传感技术
400万+工程师在用
400万+工程师在用
china
12年用户 596经验值
私信 关注
ht1621 c驱动程序
2008-7-7 17:38
ht1621 c驱动程序
lcd驱动HT1621
#include <reg51.h>
#include <types.h>
#include <intrins.h>
#include <bin.h>
extern BOOL PIN_1621_CS;
extern BOOL PIN_1621_DAT;
extern BOOL PIN_1621_WR;
#define CLK_DELAY() {_nop_(); _nop_(); _nop_();}
// Name: Write_1621_RAM
void Write_1621_RAM(BYTE addr, BYTE idata *buf, BYTE size){
BYTE i,j;
BYTE tmp;
PIN_1621_CS = 1; // clear CS
CLK_DELAY();
PIN_1621_CS = 0; // clear CS
// CMD - 101
tmp = B0000_0101;
for (i=3; i>0; --i){
PIN_1621_DAT = tmp & 0x04; tmp <<= 1;
PIN_1621_WR = 0; CLK_DELAY();
PIN_1621_WR = 1; CLK_DELAY();
// Addr - 0x00
tmp = addr & B0011_1111;
for (i=6; i>0; --i){
// data - successive 32 bytes
for (j=size; j>0; --j){
tmp = *buf;
for (i=8; i>0; --i){
PIN_1621_DAT = tmp & 0x01; tmp >>= 1;
buf ++;
// Name: Write_1621_COMMAND
static void Write_1621_COMMAND(BYTE config){
BYTE i;
BYTE cmd;
CLK_DELAY();
cmd = B0000_0100;
// CMD - 110
PIN_1621_DAT = cmd & 0x04; cmd <<= 1;
// config
for (i=9; i>0; --i){
PIN_1621_DAT = config & 0x80; config <<= 1;
// Name: Init_1621
void Init_1621(void){
Write_1621_COMMAND(B0010_1001); // 4 comm
Write_1621_COMMAND(B0000_0011); // Turn On LCD
Write_1621_COMMAND(B0000_0001); // Enable System
// Name: TurnOn_1621
void TurnOn_1621(BOOL bOnoff){
if (bOnoff){
Write_1621_COMMAND(B0000_0011); // bias generator
else {
Write_1621_COMMAND(B0000_0010); // bias generator
// M62446 drving routines, VER 1.0
// COPYRIGHT (C) 2000, Enbia Technology Inc.
// Target: 8031
// AUTHOR: STEVEN LUO
// Revision History:
// 2001/1/5 - Original Version
#include <reg51.h>
#include <types.h>
#include <bin.h>
extern BOOL PIN_M62446_LATCH;
extern BOOL PIN_M62446_DATA;
extern BOOL PIN_M62446_CLK;
static idata WORD shadow_word00=0;
static idata WORD shadow_word01=0;
static idata WORD shadow_word10=0;
static idata WORD shadow_word11=0; // for storing the control word status //
static BOOL bM62446Muted; // Set when 62446 is muted
static void Write_M62446_Word(WORD myword);
// Name: Volume_Validate
// Description:
// Arguments:
// Return value: none
static BYTE Volume_Validate(char vol){
if(vol<0)vol=0; // negative, should be 0
else if(vol >80) vol=80; // >80, set to 80
return 80 - vol; // Down to Up
// Name: Mute_M62446
// Description:
// Arguments:
void Mute_M62446(void){
Write_M62446_Word(0xa141); // B1010000 1010000 01, B10100001_01000001
Write_M62446_Word(0xa142);
Write_M62446_Word(0xa143);
bM62446Muted = 1;
// Name: UnMute_M62446
// Description:
// Arguments:
void UnMute_M62446(void){
shadow_word01&=0xfFFC; shadow_word01|=0x01; Write_M62446_Word(shadow_word01);
shadow_word10&=0xfffc; shadow_word10|=0x02; Write_M62446_Word(shadow_word10);
shadow_word11&=0xfffc; shadow_word11|=0x03; Write_M62446_Word(shadow_word11);
bM62446Muted = 0;
// Name: Write_M62446_Left
// Description: This function Write 2 bytes to M62446
// Arguments:
void Write_M62446_Left(char vol){
WORD temp;
temp=Volume_Validate(vol);
temp<<=9;
shadow_word01&=0x01ff;
shadow_word01|=temp;
// DE=0;DF=1;
shadow_word01&=0xfffc; shadow_word01|=0x01;
if (bM62446Muted) return;
// Name: Write_M62446_Right
// Arguments:
void Write_M62446_Right(char vol){
WORD temp;
temp<<=2;
shadow_word01&=0xfe03;
// DE=0;DF=1;
// Name: Write_M62446_Center
// Arguments:
void Write_M62446_Center(char vol){
WORD temp;
temp<<=9;
shadow_word10&=0x01ff;
shadow_word10|=temp;
// DE=1;DF=0;
// Name: Write_M62446_SubWoofer
// Arguments:
void Write_M62446_SubWoofer(char vol){
WORD temp;
temp<<=2;
shadow_word10&=0xfe03;
// DE=1;DF=0;
// Name: Write_M62446_SurLeft
// Arguments:
void Write_M62446_SurLeft(char vol){
WORD temp;
temp<<=9;
shadow_word11&=0x01ff;
shadow_word11|=temp;
// DE=1;DF=1;
// Name: Write_M62446_SurRight
// Arguments:
void Write_M62446_SurRight(char vol){
WORD temp;
temp<<=2;
shadow_word11&=0xfe03;
// DE=1;DF=1;
static BYTE code Treble_Bass_TAB[11]={
0x0e, // 0, -10db
0x0c, // 1, -8db
0x0b, // 2, -6db
0x0a, // 3, -4db
0x09, // 4, -2db
0x00, // 5, 0db
0x01, // 6, +2db
0x02, // 7, +4db
0x03, // 8, +6db
0x04, // 9, +8db
0x06 // 10, +10db
// Name: Write_M62446_Treble
// Arguments: 0-20,
// 0: -10db
// 10: 0db
// 20 +10db
void Write_M62446_Treble(BYTE Treble){
WORD temp;
Treble=Treble_Bass_TAB[Treble];
temp=Treble;
temp<<=12;
shadow_word00&=0x0fff;
shadow_word00|=temp;
// DE=0;DF=0;
shadow_word00&=0xfffc;
Write_M62446_Word(shadow_word00);
// Name: Write_M62446_Bass
// Arguments: 0-20,
// 0: -10db
// 10: 0db
// 20 +10db
void Write_M62446_Bass(BYTE Bass){
WORD temp;
Bass=Treble_Bass_TAB[Bass];
temp=Bass;
temp<<=4;
shadow_word00&=0xff0f;
// DE=0;DF=0;
// Name: Write_M62446_Bypass
// Arguments: 1, bypass on, 0: off
void Write_M62446_Bypass(BOOL bOnOff){
if (bOnOff) shadow_word00 |= 0x0004; // On
else shadow_word00 &= 0xfffb; // off
// DE=0;DF=0;
shadow_word00 &= 0xfffc;
// Name: Write_M62446_Output
// Arguments: port=1-4, BYTE=1 or 0
void Write_M62446_Output(BYTE port, BOOL bOnoff){
WORD temp, mask=1;
temp=bOnoff;
temp <<= (12-port);
mask <<= (12-port);
shadow_word00&=~mask;
// DE=0;DF=0;
#define DELAY() {_nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();_nop_(); _nop_();
_nop_(); _nop_();}
// Name: Write_M62446_Word
// Arguments:
static void Write_M62446_Word(WORD myword){
register BYTE i;
PIN_M62446_LATCH=0;
for (i=16;i>0;--i){
if(myword & 0x8000) PIN_M62446_DATA=1; // MSB first
else PIN_M62446_DATA=0;
myword<<=1; // Rotate Right
DELAY();
PIN_M62446_CLK=1;
DELAY();
PIN_M62446_CLK=0;
DELAY();
PIN_M62446_LATCH=1;
Ht1621中文资料   Ht1621pdf
[此贴子已经被作者于2008-7-7 17:43:22编辑过]
更多回帖
打开APP
