您好,“是否可以使用此AWG的输出功率放大来广播FM信号?”是的,绝对。
但是,广播信号不会很有趣。
U2761A上没有外部调制输入,您可以输入广播信号。
FM功能只是一个内部单音频率调制。谢谢!Mueller
以上来自于谷歌翻译
以下为原文
Hello,
Is it possible to use the output from this AWG with Power amplify to broadcast FM signal ?
Yes, absolutely. However, the broadcast signal will not be very interesting. There is no external modulation input on the U2761A where you could feed in your broadcast signal. The FM capability is just an internal single tone frequency modulation.
Thanks!
Mueller
但是,广播信号不会很有趣。
以上来自于谷歌翻译
以下为原文
Hello,
Thanks!
Mueller
举报
