TI论坛
直播中
蒋荣艳
8年用户 300经验值
私信 关注
[问答]
请问cc1310的wor历程可以在加了PA的电路板上运行吗?
cc1310的wor历程可以在加了PA的电路板上运行吗?因为pa有两个脚去控制发送接收和休眠,那么这个怎么去使用呢?
回帖(3)
盛越熊
2019-9-17 14:06:41
CC1310控制PA,可以参考TRM的23.3.2.8 External Signaling部分
The radio CPU controls the signals CPEGPO0 and CPEGPO1. For control of an external front end, CPEGPO0 is high when the LNA must be enabled; otherwise, CPEGPO0 is low. CPEGPO1 is high when the PA must be enabled; otherwise, CPEGPO1 is low.
另外,还可以参考下面这个文档
http://processors.wiki.ti.com/index.php/CC26xx_Range_Extender_Control
举报
蒋荣艳
2019-9-17 14:21:00
你好,这个原理我知道了,但是具体怎么操作呢?
举报
盛越熊
2019-9-17 14:40:54
The default configuration of RF Core Data Out 0 is to be high when the LNA is enabled and similarly RF Core Data Out 1 is configured to be high when the PA is active. These RF Core Data outputs can be directly assigned to DIOs through the IO Control registers IOCFGx (x = DIO number) bits 5-0. See the technical reference manual chapter 11.3.2.1 details.
Let's say the PA_enable signal is on DIO7, the LNA_enable signal is on DIO13 and HGM is on DIO14. We thus need to connect RF Core Data Out 0 to DIO13 and RF Core Data Out 1 to DIO7.
Thus the following registers must be set using the CC26xxware driverLib:
  • IOCFG7 = 0x30
  • IOCFG13 = 0x2F
which can be done through the IOCPortConfigureSet function:
    #include     // Map RFC_GPO0 to DIO13    IOCPortConfigureSet(IOID_13, IOC_PORT_RFC_GPO0,                    IOC_IOMODE_NORMAL);    // Map RFC_GPO1 to DIO7    IOCPortConfigureSet(IOID_7, IOC_PORT_RFC_GPO1,                    IOC_IOMODE_NORMAL);将CC1310芯片的PA和LNA输出到指定的GPIO引脚上,这些GPIO引脚分别连到PA芯片的PA和LNA上即可。在发送数据需要使能PA时,该引脚会自动拉高,同理,接收数据时,LNA引脚会自动拉高。
举报
更多回帖
