Cypress技术论坛
直播中
吴珺
8年用户 196经验值
私信 关注
[问答]
为什么静态时序分析受组件(符号)名称的影响?
为什么静态时序分析受组件(符号)名称的影响?我在示意图中有一个ISR,当我把它称为“CuttisIr”时,静态时序分析返回一个警告“设置时间违反”,但是当我称之为“UTHISISR”时,一切都很好,而我没有收到警告。我真的很害怕:(因为我不知道哪一个是最佳的部件名称,允许最大的工作时钟频率。谢谢您。
以上来自于百度翻译
     以下为原文
          Why is the static timing analysis affected by the component (symbolic) name? I have an ISR in the schematic, when I call it "CUT_ISR", the static timing analysis returns a warning "setup time violation" but when I call it "UT_ISR" all goes fine and I receive no warning. I'm really scared about that :( because I don't know which are the "optimum" names for the components that will allow the maximum working clock frequency. Thank you.
回帖(7)
王琳
2019-7-30 10:58:07
老实说,一个组件的名称对时间等任何东西都没有影响。你能发布你的完整项目,让我们都可以看看你的所有设置吗?要做到这一点,使用创建者& GT;文件-GT;创建工作区束(最小)并附加得到的文件(不要使用Chrome,它仍然不能工作,使用IE替代)。
鲍勃
以上来自于百度翻译
     以下为原文
  Well, to be honest: The name of a component has no influence on anything like timings etc. Probably something different is amiss. Can you post your complete project, so that we all can have a look at all of your settings? To do so, use
Creator->File->Create Workspace Bundle (minimal)
and attach the resulting file (do NOT use chrome, that still may not work, use IE instead).
    Bob
举报
王淑珍
2019-7-30 11:04:51
我认为这是因为通过改变组件的名称。造物者会以不同的方式分配安排/ sequence.andone硬件可能有一个较长的路径然后等它给你的警告。
以上来自于百度翻译
     以下为原文
  I think it it is because by changing the name of your component. Creator would allocate the hardware in a different way/sequence. And one of the arrangements may have a longer path then the other so it gives you the warning.
举报
吴珺
2019-7-30 11:15:03
呃,这正是正在发生的事情。有没有方法可以看出组件在布线后放置在哪里?谢谢您。
以上来自于百度翻译
     以下为原文
          H L, that is exactly what is happening. Is there any way to see where are the components placed after routing? Thank you.
举报
杨军
2019-7-30 11:32:54
没有“观众”的数字布局。无手动路由工具
要么用于数字。模拟有基本的观察者,尽管不是。
物理布局。
问候,Dana。
以上来自于百度翻译
     以下为原文
  No "viewer" for the digital layout yet. No manual routing tool
    either for digital. Analog has rudimentary viewer, albeit not
    physical layout.
    Regards, Dana.
举报
更多回帖
