参考http://processors.wiki.ti.com/index.php/SensorTag_User_Guide EZ430 Battery Pack Interface可以得知
The UART interface is not supported in the SensorTag firmware.
To use the interface a connector must be soldered to the board. The connector is type is BL SMD 91-06 U from MPE Gerry
sensorTag没有打开串口,所以不能通过串口来读取数据,您可以自行添加这个功能。
可以参考帖子http://www.deyisupport.com/question_answer/wireless_connectivity/f/45/t/48581.aspx
举报
