我可以使用一些帮助...我有一个负载控制功率计。
为了命令它将数据发送到我的计算机,我需要给它IP地址,然后是/KW.htm或/HP.htm。
例如,如果我在我的专用网络上的Internet Explorer中键入URL:http://123.321.456.12/KW.htm。
然后它“转到其内部网页”并在网页上显示结果为52.如何设置VEE以发出Web命令http: xxx.xxx.xxx.xxxcommand.htm,然后读取结果?谢谢!
Larryescaloni_grp@yahoo.com留在知道。
脉冲在新的Yahoo.com上。
一探究竟。
 你是雅虎吗?
加入。
你被邀请尝试新的雅虎!
邮件.---您目前订阅vrf为:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。
取消订阅会发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。
以上来自于谷歌翻译
以下为原文
I could use some help ...
I have a load controls Power meter. In order to command it to send me data to my computer, I need to give it the IP address followed by the /KW.htm or /HP.htm.
For example, if I type the URL in Internet Explorer on my private network:
http://123.321.456.12/KW.htm. Then it "goes to its internal webpage" and shows the result on the webpage as 52.
How can I setup VEE to issue the web command http:xxx.xxx.xxx.xxxcommand.htm, and then read the result?
THANKS !
Larry
Stay in the know. Pulse on the new Yahoo.com. Check it out. Do you Yahoo!?
Get on board. You're invited to try the new Yahoo! Mail.---You are currently subscribed to vrf as: [email=r***@soco.agilent.comTo]r***@soco.agilent.comTo[/email] subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
脉冲在新的Yahoo.com上。
一探究竟。
 你是雅虎吗?
加入。
你被邀请尝试新的雅虎!
以上来自于谷歌翻译
以下为原文
THANKS !
Larry
举报
