该设备的数据表将显示HW如何工作、控制HW配置的接口等。TCP/IP、UDP等是以太网的应用层。您要么开发自己的以太网通信栈,要么从网络上提供的一些微芯片应用程序(或者使用与您类似的配置的其他供应方)下载它们……nd包括设置MCU,建立与ENC芯片通信的驱动程序接口,然后需要一个应用层或2或更多层来处理通信策略,即UDP、TCP等。可能的-或者你找到一些可供你进行DL修改的项目。
以上来自于百度翻译
以下为原文
The datasheet for the device will show you how the HW works, the interfaces to control the HW configurations, etc. TCP/IP, UDP, etc. are application layers of Ethernet. Either you develop you own Ethernet communication stacks, or you download them from some Microchip application provided on the web (or some other supplying party that is using a similar configuration as you are)...
Overall, there are several layers of an application to accomplish what you want to, and that will involve setting up your MCU, building driver interfaces to communicate with the ENC chip, and then you will need an application layer or 2, or more that will handle your communications strategy - i.e. UDP, TCP, etc. Either you do all the work to accomplish all of this - which is very much possible - or you find some project that is available for you to DL and modify accordingly.
以上来自于百度翻译
以下为原文
举报
