巴里,谢谢你的回复,我很感激。
它证实了我在正确的轨道上。
我昨晚发现使用ListView的UF是错误的,但我没有注意到它,因为我在之前的使用中在UF上留下了一个错误引脚。
从那时起,事情似乎在表现自己,但我想在喊Eureka之前再多检查一下。再次感谢,-----原始信息-----来自:Barrie Walden [mailto:bwalden@whoi.edu]发送:
2001年11月13日星期二下午2:45到:Mohrenweiser,AnthonyCc:vrf@lvld.agilent.com主题:Re:vrf Active-X列表视图导致大量文件臃肿!嗨Anthony,我一直生活在这个问题上很长一段时间 -
它难以置信的痛苦!
需要注意的一点是,如果您的代码正常退出(不是错误退出),您应该能够预防它。
如果即使正常退出也有问题,可以通过稍微改变代码来完成某些操作。
在这个主题上有一些旧消息,我将在今天晚些时候寻找(帮助任何人?)。
我也知道如果关闭调试版本,你可能会做得更好。不幸的是,开发需要调试器并且可能存在错误。这意味着程序膨胀有时会成为一个问题。
因为这个,我从来没有运行我正在积极编辑的代码副本 - 我总是制作副本并运行它。
就像我说的 - 多么痛苦!
尽管如此,我们可以比其他人编译更快.Barriewhoi -------------------------------------
--------------------------------这是由Majordomo管理的“vrf”maillist。
要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。
订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.---
以上来自于谷歌翻译
以下为原文
Barrie,
Thanks for your reply, I appreciate it. It confirms that I am on the right
track. I found last night that the UF with the ListView was erroring, but I
hadn't noticed it because I had left an error pin on the UF in a previous
session. Since then things seem to be behaving themselves, but I wanted to
do some more checking before shouting Eureka.
Thanks again,
-----Original Message-----
Sent: Tuesday, November 13, 2001 2:45 PM
To: Mohrenweiser, Anthony
Cc:
Subject: Re: vrf Active-X List View causing massive file bloat!
Hi Anthony,
I have been living with this problem for quite awhile - its an
incredible pain! One thing to note is that you should be able to
prevent it if your code exits normally (not an error exit). If you have
the problem even with a normal exit, something can probably be done by
changing your code slightly. There are some old messages on this
subject which I will look for later today (help anybody?). I also
understand that you might do better if you turn off the debugger
options.
Unfortunately, development needs the debugger and errors are likely.
This means program bloat is going to be a problem sometime. Because of
this, I never run the copy of the code I am actively editing - I always
make a copy and run it instead. Like I said - what a pain! Still, we
can make a copy faster than others can compile.
Barrie
whoi
This is the "vrf" maillist, managed by Majordomo. To send messages to
this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
unsubscriptions are done through the address "vrf-request@lvld.agilent.com".
If you need details, just send a message containing the text "help"
to "vrf-request@lvld.agilent.com".
巴里,谢谢你的回复,我很感激。
它证实了我在正确的轨道上。
它难以置信的痛苦!
就像我说的 - 多么痛苦!
以上来自于谷歌翻译
以下为原文
Barrie,
Thanks again,
Cc:
Hi Anthony,
options.
Barrie
whoi
举报
