本手册中有一个示例程序,介绍了一些测试用例(第6-16页)。
如果您打开了COM端口,请在该端口中写入您在示例中看到的字符串。
这应该设置,从单元读取状态等。你可以使用许多其他命令,但是一旦你尝试了这个例子,你应该能够找出其他的.Regards,Uday
以上来自于谷歌翻译
以下为原文
There is an example program in the manual that explains a few test cases (page 6-16). If you have a COM port open, write to that port the strings that you see in the example. That should set, read status etc. from the unit.
There are many other commands that you could use, but once you try the example, you should be able to figure out the others.
Regards,
Uday
以上来自于谷歌翻译
以下为原文
Regards,
Uday
举报
