是德科技
直播中
王利祥
8年用户 1520经验值
私信 关注
[问答]
如何将NI-VISA更新到最新的版本?
嗨,如何将NI-VISA(或NI-MAX)更新到最新的版本?问候,FUKUI utaka>“VEE Pro(JC Park)”写道:>> Hi VRF,>>>>我有一台GPIB设备(
TC2300A,www.tescom-lab.com)这个工作>在$ B!H(BNI-MAX + NI-4882(ver2.2)+> NI-PCMCIA-GPIB $ B!I(B.(
设备对* IDN响应良好?)。>>>它仍然使用Agilent Connection Expert(Agilent> Connection Expert + NI-4882(版本2.2)+ NI-PCMCIA-GPIB)检测设备作为附加>屏幕拍摄。
然而它没有$ B!G(* IDN的Bt响应?。>设备的EOL设置为0A(十六进制)。>>>>>建议我试试?? >>>>>>问候,>
> JC Park >>> --->
以上来自于谷歌翻译
     以下为原文
  Hi,
How about updating your NI-VISA(or NI-MAX) to the newest vrsion?
Regards,
FUKUI utaka
> "VEE Pro(JC Park)" wrote:
> Hi VRF,
> I have a GPIB equipment(TC2300A, www.tescom-lab.com) and this works
> fine under configuration of  $B!H (BNI-MAX + NI-4882(ver2.2) +
> NI-PCMCIA-GPIB $B!I (B.(The equipment responses well for *IDN?).
> It still detects the equipment using Agilent Connection Expert(Agilent
> Connection Expert +NI-4882(ver2.2) + NI-PCMCIA-GPIB) as attached
> screen shoot. However it doesn $B!G (Bt response for *IDN?. The EOL of the
> equipment was set as 0A(in hex).
> Suggestion for me to try??
> Regards,
> JC Park
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
> To unsubscribe send a blank email to
> "leave-vrf@it.lists.it.agilent.com".
> To send messages to this mailing list, email "vrf@agilent.com".
> If you need help with the mailing list send a message to
> "owner-vrf@it.lists.it.agilent.com".
>    mbridge.jpg    Type: JPEG Image (image/jpeg)
>               Encoding: base64
*  $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
*  $BIY;NDL3tl (B
*  $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!!;n835;=Q (BPj e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL  $B!!30@~ (B 044-754-3661, $B!!Fb@~ (B 711-3-1966,7 <-- 2004/09/27 $B$h$j30@~$,JQ (B
$B$j$^$7$? (B
* FAX  $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
回帖(5)
陈妙宙
2019-9-5 11:03:09
Alex,同样的事情Win2K / VEE 7.01I确实注意到VEE 6的例子处于VEE 3执行模式。
当我将VEE 7示例更改为VEE 3执行模式时,它的工作方式与VEE 6示例相同。
我试过VEE 4&amp;
VEE 5模式,它们导致与VEE 7示例相同(意外)的行为。我的投票称这是一个BUG。
尽管如此,可以确定具有ERROR的公式的输出未定义,特别是当您选择忽略任何错误时。
我尝试将输出引脚馈送到字母数字显示器然后工作正常,我也尝试将错误引脚连接到字母数字显示器(正如您所提到的)然后工作正常。
如果我通过结点通过字母数字显示输入输出,则显示屏将获得NIL值。
我还添加了一个符合JCT ==> a * 2 ==> alpha显示的公式(a * 2),得到公式的“0”输出。
不是人们所期望的,但由于我们忽略了错误,我们真正期待什么?再次,我投票BUG !!!!
如果没有别的,只是由于不一致。
我不建议转到VEE 3执行模式但是...... Rob“Alexander Poulikakos(KI / EAB)”| alexandander.poulikakos@ericsson.com> 04/04/2005 05:49 AMPlease回应“Alexander Poulikakos
(KI / EAB)“收件人:VRF |vrf@agilent.com> cc:主题:[vrf]严重错误/ VEE 7.03Hi中的奇怪行为任何人都可以在VEE 7.03中解释这种行为吗?请参阅附件:bug1_vee7.03。
为什么JNC正在执行?注意:如果你把东西连接到错误引脚,那么一切似乎都运行正常。每个人都有这种行为,还是只是我的实验室环境?我在VEE 6.03中做了同样的例子,它似乎
工作正常。请参阅附件:bug1_vee6.03.vee注意:如果你打开“显示执行流程”,你会发现公式框没有得到绿色突出显示,为什么?问候,亚历克斯---你目前订阅了vrf
如:ramarquardt@ra.rockwell.com订阅时发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent
.COM” .T
o向此邮件列表发送邮件,发送电子邮件至“vrf@agilent.com”。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。
附件剪辑:bug1_vee7.03.vee(11385字节)>> ||
附件剪辑:bug1_vee6.03.vee(7601 bytes)>> ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送空白电子邮件至“join-vrf@it.lists.it.agilent
。取消订阅发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。
以上来自于谷歌翻译
     以下为原文
  Alex,Same thing here Win2K/VEE 7.01I did notice that VEE 6 example is in VEE 3 execution mode. When I changed the VEE 7 example to VEE 3 execution mode, it worked the same as your VEE 6 example. I tried VEE 4 & VEE 5 modes, they resulted in the same (unexpected) behaviour as the VEE 7 example.My vote says this is a BUG. Although, a case could be made that the output of a formula with an ERROR is undefined, especially when you choose to ignore any errors. I tried feeding the output pin to an alphanumeric display and it then works OK, I also tried connecting the error pin to an alphanumeric display (as you mentioned) and it then works OK. If I feed the output through the alphanumeric  display via a junction the display gets a NIL value. I also added a formula (a*2) in line with the JCT ==> a*2 ==> alpha display and get a "0" output of the formula. Not what one would expect but since we are ignoring the error what do we really expect?Again, I vote BUG !!!!  If nothing else, just due to the inconsistancy. I don't recommend moving to VEE 3 execution mode however.
....Rob
"Alexander Poulikakos (KI/EAB)" [email=%7Calexander.poulikakos@ericsson.com]|alexander.poulikakos@ericsson.com[/email]>04/04/2005 05:49 AM
Please respond to "Alexander Poulikakos (KI/EAB)"
        To:        VRF [email=%7Cvrf@agilent.com]|vrf@agilent.com[/email]>
        cc:
        Subject:        [vrf] Serious bug/Strange behaviour in VEE 7.03
Hi Vrf
Can anyone please explain this behaviour in VEE 7.03?
See attached file: bug1_vee7.03.vee
Why is the JNC executing?
NOTE:
if you connect something to the error pin, then everything seems to work fine.
Does everyone have this behaviour, or is it just my lab invironment?
I did the same example in VEE 6.03 and it seems to be working fine.
see attached file: bug1_vee6.03.vee
NOTE:
if you turn on "Show execution flow" you'll notice that the Formula box
never gets that green highlighting, why?
Regards,
Alex
You are currently subscribed to vrf as: ramarquardt@ra.rockwell.com
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
|| Attachment clipped: bug1_vee7.03.vee (11385 bytes ) >>
|| Attachment clipped: bug1_vee6.03.vee (7601 bytes ) >>
---You are currently subscribed to vrf as: [email=r***@soco.agilent.comTo]r***@soco.agilent.comTo[/email] subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list,  email "vrf@agilent.com".  If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
举报
陈妙宙
2019-9-5 11:22:10
我试过VEE 4&amp;
如果没有别的,只是由于不一致。
为什么JNC正在执行?注意:如果你把东西连接到错误引脚,那么一切似乎都工作正常。每个人都有这种行为,还是只是我的实验室环境?我在VEE 6.03中做了同样的例子,它似乎
.COM” .T
。取消订阅发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件至此邮件列表,请发送电子邮件至“vrf@agilent.com”。
以上来自于谷歌翻译
     以下为原文
....Rob
        cc:
Hi Vrf
NOTE:
NOTE:
Regards,
Alex
举报
陈妙宙
2019-9-5 11:34:51
我试过VEE 4&amp;
如果没有别的,只是由于不一致。
.COM” .T
以上来自于谷歌翻译
     以下为原文
....Rob
        cc:
Hi Vrf
NOTE:
NOTE:
Regards,
Alex
举报
王利祥
2019-9-5 11:40:07
> JC Park >>> --->您目前订阅了vrf:fukui.yutaka@jp.fujitsu.com>要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。
>要取消订阅,请发送一封空白电子邮件至>“leave-vrf@it.lists.it.agilent.com”。>要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。>如果您需要帮助
邮件列表发送消息>“拥有
er-vrf@it.lists.it.agilent.com“。>>名称:mbridge.jpg> mbridge.jpg类型:JPEG图像(image / jpeg)>编码:base64-- *********
******* $ BJ!0f !! K-!J(BFUKUI Yutaka)*电子邮件:fukui.yutaka@jp.fujitsu.com* $ BIY; NDL3tl(B * $ B $ b $ N $
E $ / $ j?d?JKIt!&amp; @ 8;:5; = Q3 + H / E} 3gIt !!; n835; = Q(BPj e> .EDCf#4(B- $ B#1(B)
- $ B#1 !! M9JXHV9f!'(B211-8588 * TEL $ B !! 30 @〜(B 044-754-3661,$ B !! Fb @〜(B 711-3-1966,7订阅发送)
一封空白的电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件
以上来自于谷歌翻译
     以下为原文
  Hi,
Regards,
FUKUI utaka
> Hi VRF,
> Regards,
> JC Park
>               Encoding: base64
*  $BIY;NDL3tl (B
$B$j$^$7$? (B
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
举报
更多回帖
