stk) = (INT32U)0x00000010L; //s10
*(--stk) = (INT32U)0x00000009L; //s9
*(--stk) = (INT32U)0x00000008L; //s8
*(--stk) = (INT32U)0x00000007L; //s7
*(--stk) = (INT32U)0x00000006L; //s6
*(--stk) = (INT32U)0x00000005L; //s5
*(--stk) = (INT32U)0x00000004L; //s4
*(--stk) = (INT32U)0x00000003L; //s3
*(--stk) = (INT32U)0x00000002L; //s2
*(--stk) = (INT32U)0x00000001L; //s1
*(--stk) = (INT32U)0x00000000L; //s0
#endif
                                                 /* Registers stacked as if auto-saved on exception    */
    *(stk)    = (INT32U)0x01000000L;             /* xPSR                                               */
    *(--stk)  = (INT32U)task;                    /* Entry Point                                        */
    *(--stk)  = (INT32U)OS_TaskReturn;           /* R14 (LR) (init value will cause fault if ever used)*/
    *(--stk)  = (INT32U)0x12121212L;             /* R12                                                */
    *(--stk)  = (INT32U)0x03030303L;             /* R3                                                 */
    *(--stk)  = (INT32U)0x02020202L;             /* R2                                                 */
    *(--stk)  = (INT32U)0x01010101L;             /* R1                                                 */
    *(--stk)  = (INT32U)p_arg;                   /* R0 : argument                                      */
*(--stk) = (INT32U)0x00000031L; //s31
*(--stk) = (INT32U)0x00000030L; //s30
*(--stk) = (INT32U)0x00000029L; //s29
*(--stk) = (INT32U)0x00000028L; //s28
*(--stk) = (INT32U)0x00000027L; //s27
*(--stk) = (INT32U)0x00000026L; //s26
*(--stk) = (INT32U)0x00000025L; //s25
*(--stk) = (INT32U)0x00000024L; //s24
*(--stk) = (INT32U)0x00000023L; //s23
*(--stk) = (INT32U)0x00000022L; //s22
*(--stk) = (INT32U)0x00000021L; //s21
*(--stk) = (INT32U)0x00000020L; //s20
*(--stk) = (INT32U)0x00000019L; //s19
*(--stk) = (INT32U)0x00000018L; //s18
*(--stk) = (INT32U)0x00000017L; //s17
*(--stk) = (INT32U)0x00000016L; //s16
#endif
                                                /* Remaining registers saved on process stack         */
    *(--stk)  = (INT32U)0x11111111L;             /* R11                                                */
    *(--stk)  = (INT32U)0x10101010L;             /* R10                                                */
    *(--stk)  = (INT32U)0x09090909L;             /* R9                                                 */
    *(--stk)  = (INT32U)0x08080808L;             /* R8                                                 */
    *(--stk)  = (INT32U)0x07070707L;             /* R7                                                 */
    *(--stk)  = (INT32U)0x06060606L;             /* R6                                                 */
    *(--stk)  = (INT32U)0x05050505L;             /* R5                                                 */
    *(--stk)  = (INT32U)0x04040404L;             /* R4                                                 */
    return (stk);
3、keil环境配置和FPU功能也选了
帮帮我吧!!!!!!!!!!!!!!!!!!!
回帖(7)
刘锦
2020-3-11 07:59:33
8字节对齐,有几个地方要改
举报
高文利
2020-3-11 08:19:14
凌流浪
2020-3-11 08:32:42
你的参考我也看了,没有发现不同,能具体告诉要改哪里吗? 万分感谢!!!
举报
李琳
2020-3-11 08:47:03
举报
更多回帖
