是德科技
直播中
李秀云
8年用户 815经验值
私信 关注
[问答]
如何在GPIB上更改仪器的地址
>我无法更改GPIB14接口上任何仪器的地址。>高级手册的实验3-1(C:My DocumentsVEE ProgramsAdvSolutionsLab 3-1.vee)>是一个示例程序,它只是更改DMM的地址和它
根本不适合我...对于我们这些没有实验室3-1的人,您是1)尝试更改仪器本身的GPIB地址吗?
- 并非所有仪器都可以通过总线更改其地址。
您必须参考仪器手册才能确定。
- 我不建议在程序中动态执行此操作。
地址应手动设置,记录,具体投射 - 不要改变它。
2)或者您只是想改变VEE使用的地址?
- 也就是说,让VEE扫描它想要的仪器GPIB并锁定它吗?Les HammerPartnerComplete Test720 SW 14th St.Loveland,CO.80537Les.Hammer@CompleteTest.com ---您目前订阅的是vrf:r*** @
soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。
要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。
以上来自于谷歌翻译
     以下为原文
> I can not change the address of any instrument on GPIB14 interface.
> Lab 3-1 of the advanced manual (C:My DocumentsVEE ProgramsAdv
> is a sample program that just changes the address of a DMM and it simply
does not work for me...
For those of us who don't have Lab 3-1, are you
  1) trying to change the GPIB address of the instrument itself?
      -- not all instruments can change their address over the bus.
         You would have to refer to the instrument manual to know for sure.
      -- and I wouldn't recommend doing this dynamically in a program.
         The address should be set manually, documented, cast in concrete -
don't change it.
  2) or are you just trying to change the address that VEE uses?
     -- That is, have VEE scan GPIB for the instrument it wants and lock on
to it?
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO.  80537
You are currently subscribed to vrf as: r***@soco.agilent.com
To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list,  email "vrf@agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
回帖(1)
李秀云
2019-8-28 09:21:42
嗨,我无法更改GPIB14接口上任何仪器的地址。
高级手册(C:My DocumentsVEE ProgramsAdv SolutionsLab 3-1.vee)的实验3-1是一个示例程序,只是改变了数字万用表的地址,它根本不适用于我...我很感激任何建议,山姆
---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“
vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。
以上来自于谷歌翻译
     以下为原文
  Hi,
I can not change the address of any instrument on GPIB14 interface. Lab 3-1 of the advanced manual (C:My DocumentsVEE ProgramsAdv SolutionsLab 3-1.vee) is a sample program that just changes the address of a DMM and it simply does not work for me...
I appreciate any suggestions,
Sam
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
举报
更多回帖
