MTK平台
部分log信息如下:
7.436655] <0>.(3)[302:camerahalserver][Camera-ISP][ISP_release]+ Curr UserCount(1->0), (process, pid, tgid)=(camerahalserver, 302, 302), last user
[ 7.436671] <0>.(3)[302:camerahalserver][Camera-ISP][ISP_EnableClock]En(0),g_EnableClkCnt(1)
[ 7.501142] <0>.(3)[319:rpmb_svc]RPMB_WRITECOUNTER fail
[ 7.520059] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=16
[ 7.521156] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_open
[ 7.521998] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_close
[ 7.522763] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=0
[ 7.523693] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_open
[ 7.524539] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_close
[ 7.525277] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=0
[ 7.528489] <0>.(0)[388:HwBinder:232_1]Btcvsd_Loopback_Control_Get = 0
[ 7.792661] <1>.(1)[325:mtk_wmtd][WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(319, 792) ok
[ 7.802927] <3>.(3)[319:rpmb_svc]RPMB_WRITECOUNTER fail
[ 7.982720] <2>.(2)[401:bootanimation]Dump cpuinfo
[ 8.009016] <1>.(1)[325:mtk_wmtd][WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(178, 915) ok
[ 8.021307] <0>.(0)[325:mtk_wmtd][WMT-IC][E]mtk_wcn_soc_sw_init(1221):bt_tssi_from_wifi=0, bt_tssi_target=0
[ 8.049872] <0>.(0)[229:main]BOOTPROF: 8049.871095:Zygote:Preload Start
[ 8.104628] <1>.(1)[319:rpmb_svc]RPMB_WRITECOUNTER fail
[pmic6392_init] Preloader Start..................
[pmic6392_init] PMIC CHIP Code = 0x2092
[pmic6392_init] Debug Status: Reg[0x7A]=0x0
[pmic6392_init] Debug Status: Reg[0x7C]=0x20
pl pmic powerkey Press
[pmic6392_init] powerKey = 1
[pmic6392_init] is USB in = 0xB003
[pmic6392_init] Reg[0x11A]=0x7B
[pmic6392_init] Reg[0x136]=0x1
[pmic_buck_oc_enable] MT6392_BUCK_OC_CON0 0x258 = 0x6
[pmic_buck_oc_enable] Clear Buck OC Flag, MT6392_BUCK_OC_CON0 0x258 = 0x0
[pmic_buck_oc_enable] Enable Buck OC shutdown function...
[pmic_ldo_cali_sw_bonding] Done...................
[pmic6392_init] Reg[0x70]=0x52
[auxadc_hw_init] Preloader Start..................
[pmic6392_init] Done...................
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip_ver[1]
回帖(1)
2020-1-7 15:53:55
是不是EMMC没解锁的问题
是不是EMMC没解锁的问题
举报
更多回帖
