Thanks for the reply. Previous to to VISA the software ran on the driver supplied by the mfgr of the GPIB board, Measurements Computing.
Here's the code:
Function WriteToInstrument(tq_num%, cmd$, rd_delay&) As String
'On Local Error GoTo errWrtInst
Dim vi As Long 'Session to instrument
Dim vi_status As Long
Dim rSize As Long 'return byte count for read operation
Dim strRes As String
Static viDFRM As Long 'Sessions of Default Resource Manager
Static wti_count%
'Debug.Print TQ_Model$(tq_num%) & " cmd$[" & cmd$ & "]"
If wti_count% = 0 Then
Track_VISA_Data "reset", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
wti_count% = 1
End If
WriteToInstrument = "OK"
sz% = -1
Select Case tq_num%
Case Is = AMM%
If TQ_Address$(AMM%) = TQ_Address$(PWS%) Then
tq_num% = PWS%
End If
If TQ_BusParameters$(tq_num%) = "GPIB" And InStr(cmd$, "?") Then
sz% = CInt((pwsPoints% + 1) * 12)
'Debug.Print RptLog$(tst_prc%) & " cmd$/sz%[" & cmd$ & "/" & sz% & "]"
strRes = String(sz%, Chr$(32))
Else
strRes = String(200, Chr$(32))
End If
Case Else
strRes = String(32, Chr$(32)) '200
End Select
If viDFRM = 0 Then
If cmd$ "release" Then
'Open the default resource manager session for valid devices
Select Case TQ_BusParameters$(tq_num%)
Case Is = "GPIB", "LAN", "LANtoGPIB", "LANtoMODBUS"
vi_status = viOpenDefaultRM(viDFRM)
Debug.Print "Open DRM " & "[" & viDFRM & "]"
If vi_status VI_SUCCESS Then
Track_VISA_Data "Open DRM", whchInstr$, viDFRM, vi, Hex(vi_status), Data_Filter(Trim(cmd$))
RptLog$(err_des%) = "Fail Open: Default Resource Manager session[" & Str(viDFRM) & "]"
WriteToInstrument = "VISA Error!"
viDFRM = 0
GoTo errWrtInst
End If
Case Else 'RS232, PCI, USB
End Select
End If
End If
If cmd$ = "release" Then
If viDFRM > 0 Then
Debug.Print "Close " & TQ_Model$(tq_num%) & "[" & viDFRM & "]"
vi_status = viClose(viDFRM)
viDFRM = 0
Exit Function
Else
Exit Function
End If
End If
Case Is = "GPIB"
wti_count% = wti_count% + 1
'Debug.Print RptLog$(tst_prc%) & " wti_count%[" & wti_count% & "]"
'Open the session to the resource
whchInstr$ = "GPIB1::" & TQ_Address$(tq_num%) & "::INSTR"
vi_status = viOpen(viDFRM, whchInstr$, VI_NULL, VI_NULL, vi)
trkDFRM& = viDFRM
trkStatus$ = Hex(vi_status)
trkCmd$ = Data_Filter(Trim(cmd$))
Track_VISA_Data "open", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
RptLog$(err_des%) = "viOpen session Failed[" & Hex(vi_status) & "][" & Format$(vi, "0") & "]"
WriteToInstrument = "VISA Error!-tq_num%[" & Format$(tq_num%, "0") & "]"
viDFRM = 0
GoTo errWrtInst
End If
'write to device - rd_delay& = 0 Then
cmd$ = cmd$ & vbLf
vi_status = viWrite(vi, cmd$, Len(cmd$), rSize)
RptLog$(err_des%) = "viWrite Failed[" & Hex(vi_status) & "]"
'Track_VISA_Data "viWrite", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
viDFRM = 0
GoTo errWrtInst
End If
Else
rd_delay& = Abs(rd_delay&)
End If
'Read the results as a string.
If InStr(cmd$, "?") And rd_delay& > 0 Then '11.09.02
Sleep rd_delay&
Select Case sz% 'tq_num%
Case Is > 0 '= AMM%
vi_status = viRead(vi, strRes, sz%, rSize)
Case Else
sz% = 64
End Select
trkDFRM& = viDFRM
Track_VISA_Data "read", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
'If vi_status VI_SUCCESS_MAX_CNT Then
RptLog$(err_des%) = "viRead Failed[" & Hex(vi_status) & "] byte count[" & Format$(sz%, "0") & "/" & Format$(rSize, "0") & "]"
viDFRM = 0
GoTo errWrtInst
End If
'Debug.Print "strRes[" & strRes & "]"
dat_str$ = strRes
WriteToInstrument = Data_Filter(Trim(dat_str$))
End If
vi_status = viClose(vi)
Track_VISA_Data "close vi", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
RptLog$(err_des%) = RptLog$(err_des%) & " Fail close:[" & Str(viDFRM) & "]"
End If
'If wti_count% >= 1500 Then
' vi_status = viClose(viDFRM)
' If vi_status VI_SUCCESS Then
' RptLog$(err_des%) = "Fail close:[" & Str(viDFRM) & "]"
' WriteToInstrument = "VISA Error!"
' End If
' viDFRM = 0
' wti_count% = 0
'End If
Case Is = "LAN"
whchInstr$ = "TCPIP0::" & TQ_LanAddress$(tq_num%) & "::INSTR"
trkDFRM& = viDFRM
'Track_VISA_Data "open", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
viDFRM = 0
GoTo errWrtInst
End If
cmd$ = cmd$ & vbLf
viDFRM = 0
GoTo errWrtInst
End If
Else
End If
Sleep rd_delay&
Case Is > 0 '= AMM%
Case Else
sz% = 64
End Select
trkDFRM& = viDFRM
'Track_VISA_Data "read", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
viDFRM = 0
GoTo errWrtInst
End If
dat_str$ = strRes
End If
'Track_VISA_Data "close vi", whchInstr$, trkDFRM&, vi, trkStatus$, trkCmd$
End If
Case Is = "LANtoGPIB" 'see Prologix note
DoEvents
whchInstr$ = "TCPIP0::" & TQ_LanAddress$(tq_num%) & "::" & TQ_LanPort$(tq_num%) & "::SOCKET"
RptLog$(err_des%) = "viOpen session Failed[" & Hex(vi_status) & "]"
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
'write to device
For n% = 1 To 3
lan_msg$ = Choose(n%, "++addr " & TQ_Address$(tq_num%), "++auto 0", cmd$) & vbLf
vi_status = viWrite(vi, lan_msg$, Len(lan_msg$), rSize)
RptLog$(err_des%) = "viWrite Failed[" & Data_Filter(Trim(lan_msg$)) & "/" & Hex(vi_status) & "]"
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
Sleep 250
Next n%
If InStr(cmd$, "?") Then
DoEvents
Dim strLAN As String * 64
Sleep rd_delay&
lan_msg$ = "++read eoi" & vbLf
RptLog$(err_des%) = "viWrite/Read Failed[" & Data_Filter(Trim(lan_msg$)) & "/" & Hex(vi_status) & "][" & rd_delay& & "]"
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
'Sleep 250
vi_status = viRead(vi, strLAN, 64, rSize)
If vi_status VI_ERROR_TMO Then
'vi_status = viClose(vi)
viDFRM = 0
RptLog$(err_des%) = "viRead Failed[" & Hex(vi_status) & "]"
End If
viDFRM = 0
GoTo errWrtInst
End If
End If
dat_str$ = Trim(strLAN) 'strRes
'Debug.Print " [" & Data_Filter(Trim(dat_str$)) & "]"
Else
WriteToInstrument = ""
End If
Case Is = "LANtoMODBUS"
whchInstr$ = TQ_Model$(tq_num%)
Select Case TQ_Model$(tq_num%)
Case Is = "E3645A"
'Debug.Print "Write-TQ_Model$(tq_num%)[" & TQ_Model$(tq_num%) & "]"
dat_str$ = PWS_E3645A(cmd$)
Case Is = "USB-2527", "PCI-DAS1602/12"
If cmd$ = "*IDN?" Then
WriteToInstrument = TQ_Model$(tq_num%)
End If
End Select
End Select
Exit Function
errWrtInst:
vi_status = viClose(vi) '11.09.16
RptLog$(err_src%) = "WriteToInstrument[" & whchInstr$ & "]"
RptLog$(err_idn%) = Data_Filter(Trim(cmd$))
Test_Logs "visa"
End Function
Here's the code:
Static wti_count%
wti_count% = 1
End If
sz% = -1
Select Case tq_num%
Case Is = AMM%
tq_num% = PWS%
End If
Else
End If
Case Else
End Select
If viDFRM = 0 Then
viDFRM = 0
GoTo errWrtInst
End If
End Select
End If
End If
If viDFRM > 0 Then
viDFRM = 0
Exit Function
Else
Exit Function
End If
End If
Case Is = "GPIB"
trkDFRM& = viDFRM
viDFRM = 0
GoTo errWrtInst
End If
cmd$ = cmd$ & vbLf
viDFRM = 0
GoTo errWrtInst
End If
Else
End If
Sleep rd_delay&
Case Is > 0 '= AMM%
Case Else
sz% = 64
End Select
trkDFRM& = viDFRM
viDFRM = 0
GoTo errWrtInst
End If
dat_str$ = strRes
End If
End If
' End If
' viDFRM = 0
' wti_count% = 0
'End If
Case Is = "LAN"
trkDFRM& = viDFRM
viDFRM = 0
GoTo errWrtInst
End If
cmd$ = cmd$ & vbLf
viDFRM = 0
GoTo errWrtInst
End If
Else
End If
Sleep rd_delay&
Case Is > 0 '= AMM%
Case Else
sz% = 64
End Select
trkDFRM& = viDFRM
viDFRM = 0
GoTo errWrtInst
End If
dat_str$ = strRes
End If
End If
DoEvents
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
'write to device
For n% = 1 To 3
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
Sleep 250
Next n%
DoEvents
Sleep rd_delay&
End If
viDFRM = 0
GoTo errWrtInst
End If
DoEvents
'Sleep 250
viDFRM = 0
End If
viDFRM = 0
GoTo errWrtInst
End If
End If
Else
End If
Case Is = "E3645A"
End If
End Select
End Select
Exit Function
errWrtInst:
Test_Logs "visa"
End Function
举报
