Cypress技术论坛
直播中
严岩
8年用户 181经验值
私信 关注
[问答]
开发板编程后没有运行固件
我有CY314PSoC EVALUSB开发板,我已经制作了CAPSENSE示例(5.1—我的第一个代码示例),正如在DEV板上的用户指南中所概述的。
我已经能够建立和生成项目的罚款,甚至假定程序固件到芯片上,但当我权力的DEV板,并试图按在PAD垫/滑块,没有发生。
然后我编写了与DeV板CD捆绑在一起的CAPENSE示例HEX文件,这实际上是有效的,但是当我打算对我的版本进行示例编程时(应该与捆绑在一起的内容完全一样),那就是当事情不起作用的时候。难道我没有正确创建HEX文件吗?
目标芯片是CY8C24894-24LTXI,我使用PSoC设计器5.1。
我已经仔细检查了模块参数和用户指南中指定的匹配项。
我已经将提供的main .c文件中的内容复制到我的主文件中(如指南中指定的)
我甚至清理和重建了这个项目,希望它能做些什么。它没有。
在开发板上的电源跳线设置的VBUS,这是它应该在的地方
开发板的页面在这里:http://www.cypress.com/?RID=37815
用户指南也在那一页上。
谢谢你的帮助!
以上来自于百度翻译
     以下为原文
  I have the CY3214-PSoC-EvalUSB development board and I've been making the Capsense example (5.1 - My First Code Example) as outlined in the user guide that came with the dev board.
    I have been able to build and generate the project fine and even supposedly program the firmware onto the chip but when I power the dev board and try to press on the capactive pads/slider, nothing happens.
    I then programmed the capsense example hex file that came bundled with the dev board CD and that actually worked but when I try to program my version of the example (which should be the exact same as what was bundled with the board), that's when things don't work.  Am I just not creating the hex file properly?
    The target chip is the CY8C24894-24LTXI and I'm using PSoC Designer 5.1
    I've double checked the module parameters and the match what is specified in the user guide
    I've copied the contents from the provided main.c file into my main file (as specified in the guide)
    I've even cleaned and rebuilt the project hoping it would do something.  It didn't.
    The power jumper on the dev board is set to Vbus, which is where it should be
    The Dev Board page is here: http://www.cypress.com/?rID=37815
    The user guide is also in that page provided above.
    Thanks for you help!
回帖(1)
杨军
2019-7-25 10:57:34
不明显发生什么,但设计师5.1相当老,目前的转速是
5.4,并且每个Rev总是修复问题并更新组件,因此考虑
安装它。
还可以考虑为论坛项目张贴一个存档来查看。
“文件”
“档案工程”
使用Firefox或IE,而不是Chrome发布。
问候,Dana。
以上来自于百度翻译
     以下为原文
  Not obvious whats happening, but Designer 5.1 quite old, current rev is
    5.4, and each rev always fixes issues and updates components, so consider
    installing that.
    Also consider posting an archive fo the project for forum to look at -
    “File”
    “Archive Project”
    Use Firefox or IE, not chrome to post.
    Regards, Dana.
举报
更多回帖
