单片机学习小组
登录
直播中
黄鼎
8年用户
151经验值
私信
为什么我的1602液晶显示DS12C887会延迟?
开启该帖子的消息推送
液晶
代码
ds12c887
#include
#define uchar unsigned char
#define uint unsigned int
***it dula=P2^6;
***it wela=P2^7;
***it rs=P3^5;
***it lcden=P3^4;
***it s1=P3^0;
***it s2=P3^1;
***it s3=P3^2;
***it rd=P3^7;
***it beep=P2^3;
***it dscs=P1^4;
***it dsas=P1^5;
***it dsrw=P1^6;
***it dsds=P1^7;
***it dsirq=P3^3;
uchar count,shi,s1num,flag;
char si,fen,miao;
uchar code table[]=" 2016-08-24 MON";
uchar code table1[]=" : : ";
void write_ds(uchar,uchar);
void set_al
ARM
(uchar,uchar,uchar);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void set_
ti
me();
void init()
uchar num;
//EA=1;
//EX0=1;
//IT0=1;
dula=0;
wela=0;
lcden=0;
//si=18;
//fen=41;
//miao=20;
//set_time();
//set_alarm(20,17,00);
//write_ds(0x0B,0x26);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<11;num++)
write_date(table1[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
rd=0;
if(s1==0)
delay(5);
if(s1==0)
flag=1;
while(!s1);
s1num++;
if(s1num==1)
write_com(0x80+0x40+10);
write_com(0x0f);
if(s1num==2)
write_com(0x80+0x40+7);
write_com(0x0f);
if(s1num==3)
write_com(0x80+0x40+4);
write_com(0x0f);;
if(s1num==4)
s1num=0;
write_com(0x0c);
flag=0;
write_ds(0,miao);
write_ds(2,fen);
write_ds(4,si);
if(s1num!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(9,miao);
if(s1num==2)
fen++;
if(fen==60)
fen=0;
write_sfm(6,fen);
if(s1num==3)
si++;
if(si==24)
si=0;
write_sfm(3,si);
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(s1num==1)
miao--;
if(miao==-1)
miao=59;
write_sfm(9,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
write_sfm(6,fen);
if(s1num==3)
si--;
if(si==-1)
si=23;
write_sfm(3,si);
void write_ds(uchar add,uchar date)
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P0=add;
dsas=0;
dsrw=0;
P0=date;
dsrw=1;
dsas=1;
dscs=1;
uchar read_ds(uchar add)
uchar ds_date;
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsds=0;
P0=0xff; //读取前口赋值高 0xff
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
void set_time()
write_ds(4,18);
write_ds(2,41);
write_ds(0,20);
void set_alarm(uchar ashi,uchar afen,uchar amiao)
write_ds(1,amiao);
write_ds(3,afen);
write_ds(5,ashi);
void main()
init();
while(1)
keyscan();
if(flag==0)
miao=read_ds(0);
fen=read_ds(2);
si=read_ds(4);
write_sfm(9,miao);
write_sfm(6,fen);
write_sfm(3,si);
//while(1);
/*void exter() interrupt 0
uchar c;
beep=0;
c=read_ds(0x0c);
这是代码 如果最后一段
[size=15.1999998092651px]void exter() interrupt 0[size=15.1999998092651px]{[size=15.1999998092651px] uchar c;[size=15.1999998092651px] beep=0;[size=15.1999998092651px] c=read_ds(0x0c);[size=15.1999998092651px]} [size=15.1999998092651px]不加的话液晶正常显示时间[size=15.1999998092651px]但如果一旦加进去 就会显示成这样[size=15.1999998092651px]
[size=15.1999998092651px]不过半分钟之后 时间又能正常显示了 想了很长时间 一直没有答案
回帖
(6)
许朝亮
2019-9-4 07:57:18
延迟是什么意思?
你图片是有字符缺失,没显示出来。
延迟是什么意思?
你图片是有字符缺失,没显示出来。
举报
余英姿
2019-9-4 08:16:34
恩 不仅显示不出来 按键调节也失效 都是大概半分钟后一切又恢复正常
举报
张婧怡
2019-9-4 08:33:00
这都看不出来! 你在主函数里对P0口进行操作,中断里也对P0口进行操作,肯定有冲突了…………
你自己想想,假如单片机正在和1602通信当中,这时发生中断,会是什么结果??
举报
李熙国
2019-9-4 08:44:38
肯定要中断啊 因为是设置闹钟 问题是我把前面中断关闭了 按说此时中断是不会对主程序产生影响的才对 还有 如果有影响应该一直有影响才对 而不是影响半分钟后就没影响了
举报
更多回帖
rotate(-90deg);
回复
相关问答
液晶
代码
ds12c887
求有偿求购周期方波信号频率周期测量设计
2020-05-28
1836
MSP4301493
DS12C887
2016-05-11
2600
购买
ds12c887
设计的时钟
2020-04-16
1886
用STC
12C
5A60S2单片机点阵
显示
DS12C887
不走时间
2014-04-19
4061
新手请教一个关于
ds12c887
的问题
2016-03-03
3588
DS12C887
时钟电池已用完
2020-03-07
4008
ds12c887
时间
显示
乱码而且只有秒是在走
2015-07-22
4719
求
ds12c887
如何设置两组闹钟
2013-04-19
3714
如何用
ds12c887
芯片设置两组闹钟??
2013-04-25
2633
最近在做16*32的led点阵,想在点阵上用
ds12c887
显示
时间
2014-03-07
2025
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
