是德科技
直播中
张辉
8年用户 1433经验值
私信 关注
[问答]
如何使用SCPI通过LabView设置SPectrum Analyzer
在尝试使用SCPI通过labview设置SPectrum Analyzer时需要帮助。
我有一个中心频率,需要2个标记+/- 2.5 Mhz,然后读取两个标记之间的差值。
前面板手动控制序列是:标记1正常Delta -2.5 MHz正常标记2正常Delta 5 MHz试图使序列正确以使SCPI设置它是一个绊脚石。
想法?
解决方案?
以上来自于谷歌翻译
     以下为原文
  Need assistance in trying to setup SPectrum Analyzer via LabView using SCPI. I have a center frequency and need to 2 markers +/- 2.5 Mhz and then read the delta between the two markers.
Front Panel Manual control sequence is:
Marker 1
  Normal
  Delta
  -2.5 MHz
  normal
Marker 2
  Normal
  Delta
  5 MHz
trying to get the sequence correct to set this up with SCPI has been the stumbling block. Ideas? Solutions?
回帖(1)
李欢
2019-7-24 15:57:53
嗨 - 标记沿着迹线移动,通常设置为1001个迹线点。
因此,每个跟踪点由span /(跟踪点-1)间隔开。
例如,如果您的中心频率为50 MHz且跨度为10 MHz,则每个跟踪点间隔10E6 /(1001-1)= 10 kHz。
要打开增量标记并将标记移动到-2.5 MHz(这是-250个跟踪点),您将执行以下操作:calc:mark1:mode delta calc:mark1:x:pos -250要关闭delta标记和
然后将其重新打开并移动标记5 MHz执行以下操作:计算:标记1:模式位置计算:标记1:模式增量计算:标记1:x:位置500最终结果是您有标记+/- 2.5 MHz
并且分析仪显示它们之间的幅度差。
问候 -
以上来自于谷歌翻译
     以下为原文
  Hi -
The markers move along the trace, which is typically set to 1001 trace points.  So, each trace point is spaced apart by the span / (trace points – 1).  If for instance your center frequency is 50 MHz and your span is 10 MHz, then each trace point is spaced 10E6/(1001-1) = 10 kHz apart.
To turn on the delta marker and move the marker to -2.5 MHz (which is -250 trace points) you would do the following:
To turn off the delta marker and then turn it back on and move the marker 5 MHz do the following:
Calc:mark1:mode pos
Calc:mark1:mode delta
Calc:mark1:x:pos 500
The end result is that the you have the markers +/- 2.5 MHz and the analyzer is showing the delta in amplitude between them.
Regards -
举报
更多回帖
