在Marcus,由于TDA7498E可以在单声道BTL模式下提供更高的输出电流来驱动低阻抗负载(2欧姆),那么这些二极管已用于降低尖峰电压电平。
我想你在谈论BTL输出之间的缓冲网络22R + 330pF,你可以在输出和地之间将其改为10R + 680pF。但是对于感性负载,你需要用低输出功率的扬声器加交叉滤波器检查实际频率响应(否则你的高音扬声器可能烧坏),然后调整L + C值以平衡你在高频段的响应。
由于你的负载阻抗可能是4.9欧姆,那么36V电源的输出电流可能很小,最好使用TDA7498E。
谢谢
YT
以上来自于谷歌翻译
以下为原文
hi Marcus,due to TDA7498E can deliver higher output current to drive low impedance load (2 ohm ) in mono BTL mode , then those diode had been used to reduce spike voltage level.
I supposed you are talking about snubber networks 22R+330pF between BTL output, you may change it to 10R+680pF between output and ground . but regarding inductive load , you need to check the real frequency response with speaker plus crossover filter in low output power(otherwise your tweeter may be burnt out) , then adjusted L+C value to flat your response in upper audio band .
since your load impedance could be 4.9 ohm , then output current may be marginal with 36V supply , it's better to use TDA7498E .
Thanks
YT
谢谢
YT
以上来自于谷歌翻译
以下为原文
Thanks
YT
举报
