收藏家必须在圈内,他们不会以任何其他方式工作。
如果将收集器数据存储到变量,则可以将To File取出循环。
然后,在循环之外,使用To Files。我已经对你的程序进行了一些清理,这可能会告诉你在VEE中通常是怎么做的。
(我已经在VEE工作了将近15年。)顺便说一句,你不需要Counter对象中的clear终端。
仍有进一步改进的余地,但这比你所拥有的要好。参见附件。
另请查看我发送的其他程序,了解收藏家通常如何使用。-Bill
以上来自于谷歌翻译
以下为原文
The collectors have to be inside the loop, they won't work any other way. You could take the To File out of the loop if you store the collector data to a variable. Then, outside the loop, use the To Files.
I've done some cleanup of your program and maybe this will show you how things are normally done in VEE. (I have been working with VEE for almost 15 years now.) BTW, You don't need the clear terminal in the Counter object. There is still room for further improvement, but this is better than what you had.
See attached. Also look at the other program I sent to see how collectors are normally used.
-Bill
附件
以上来自于谷歌翻译
以下为原文
-Bill
附件
举报
