您好,您也可以查看下面的AR以调试此修剪行为.http://www.xilinx.com/support/answers/23990.html
问候,阿希什-----------------------------------------------
- - - - - - - - - - - - - - - - - - - - - - - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
以上来自于谷歌翻译
以下为原文
Hello,
You can also check below AR for debugging this trimming behavior.
http://www.xilinx.com/support/answers/23990.htmlRegards,
Ashish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
以上来自于谷歌翻译
以下为原文
Hello,
Ashish
举报
