FPGA开发
本文和设计代码由
FPGA爱好者小梅哥编写,未经作者许可,本文仅允许网络
论坛复制转载,且转载时请标明原作者。
- 关于自定义IP
- 1、接口
- a、全局信号 时钟(Clk),复位(reset_n)
- b、avalon mm slave
- 地址(as_address)
- 片选(as_chipselect /as_chipselect_n)
- 写请求(as_write / as_write_n)
- 写数据(as_writedata(按照字节对齐,8/16/32位位宽)
- 读请求(as_read / as_read_n)
- 读数据(as_readdata)(按照字节对齐,8/16/32位位宽)
- 等待信号(as_waitrequest / as_waitrequest_n)
- 读数据有效信号(as_data_valid)
- 中断请求(irq / irq_n)
- c、导出信号,导出到NIOS 系统顶层,分配到IO,或者连接到Qsys系统以外的逻辑
- 2、内部寄存器和线网的定义
- 数据寄存器(读/写)
- 状态寄存器(IP运行状态、数据状态……)
- 控制寄存器
- 中断屏蔽寄存器
- 用户自定义寄存器
- 3、Avalon总线对寄存器的读写
- //写入数据
- always@(posedge clk or negedge reset_n)
- if(!reset_n)
- channel <= 3'd0;
- else if(as_chipselect && as_write && (as_address == 1))
- channel <= as_writedata[2:0];
- //写指定地址实现相应功能,不考虑写入值
- if(!reset_n)
- control <= 1'd0;
- else if(as_chipselect && as_write && (as_address == 3))
- control <= 1'd1;
- else
- control <= 1'd0;
- //读寄存器逻辑
- if(!reset_n)
- as_readdata <= 16'd0;
- else if(as_chipselect && as_read)begin
- case(as_address)
- 0:as_readdata <= {4'd0, data};
- 1:as_readdata <= {13'd0, channel};
- 2:as_readdata <= {8'd0, freq_sclk};
- 4:as_readdata <= {15'd0, irqmask};
- 5:as_readdata <= {14'd0, status};
- default:as_readdata <= 16'd0;
- endcase
- end
- 4、用户逻辑对寄存器的赋值
- if(!reset_n)
- status[0] <= 1'd0;
- else if(Conv_Done)
- status[0] <= 1'b1;
- else if(as_chipselect && as_read && (as_address == 0))
- status[0] <= 1'b0;
- if(!reset_n)
- status[1] <= 1'd0;
- else if(ADC_State)
- status[1] <= 1'b1;
- else
- status[1] <= 1'b0;
更多回帖
