天线|RF射频
直播中
王岩
8年用户 897经验值
私信 关注
[问答]
LWIP多条socket连接只有两条成功了是怎么回事?
小弟目前在搞f107 freertos+lwip,目前遇到的问题是只能成功建立两条socket连接
具体
设备即作为Server、又做Client
2条client可以成功连接到远程server
远程client连接设备的server端是,连接被拒绝,抓包显示窗口大小不够
不知问题出在哪里
是底层驱动问题?内存太小?
请各位大虾指点迷津,小弟在此不胜感激
回帖(3)
黄思
2019-9-17 09:34:37
对您的帮助深表感谢。我修改了一些还是不行,下边是我的配置,这个和网口驱动有关吗?
/* ---------- Memory options ---------- */
/* MEM_ALIGNMENT: should be set to the alignment of the CPU for which
   lwIP is compiled. 4 byte alignment -> define MEM_ALIGNMENT to 4, 2
   byte alignment -> define MEM_ALIGNMENT to 2. */
#define MEM_ALIGNMENT           4
/* MEM_SIZE: the size of the heap memory. If the application will send
a lot of data that needs to be copied, this should be set high. */
#define MEM_SIZE                (5*1024)
/* MEMP_NUM_PBUF: the number of memp struct pbufs. If the application
   sends a lot of data out of ROM (or other static memory), this
#define MEMP_NUM_PBUF           100
/* MEMP_NUM_UDP_PCB: the number of UDP protocol control blocks. One
   per active UDP "connection". */
#define MEMP_NUM_UDP_PCB        6
/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCP
   connections. */
#define MEMP_NUM_TCP_PCB        10
/* MEMP_NUM_TCP_PCB_LISTEN: the number of listening TCP
   connections. */
#define MEMP_NUM_TCP_PCB_LISTEN 5
/* MEMP_NUM_TCP_SEG: the number of simultaneously queued TCP
   segments. */
#define MEMP_NUM_TCP_SEG        20
/* MEMP_NUM_SYS_TIMEOUT: the number of simulateously active
   timeouts. */
#define MEMP_NUM_SYS_TIMEOUT    10
 * MEMP_NUM_NETCONN: the number of struct netconns.
#define MEMP_NUM_NETCONN                5
 * MEMP_NUM_NETBUF: the number of struct netbufs.
#define MEMP_NUM_NETBUF                 3
/* ---------- buf options ---------- */
/* BUF_POOL_SIZE: the number of buffers in the pbuf pool. */
#define BUF_POOL_SIZE          20
/* BUF_POOL_BUFSIZE: the size of each pbuf in the pbuf pool. */
#define BUF_POOL_BUFSIZE       500
/* ---------- TCP options ---------- */
#define LWIP_TCP                1
#define TCP_TTL                 255
/* Controls if TCP should queue segments that arrive out of
   order. Define to 0 if your device is low on memory. */
#define TCP_QUEUE_OOSEQ         0
/* TCP Maximum segment size. */
#define TCP_MSS                 (1500 - 40)  /* TCP_MSS = (Ethernet MTU - IP header size - TCP header size) */
/* TCP sender buffer space (bytes). */
#define TCP_SND_BUF             (5*TCP_MSS)
/*  TCP_SND_QUEUELEN: TCP sender buffer space (pbufs). This must be at least
  as much as (2 * TCP_SND_BUF/TCP_MSS) for things to work. */
#define TCP_SND_QUEUELEN        (2* TCP_SND_BUF/TCP_MSS)
/* TCP receive window. */
#define TCP_WND                 (10*TCP_MSS)
/* ---------- ICMP options ---------- */
#define LWIP_ICMP                       1
/* ---------- DHCP options ---------- */
/* Define LWIP_DHCP to 1 if you want DHCP configuration of
   interfaces. DHCP is not implemented in lwIP 0.5.1, however, so
   turning this on does currently not work. */
#define LWIP_DHCP               1
#define LWIP_DNS                       0
#define LWIP_SO_RCVTIMEO                0
/* ---------- UDP options ---------- */
#define LWIP_UDP                1
#define UDP_TTL                 255
/* ---------- Statistics options ---------- */
#define LWIP_STATS 0
#define LWIP_PROVIDE_ERRNO 1
举报
李高胜
2019-9-17 09:43:15
正确答案是:在os_cfg.h系统配置文件里面修改#define OS_MAX_QS                 4u ,为#define OS_MAX_QS                 6u
你就可以创建3个socket了。试试吧。
举报
郑尧
2019-9-17 09:49:38
我也是这样的问题,求问题解决
举报
更多回帖
