您好AllI已开始使用7.5版本。
当我使用运行时为7.5版本的安全文件(vxe)时,当文件超过8个字符时,我看不到整个文件名;
它只显示文件名的一部分~~符号dos do。
我对预览版本中的这种行为并不熟悉,看到文件名对我来说非常重要因为我们正在使用少量版本,这可能会导致错误。我的第二个问题涉及Excel,我有
一个程序,用大量的excel程序,当我想关闭所有这些与CloseAllWorkBooks似乎它不会关闭它们,当我尝试打开文件或用其他名称保存它不会
允许我。我打开任务管理器,因为有一些开放的Excel工艺。
我已经杀了这些进程,然后一切都继续,那么我应该怎么做,我怎么能提供不再那么当前的excel工作簿将作为打开的进程打开。
ÂRegardsArieFainbrun---要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。
要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。
要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。
在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。
以上来自于谷歌翻译
以下为原文
Hi All
I have started working with 7.5 version. When I’m using secured files (vxe) with run time 7.5 version,
I don’t see the whole file name when the file has more then 8 characters; it shows only a part of the file name with ~ sign
Like dos do. I’m not familiar with this behavior from the previews version, and it’s very important for me to see the file name
Since we are working with few version, and it may cause mistakes.
My second question concern to Excel, I have a program that dills with a lot of excel programs, when I want to close all of them
With CloseAllWorkBooks it seems that it doesn’t close them, and when I try to open the file or save it with other name it doesn’t allows me.
I open the task manager as there were a few open excel process. I have killed these process and then everything continue as well,
So what should I do, and how can I provide that no more then current excel workbook will be opened as opened process.
Â
Â
Â
Regards
Arie Fainbrun
Â
To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@agilent.com".
If you need help with the mailing list send a message to
"owner-vrf@it.lists.it.agilent.com".
Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
您好AllI已开始使用7.5版本。
以上来自于谷歌翻译
以下为原文
Hi All
Â
Â
Â
Regards
Arie Fainbrun
Â
举报
