是的,只有设置为1的比特才会被设置。xxxCLR只清除设置为1.xxxINV的比特,只反转设置为1.xxxINV的比特。所有SFR占用432位字,其中第一位是基本寄存器,第二位是CLR寄存器,第三位是SET寄存器,第四位是INV寄存器。IFS0 bit.bit不在PIC32上的原子位。在处理器的头文件中,有针对所有位的掩码定义,如果使用的话,可以使代码更清晰地读取。IFS0SET=_IFS0_T1IF_MASK;/Ruben
以上来自于百度翻译
以下为原文
Yes, only the bits set to 1 will be set.
xxxCLR clears only the bits set to 1.
xxxINV inverts only the bits set to 1.
All SFRs occupy 4 32 bit words, where the first is the base register, the second is the CLR register, the third is the SET register and the fourth is the INV register.
These instructions are atomic which IFS0bits.bit is not on a PIC32.
In the header file for the processor there are mask defines for all bits which, if used, makes the code clearer to read.
/Ruben
以上来自于百度翻译
以下为原文
/Ruben
举报
