附上代码,已经
仿真验证,可以实现,请问还有其它更简单的方法吗?
-- use Division IP core achieve /5
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
en
tity Division_ip is
port (
Clk_i : in std_logic;
Rst_i : in std_logic;
DivisionA_i : in std_logic_vector(17 downto 0);
DivisionC_o : out std_logic_vector(17 downto 0)
end Division_ip;
architecture arch_Division_ip of Division_ip is
component M_Division port (
clock : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
end component;
constant DivisionB_c : std_logic_vector(31 downto 0) := b"0100_0000_1010_0000_0000_0000_0000_0000";
signal zero : std_logic_vector(31 downto 0) := b"0000_0000_0000_0000_0000_0000_0000_0000";
shared variable i : integer range 0 to 17;
signal j : integer range 0 to 256;
signal Dataa_s : std_logic_vector(31 downto 0);
signal DivisionA_s : bit_vector(17 downto 0);
signal DivisionD_s : bit_vector(31 downto 0);
signal DivisionC_s : std_logic_vector(23 downto 0);
signal result_s : std_logic_vector(31 downto 0);
begin
DivisionA_s <= to_bitvector(DivisionA_i);
process (Rst_i, Clk_i) begin
if (Rst_i = '0') then
i := 17;
Dataa_s <= (others => '0');
elsif rising_edge (Clk_i) then
if (DivisionA_i(i) = '1') then
Dataa_s(22 downto 5 ) <=to_stdlogicvector( DivisionA_s SLL (18-i));
Dataa_s(30 downto 23) <= conv_std_logic_vector(i+127,8);
else
i := i - 1;
end if;
end if;
end process;
DivisionC_s <= (others => '0');
DivisionC_s <= to_stdlogicvector( ('1' & DivisionD_s(22 downto 0)) SRL (150 - j));
end if;
end process;
j <= conv_integer(result_s(30 downto 23));
DivisionD_s <= to_bitvector(result_s);
U_M_Division_0 : M_Division port map (
clock => Clk_i ,
dataa => Dataa_s ,
datab => DivisionB_c ,
result => result_s
DivisionC_o <= DivisionC_s(17 downto 0);
end arch_Division_ip;
