在公式框中:设置objOutlook = CreateObject(“Outlook.Application”);一般规则是GetObject获取对象的运行实例,而CreateObject创建它(或它的新实例)。
有* * ispotential滥用创建,所以你总是可以先尝试GetObject,如果Get失败则使用useCreateObject。如果你从acontainer文件中获取一个对象,语义会有所不同:GetObject可以做到这一点而Create不能,所以
只有调用toGetObject来创建服务器的多个实例是不可能的。-SHAWN ----您目前订阅vrf为:r***@soco.agilent.com要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists”。
it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@it.lists.it.agilent.com“。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。
以上来自于谷歌翻译
以下为原文
In a formula box:
Set objOutlook = CreateObject("Outlook.Application");
The general rule is that GetObject gets a running instance of an object,
while CreateObject creates it (or a new instance of it). There *is* the
potential to misuse create, so you can always try GetObject first and use
CreateObject if Get fails.
The semantics are a bit different if you're getting an object from a
container document: GetObject can do this and Create can't, so there's no
possibility of creating multiple instances of the server with only calls to
GetObject.
-SHAWN-
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
以上来自于谷歌翻译
以下为原文
In a formula box:
GetObject.
-SHAWN-
举报
