赛灵思
直播中
王林
7年用户 192经验值
私信 关注
[问答]
如何获得ISE Design Suite许可证
我已经从eval套件随附的CD安装了ISE Design Suite。
现在它在最后询问许可证。
现在我被卡住了。
我想我想要“开始30天评估”,其中包括比特流。
但是当我选择并单击下一步,然后立即连接时,我只需转到窗口上的下一个选项卡。
我无法通过这个窗口。
“复制许可证...”按钮似乎想要找到我还没有的本地许可证。
我无法使用设置按钮,因为我不知道其他地方我有许可证。
这没有任何意义。
我应该做些什么?
DARN。
我阅读了http://forums.xilinx.com/t5/Inst ... ighlight/true#M7452“不再支持ISE评估许可证。”
DARN。
尝试了30天试用(没有比特流),但得到了错误“无法安装许可证,因为所需的信息不可用”。
这是包装盒中的12.2版本。
我记得在过去难以弄清楚当前的版本是什么。
14件事?
我应该重新安装更高版本吗?
那么我现在该怎么办?
有人想打电话给我吗?
770-ThreeFourFive-7634。
东部时间,每周7天,每天早上6点至晚上9点,除了瑜伽课上几天的几个小时外。
否则,我将花一个星期的时间只过一个即将到来的每个路障。
以上来自于谷歌翻译
以下为原文
I've installed ISE Design Suite from the CD that came with the eval kit.  Now it's at the end asking about a license.  Now I'm stuck.  I think I want to "Start 30 Day Evaluation" that includes bitstream.  But when I select that and click next, then connect now, I simply go to the next tab on the window.  I can't get past this window.  The "Copy License..." button seems to want to find a local license I don't already have.  I can't use the Set buttons because I don't know of some other place I have licenses.  It just makes no sense.  What am I supposed to do?
DARN.  I read at http://forums.xilinx.com/t5/Inst ... ighlight/true#M7452 "ISE evaluation license is no more supported."
DARN.  Tried the 30 Day Trial (No Bitstream) but get erorr "Unable to install license because required information is not available".
This is version 12.2 that came in the box.  I recall having difficulty figuring out in the past what IS the current version.  14 something?  Should I reinstall a later version?
So now what do I do?
Anybody feel like calling me on the phone?  770-ThreeFourFive-7634.  Eastern Time, 6am-9pm 7 days a week, available except for a few hours on a few days during yoga class.  Otherwise I'll spend a week getting past each of the upcoming road blocks only one at a time.
回帖(1)
姚庭芳
2019-7-24 09:12:42
嗨,正如在论坛链接中所提到的,YES,ISE评估许可证不再受支持。
您可以考虑使用ISE Webpack license.Follow以下步骤生成ISE Webpack许可证:1。
请访问www.xilinx.com/cn/getlicense2。
使用您的凭据登录3。
选择ISE Webpack许可证,然后单击生成许可证。
单击“下一步”两次,许可证将通过电子邮件发送给您。
收到许可证后,将许可证文件(Xilinx.lic)保存到某个位置。
现在打开Xilinx许可证配置管理器并单击复制许可证按钮并浏览到Xilinx.lic并选择它。谢谢,Vinay
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
As mentioned in the forums link, YES, ISE evaluation license is no more supported. You can consider using ISE Webpack license.
Follow below steps to generate ISE Webpack license:
1. Go to www.xilinx.com/getlicense
2. Login with your credentials
3. Select the ISE Webpack license and click generate license.
4. Click Next twice and the license will be emailed to you.
5. Once license is received, save the license file (Xilinx.lic) to some location.
6. Now open Xilinx License Configuration Manager and click on copy license button and browse to Xilinx.lic and select it.
Thanks,
Vinay--------------------------------------------------------------------------------------------
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
举报
更多回帖
