韦东山Linux嵌入式课程社区
直播中
李建平
7年用户 202经验值
私信 关注
为什么linux启动根文件系统会出现以下报错?
ARM-linux-gcc  version 4.3.2
linux-3.4.2
根文件系统(用的是老师提供的): fs_mini_mdev_new.yaffs2
分区信息   (512K, 128K, 4M, -)
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x0000000a0000 : "param"
0x0000000a0000-0x0000004a0000 : "kernel"
0x0000004a0000-0x000010000000 : "root"
启动内核时报如下错误信息, 我感觉好像是没有找到yaffs2 文件系统。 但我已经在 make menuconfig 中 把yaffs2 文件系统支持添加了。而且内核也打了yaffas2的补丁。请老师帮忙看看。谢谢!
uncorrectable error :
end_request: I/O error, dev mtdblock3, sector 2
EXT3-fs (mtdblock3): error: unable to read superblock
EXT2-fs (mtdblock3): error: unable to read superblock
end_request: I/O error, dev mtdblock3, sector 0
Buffer I/O error on device mtdblock3, logical block 0
end_request: I/O error, dev mtdblock3, sector 8
Buffer I/O error on device mtdblock3, logical block 1
end_request: I/O error, dev mtdblock3, sector 16
Buffer I/O error on device mtdblock3, logical block 2
end_request: I/O error, dev mtdblock3, sector 24
Buffer I/O error on device mtdblock3, logical block 3
FAT-fs (mtdblock3): unable to read boot sector
VFS: Cannot open root device "mtdblock3" or unknown-block(31,3): error -5
Please append a correct "root=" boot option; here are the available partitions:
1f00             512 mtdblock0  (driver?)
1f01             128 mtdblock1  (driver?)
1f02            4096 mtdblock2  (driver?)
1f03          257408 mtdblock3  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
Backtrace:
[] (dump_backtrace+0x0/0x10c) from [] (dump_stack+0x18/0x1c)
r6:c38a7000 r5:fffffffb r4:c381df2c
[] (dump_stack+0x0/0x1c) from [] (panic+0x7c/0x1d0)
[] (panic+0x0/0x1d0) from [] (mount_block_root+0x180/0x23c)
r3:00000000 r2:c384c9f4 r1:c381df2c r0:c03c5b60
[] (mount_block_root+0x0/0x23c) from [] (mount_root+0x88/0x108)
[] (mount_root+0x0/0x108) from [] (prepare_namespace+0x110/0x1d0)
r7:c04774e0 r6:c044573c r5:c044573c r4:c0477540
[] (prepare_namespace+0x0/0x1d0) from [] (kernel_init+0x164/0x1b8)
r6:00000008 r5:c0444f10 r4:c0449c34
[] (kernel_init+0x0/0x1b8) from [] (do_exit+0x0/0x76c)
回帖(6)
顾天天
2019-10-12 09:00:44
你的bootargs指定文件系统类型了吗?为啥我看到了ext3 fat啥的
举报
张清华
2019-10-12 09:13:04
这个是yaffs2文件系统,所以没有指定文件类型。我也很奇怪,为什么出现ext3的。 按道理系统应该会自动匹配yaffs2,可是看错误提示,系统好像没有做这一步。
举报
贾玲
2019-10-12 09:32:04
u-boot参数如下:
SMDK2440 # print
baudrate=115200
bootargs=console=ttySAC0,115200 root=/dev/mtdblock3
bootcmd=nand read 30000000 A0000 400000;bootm 30000000
bootdelay=5
ethact=dm9000
ethaddr=00:0c:29:bc:d8:55
ipaddr=192.168.1.14
mtddevname=boot
mtddevnum=0
mtdids=nand0=jz2440-0
mtdparts=mtdparts=jz2440-0:512k(boot),128k(params),4m(kernel),-(rootfs)
netmask=255.255.255.0
partition=nand0,0
serverip=192.168.1.11
stderr=serial
stdin=serial
stdout=serial
Environment size: 455/131068 bytes
SMDK2440 #
举报
王淑珍
2019-10-12 09:42:53
bootargs指定一下rootfstype=yaffs
举报
顾天天
2019-10-12 09:48:53
估计是内核有问题.
举报
更多回帖
